Question about LG DLE0332 Gas Dryer
Dryer heating problems
My dryer turns and acts like it's heating but it is not. I do think it's the heating element, is this something I would have to replace, or is there a reset button for it? How do I fix it? If I get someone to fix it, what's a resonable price for them to charge?
  • Anonymous Dec 25, 2008
    where the fuse an circuit breaker locate at
    New Friend:
  • 60 Answers
You have this under "gas dryer" but by the model number it's an electrics dryer. There are 3 things you can check yourself first, 1) Check for blown fuses or popped circuit breakers. 2) Check the connections where the wires go in the back of the dryer 3) Make sure you have good airflow coming out of the vent outside your house. If all of these are good then you will have to call for service.
Posted on Dec 21, 2007
Roper dryer takes 2 cycles to dry clothes. How do I look at the heating element? OR since it is still heating, just not quickly enough, could it be something else? OR does it have 2 heating elements?
First of all, unplug the unit before working on it. Be careful inside a fuse box, dangerous voltages. It's usually safe to change fuses or flip a breaker so long as your not in a wet location. Most dryers run the heating element on 220 volts, meaning you can either have one larger breaker or you could have 2 smaller breakers or fuses. If that is the case, possibly one of these breaker "legs" has tripped. Check that first. I would sooner think one of the heating elements are open or "not heating". I would look up the Roper Model number and search for the heating elements section. Some do have a thermal fuse but I think that would cause both elements to quit. Take a look here: https://www.youtube.com/results?search_query=roper+dryer+heating+element+replacement
Dec 20, 2017 | Roper Dryers
Cwsr ele 2406024 cv50
I'm inclined to think that the problem is in the electronics, in the circuit board, since it's acting so oddly. The timer dial shouldn't allow the heating element to energize when the door is open.
If the thermal fuse is blown, you should NOT get heat.
Aug 13, 2014 | Kenmore Dryers
No heat in dryer
Check the wiring first. If that looks ok unplug dryer from wall then remove the heating element and test it for continuity. If it is wide open then it is bad.
Jun 18, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
My electric dryer works but isn't heating. What is the problem?
The burning smell usually indicates an over-heating motor. It could also be lint on the heating element that is getting hot (very dangerous).
Either way, I would not use the dryer until you call a certified techinican. If it's lint on the element, he should only charge you for a service cost to clean out the lint. If he diagnoses a bad motor, then the motor is usually around $150 and labor $100.
You can sometimes find technicians that offer free estimates. I think that will be your best bet.
Best of luck and thanks for using Fixya.com.
Aug 12, 2009 | Whirlpool LER4634J Electric Dryer
Turns on and has no heat
Check operating and high limit thermostats. Just check all thermostats and thermal fuse non resetable. After that is done check heating element. Good luck Be sure & check thermostats something is not shutting it off. Timer may be stuck in cycle.
Jun 26, 2009 | Kenmore Dryers
Heating element failed twice
most dryers have a thermal fuse on the exhaust it may be open
Mar 17, 2009 | Whirlpool LER5636P Electric Dryer
My Kenmore Elite Electic dryer mod #11063012101
OK .. on your dryer it does have a bi-metal switch that turns on and off the element....if your dryer produces heat... nothing wrong with element.. a thermostat w/wire sensor is the only way to check for your heat if its working correctly.. the other is to check if your clothes coming out of your washer is it wetter then before.. might need to spin one more time.. good luck..
Jan 13, 2009 | Kenmore 62602 Electric Dryer
Dryer heating element
usually if it heats up but long dry times ,,air flow problem inspect exhaust hose and vent s should resolve problems...
Dec 27, 2008 | Kenmore 62602 Electric Dryer
Dryer heats up, but acts like the motor isn't turning
POOR AIR FLOW IS YOUR PROBLEM THAT IT /// DOES THE DRUM MOVE
Nov 23, 2008 | Kenmore 94812 Top Load Stacked Washer /...
LG DLE0332 Gas Dryer Logo
155 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
