When I turn on my tv all it has is a thin line that goes across the width of the tv. If you bumped the tv sometimes the picture would come back or you would get a partial picture. It is a Toshiba model # 36A40.
  • 4,234 Answers
This is a problem with the vertical circuit. Since a hit sometimes "fixes" the problem, it is likely to be a poor solder connection at the vertical IC. If you can solder and are comfortable working inside the set where there are potentially dangerous high voltages even when unplugged, you can fix this yourself. Locate the vertical IC (small flat IC attached to a heat sink that has markings like LA7837 or something similar.) Resolder the pins of the IC being careful not to short the pins together. Try the set. If that fails to resolve the problem, replace the IC with a new one. The part will cost around $20. Sometimes other parts will be defective as well. Work with the IC first and if there are still issues, the symptom will be different. Update this with any changed symptoms and I'll guide you through the additional steps.
Dan
Posted on Oct 02, 2009
  • 189 Answers
HELLO
The problem here sounds like dry joints on or around the field/frame output IC. I have sorted this kind of problem before with a soldering iron - some (but not all Toshiba's) seem to suffer dry joints on this part.
Try a resolder. If that does not cure it then the field output IC will have to be changed.
ALL THE BEST WITH THAT! (:-)
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
A horizontal thin black line has appeared across screen.
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jan 27, 2010 | JVC PD-42V475 42 in. HD-Ready Plasma...
No picture on screen
No,Ur vertical/horizontal IC is shorted or cold soldiers.Could be the parts that support the IC is also.
Aug 19, 2009 | Sanyo DS27820 27" TV
Thin horizontal line across the screen
you need to replace the electrolytic capacitor in the horizontal section of of your tv sets,cause the capacitor is weak.need to repair
Jan 11, 2009 | Sharp 27C-240 27" TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
