Question about NEC VL-PAD-933 Tablet PC
Nec versa litepad motherboard
I NEED A NEW MOTHERBOARD NO ONE SEEMS TO HAVE IT SO PLZ HELP I NEED ONE ASAP
  • Anonymous Jun 05, 2008
    i need a new motherboard.
This might be a 'crazy cursor' related problem. Check this site for the fix:
http://www.veridicus.com/tummy/programming/litepadfix/
Posted on Dec 17, 2008
Power problem with Onix 7" tablet
The screen just flashess white i dont understand wat do do plz mi hopeles without it someone help me asap plz
Jan 27, 2013 | Tablets & eReaders
Sir ,sound not working in our pc please
plz try by reinstalling the sound driver from the motherboard cd
Aug 13, 2010 | Xplore Technologies Xplore iX104C2 Tablet...
Password problems on a Toshiba Protege m200 laptop
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password.
  1. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
  2. On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password.
  3. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
  4. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it.
Good luck and more power
nicole
Oct 03, 2009 | Toshiba Satellite R15 Tablet PC
Cheapest and best place to buy laptop motherboard
try newegg.com (think that's right site). do you have the skills you need to replace a motherboard in a laptop?
if not do you have a friend who's an 'electronics geek'? who can help you do it? get on HP website and look for a PDF manual for dis-assembly and replacement of various components. it can be pretty hairy!!
good luck!
Sep 24, 2009 | HP Pavilion TX2000Z Tablet PC
WHEN IM ON MY NEC VERSA LITEPAD DOIN WHATEVER THE CURSUR(arrow)CONSTANTLY JUMPS TO THE START MENU AND WONT STOP. HOW DO I STOP IT?
Almost all NEC litepad's have that problem, it's caused by AC current leaking fromt he adapter. Seacrch for LitePad Fix on google for a software solution. Also, preferably change your AC adapter to a OEM.
Jun 30, 2009 | NEC VL-PAD-933 Tablet PC
Thinkpad x60 reboot fails. Error message: Media test failure
plz check the hard disk data cable(cable which is connected to motherboard), if changing the cable do not solve the problem your hard disk may be corrupt
Mar 01, 2009 | IBM ThinkPad X60 Tablet PC
Root password
As you have mentioned that your motherboard is replaced pls check on the motherboard there is flat battery which act as the power given to memory card & if this is removed & placed again this might resolve your problem...........
Dec 22, 2008 | Tablets & eReaders
Nec versa litepad
Here Try this website they were the cheapest here . Hope this is what you are looking for. should be the right one thanks for looking
http://www.pchub.com/uph/catf/SearchItem.aspx?ft=nec+versa+board&gclid=CPDF3O-VrpACFSBMGgodTANs8g
Dec 16, 2007 | NEC VL-PAD-933 Tablet PC
Tablet pc
did you depress the reset on the bottom of the unit?
Jun 10, 2007 | NEC VL-PAD-933 Tablet PC
NEC VL-PAD-933 Tablet PC Logo
177 people viewed this question
Top NEC Tablets & eReaders Experts
Marvin
Marvin
Are you a NEC Tablet and eReader Expert? Answer questions, earn points and help others
