Question about Bosch Classixx WFL 2066 Front Load Washer
Hole in front seal round inside of door. need part and someone to fix please - or could I fix it myself? Thanks, Simon
  • 10,865 Answers
Your best bet is to replace it. here is what you do:
Look in your owner's manual or study the current seal to see how it is attached. If it is attached with bands, there will be one or more spaced around the seal. Remove them following manufacturer's instructions.
  • Step 2 Pull the seal from the door rim. For seals that are attached with sealant, you may need to slide a finger under the end and push it up while you pull it free with the other hand.
  • Step 3 Wash the area thoroughly with a degreasing cleanser. This will remove all traces of dirt, grime and old sealant around the area.
  • Step 4 Slide the open end of the new seal onto the door framehole in front seal round inside of door. need part - 2.gif. Make sure the fit is snug and it is completely slid into place.
  • Step 5 Glue around the join with the sealant or reattach the bands. Allow sealant to dry for at least two hours before running the machine.
  • Posted on Oct 02, 2009
      Genius:
    • Bosch Master
    • 1,460 Answers
    Depends where you are im in Glasgow....If it not the simplist of jobs if your quite handy the you should manage, Cost total around£28 .00 parts + labour
    Replace door seal
    its not to easy to do but,,,
    look at the bottom of the washer were the door closes the seal is held on with a spring wire,,unhook this wire and fold the seal inside the washer,,look for the inner drum there is another spring wire holding the inner part of the seal to the inner drum undo this as well,, pull old seal out through the door hole,,,now fold new seal so that the inner wire can be fitted round the new seal first to the inner drum,,then pull the new seal through the door hole and fit the outer wire to seal,,,
    and then job a good un?,,, not easy a,,well i did tell you this!
    Jul 12, 2010 | Frigidaire ATF6000ES Front Load Washer
    Solution for washing machine
    1. remove top cover.
    2. Remove soap dispenser draw.
    3. unscrew the screws securing the the soap dispenser to front console.
    4. Pull timer dial off, noting position of symbols.
    5. slide console panel to right, and lift up out of way of front panel.
    6. Undo 3 screws securing top of front panel.
    7. undo 2 screws securing door interlock to front of panel.
    8. Remove plastic clip securing door seal to front of panel.
    9. remove wire clamp band round front of door seal.
    10. Undo 3 screws at bottom of front panel securing it to cabinet .
    11. remove front panel.
    12. Unscrew thye top wire clamp band securing the seal to drum front.
    13. remove door seal.
    14. Fit new door seal, making sure the drainage holes are at the bottom dead center.
    15. reassemble in reverse order.
    16. Please rate my solution.
    17. Thanks.
    Nov 06, 2009 | Washing Machines
    The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
    The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
    Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
    Thanks.
    Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
    Bosch Classixx - Rubber Door Seal - I heard the easiest way to get the inner ring back on is to remove the whole front panel - How do I do this?
    Not recommended, tilt washer backwards, and work spring on with your fingers, slowly going round the inner lip of the seal, it helps if you can get someone to help by holding the spring in place as you work your round the seal.
    Thanks.
    Aug 27, 2009 | Bosch Classixx WFL 2066 Front Load Washer
    A HOLE IN THE RUBBER SEAL
    You can certainly diy. Unplug the washer. With the door open, look at the bottom of the seal. You'll see a ring clamp. Loosen the screw and remove the clamp. Peel the seal inward. It is easier to complete the seal swap with the front off. Remove the door and set aside. Locate the screws for the front of the machine and remove them, gaining access to the seal. Youcan either set the door to the side with the door lock wires still attached, or unclip them, which is easier. With the seal folded inward, you will likely find another clamp at the bottom. Loosen this as well. Remove the seal and replace with the new one, making sure to orient it like the old one was, and fold it to the inside like you had the old one for removal. Replace the front panel. Complete the seal installation, being careful to make sure that the clamp removed earlier gets put back in the groove and seats well. Reinstall the door. Best Regards, --WoobieDog--
    Jul 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Leaks water when washing from the door
    It's because of a hole in the door seal body. The water runs down inside the machine and comes under the front of the washing machine
    For this first unplugged and then take the top off the washer and there is usually a nut and bolt to undo which is holding a clamp band round the door seal fixing it to the tub.
    many cases where the water runs down from the bottom of the door but has in fact come from the soap dispenser but the leak was coming from the door.A thin line of water trickles from the soap dispenser and runs round the door frame to appear as a door seal leak. Make sure this isn't the case.
    Thanks.
    Kevin
    Jul 04, 2009 | Whirlpool Washing Machines
    How do you replace the door seal on a Bosch Nexxt front load washer?
    Tilt the m/c back and remove the clamp securing the seal to the front of the cabinet, double the seal back inside the washer door opening, and then pull the retaining spring off the inside of the door seal which is fitted in a groove at the back of the seal.
    Refit the new seal starting at the topmake sure the seal is fittef the right way up, drainage holes to the bottom.
    Work the seal on all the way round the drum, and then roll the spring into the groove at the back of the seal and work it round all the way round the seal, you will find it easier if you have someone to help hold the spring in place..
    Refit the seal round the front of the cabinet,and refit clamp at front.
    Plz rate this solution.
    Thanks.
    Dec 19, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
    Replace door gasket
    It sounds like you have left the spring on the inside lip of the door opening when you removed the old seal,
    You will have to take the seal off again and feel for the spring on the lip of the front of the drum, you will find it easier if you have something to hook it out with,it is fiddley, but you must get the spring out, or the seal will not stay on
    Refit seal as before, and double it back inside the drum,then fit the spring in the groove that you can feel on the lip of the door seal. Work the spring all the way rond feeding it into the groove as you go round, you will find it a lot easier if you have someone there to hold the spring as you are are fittingit, it is very fiddley, stick with it!!!.
    Plz rate this solution .
    Thanks.
    Dec 19, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
    Leak in the front door
    If the water is running down the outside at the front of the m/c, then you probably need new door seal.
    If however it is coming down the front from the top, then it is coming from your dispenser, check for blockage
    Nov 21, 2008 | LG WM-2077C Front Load Washer
    Bosch Classixx WFL 2066 Front Load Washer Logo
    137 people viewed this question
    Top Bosch Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
