Question about Boating
30 hp johnson outboard motor trys to start. It will fire but won`t start. Sometimes I have no spark, other times I do have spark. It is a 1985 modle
1985 30 hp johnson used a cdi system(solid state, no points) check the power pack.
Posted on Mar 09, 2010
  • 86 Answers
Pull the flywheel off and file or replace the points. if you replace the points set them at .020
Posted on Oct 16, 2009
  • C.Allen Jan 01, 2013
    Any tips on pulling the flywheel??
    Sergeant:
  • 352 Answers
SOUNDS LIKE A POSSIBLE COIL PACK. HAVE THEM (IT) TESTED
Posted on Aug 06, 2012
How to set timing on 75 hp johnson outboard
creates an impulse to the cid as a magnet passes by . not much adjustment to timing small screw toward the front that moves the stator perhaps a 1/4 inch .
Aug 17, 2015 | Johnson Evinrude Timer Base, 6 Cyl 75-85...
I have a Johnson 70 outboard motor and I'm having
The moter has locked up is it 2sroke or 4sroke if 2 did you have oil in the fuel ?
Apr 29, 2013 | Boating
1997 50 hp Evinrude won't fire
Take off the top & expose the magneto clean with a fine grit sandpaper that should get fire to the plugs if still no fire u may have.to replace the points
Jul 23, 2012 | Boating
1968 evinrude starflite 100 hp no spark
Some of those had a battery ignition with a short cap and rotor, and some had a magneto which reached down into the bucket. Both had points and condenser like an old car. The cog belt location was critical. 2 teeth off and it would not fire. the key switch was wired diferently for each ignition system.
Jun 19, 2012 | Boating
Starter motor on 130hp Johnson outboard won't
does it turn or can you hear a click as you try ? if its not turning check the starter brushes and if it clicks then replace solinoide !
Apr 04, 2012 | Yamaha Boating
I have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
i have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
May 06, 2010 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Does an 85 johnson outboard motor 15 hp have
Not ignition points as a set of breaker points as we know it.The timing is set from magnets set under the flywheel.Hope this helps
Sep 02, 2009 | Sport & Outdoor - Others
1985 40 hp Johnson outboard wouldnt open up and
sounds like your mix is off and it's fowling the plugs. probably too rich. make sure the level in your carb bowls isn't too high. Really sounds like you should clean and bench set your carbs. Especially if a plug change helps but doesn't last, then it's got to be your fuel mix, or maybe timing.
Jul 16, 2009 | Sport & Outdoor - Others
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
Boating Logo
891 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
