Question about Nokia 5310 Cellular Phone
Vibrating mode not working
Once my 5310 switched off... i tried to switch it on .. then after a minute or two it got off.... after a day it got to be good and returned back to normal... after a few hours i realized that my vibrating mode is not working...wat to do with the problem
DRY THE HANDSET USING SOME HEATER &SEE THAT THERE IS NO MOISTURE IS THERE TAKE FRONT PANEL AND BAK PANEL AND REPLACE IT IF IT IS NT WORKING OPEN IT WITH T6 SCREWDRIVER AND CHECK CONTACT ON VIBRA.IF NT WRKING REPLASE THE VIBRA
Posted on Oct 02, 2009
    Problem Solver:
  • 19 Answers
Your using it too much, calm down!
My phone vibrates once and ends , the vibration is so light
Since you have not mentioned the model I will give a generral answer. Make sure that you have chosen from the phone settings the mode of the ******** to be continuous with the ring tone or only the vibration. If this is ok then you must check the ******** for fault. Open the panela nd get acess to the main board. the ******** is a tiny motor fitted with a counter weight which can be easily tested with a very low voltage even from an analogue multimeter. If this test runs the motor slowly change or else you have a fault onthe main board which need ffuther probe from the trigger switch. So check this out or take help.Hope you try carefully with the right tools. Good day
Aug 05, 2010 | Cell Phones
I have nokia 5310 model mobile.the mobile is giving beep sounds continuously and no keys are working except switch off. Even I can't unlock or receive calls. Phone is ringing but when I press answer it is...
hello dude...here is the solution for u... download the latest software which is compatibile to u r mobile(unique to u r mobile model) from nokia.com. In the site itself they have provided steps for insatllation, after successful installation restart your mobile and also do restorefactory settings once....if u r using memory card format it once.
Jul 03, 2010 | Nokia 5310 Cellular Phone
How to refresh 5310
If you mean how to reinstall firmware then visit your local mobile softwre guy he will fix it up. Or you can try the master reset option in your mobile.
Mar 03, 2010 | Nokia 5310 Cellular Phone
How to change from ringtone to vibrate and back
Press and hold the * key to switch to turn "Vibrating mode on." Press and hold * again to turn "Vibrating mode off."
Dec 23, 2009 | LG CU515 Cellular Phone
Phone got switched off due to less battery.how do i switch it on now??? nokia 5310 xpressmusic
Plug in its charger to the power outlet, and plug the smaller side of it in the phone. Wait some minutes, and you can turn it off.
Dec 10, 2009 | Nokia 5310 Cellular Phone
I've forgotten my security code. my phone is nokia 5130 xpressmusic. I changed it this morning and was able to access it, but now I can't.I've been trying since 12noon. pls help? I can't access my phone...
If your phone is prompting you for a security code and you have not activated one, please try the following:
  • Enter the default security code: 12345. Only try this once.
  • If your phone still requests a security code, please bring it to the nearest Nokia Care point for inspection.
Please note:
Some operators configure phones so that they only work with their SIM cards. In this case, if you enter the wrong code three or more consecutive times, the phone may lock permanently. If this happens, contact your operator or service provider for assistance.
In other cases when you enter the wrong code three or more consecutive times, the phone switches to a "sleep mode" and does not accept any entries for the next 15 minutes. In this case, power the phone off, then back on, let it sit idle or untouched for 15 minutes, then try again.
Jul 15, 2009 | Nokia 5310 Cellular Phone
Nokia 5310
Cell phones tend to need RESET from time to time. Take off your back cover and remove the battery. Leave out for a minute or so, Repower the Phone and it should be okay.
May 13, 2009 | Nokia 5220 XpressMusic Cellular Phone
After 2 - 10 Minutes Satellite connection is lost
Try this and see if it fixes your problem....first disable bluetooth then follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the above problem.
Dec 19, 2008 | Garmin Nuvi 660 GPS Receiver
Vibrate on
good day ! you need bring your phone to the cellphone technitian to check the vibra motor or the setting of your phone , if the setting is good thats mean the problem is the vibra motor or the vibra driver ic try to replace that ! good luck ! ...
Sep 09, 2008 | Sony Ericsson W200i Cellular Phone
Nokia 5310 Cellular Phone Logo
82 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
