Motor not spinning (was making too much of craking noise before) it seems that the motor has jammed
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Could be the motor or something stuck in the drum, Remove the belt and note if motor is ok on own.....If all is well then motor okay, If no turn then could be motor or brushes....
Posted on Oct 02, 2009
My drill wont spin it just smokes and buzzes
Your brushes in the motor are shot. Or the drill got wet and the bearings are seizing up.
Sep 22, 2014 | Makita 1/2 in. Corded Drill
Doesn't want to go onto spin cycle just makes funny noises
Possible that there is slippage when the program comes to the spin mode. Please check the drive and see if the belt is slipping or the drive is jammed. If not check the motor drive.
Jan 21, 2013 | Beko Washing Machines
Is making humming noise and drum does not turn.
the noise is coming from the motor,you either have something jammed in the motor or blower wheel stopping the motor from spinning or the motor is bad,try this,open the door,hold the door switch in with one hand and spin the drum with your other hand and have someone else hit the start button at the same time,this sometimes starts the motor but the motor still has to be changed out.let me know what you find and send the model number
Oct 22, 2010 | GE Dryers
Dryer wont start, makes humming noise and thats all
sounds like you have abad motor,try spinning the drum by hand,if it moves most likely it's the motor,or the belt broke and is jammed in the motor stopping it from spinning,or if it's hard to turn something could be stuck in the blower wheel but it's the motor making the noise.you need to get in there and check it out.the motors are easy to change out on a kenmore dryer,also next time send the model number.let me know what you find
Aug 20, 2010 | Amana Dryers
Will not agitate or spin, belt is fine. Motor is not turning, just making a humming noise. Is the motor bad or are there brushes that can be replaced or.....?
move the belt to see if it is not jammed and spins the rotor. If that is the case, the Humming noise is then an indication of a burned motor and not from a good motor trying to drive a jammed belt.
Oct 09, 2009 | GE WJSE3110A Top Load Washer
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Apr 28, 2009 | Kenmore 23822 Top Load Washer
My washer will not spin in any cycles
i would still want to removehte motor and check for a craked motor coupling, if its cracked the tub willl not spin( or agitate) but will drain.
Mar 17, 2009 | Kenmore 24032\24036 Top Load Washer
Machine does not spin...makes a noise
your drive coupler is most likely broken.It is located between the motor and transmission.very easy fix.you will need to take the screws from the face of the machine out and lift the face .make sure to unplug.their are 2 gold clamps that hold your cabinet in place.take screw driver and pop clips out.pull your lid switch connection loose and pull cabinet off.you will see your pump in front bottom of machine.remove clamps that hold pump in place then remove the power clip from your motor.remove 2 clamps that hold motor in place and your drive coupler is their.it will be 2 white plastic pieces and a black rubber piece in center of 2.check if teeth are broke or if craked.
Mar 07, 2009 | Kenmore Washing Machines
BAGGING NOISE WHEN SPINNING
try moving the clothes around it might be an unbalanced load.
Jul 30, 2008 | Tecnik TKL9260 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
