Question about Sony Ericsson Walkman W810i Cellular Phone
Master reset i master reset my phone and now the menu will not appear and all it says is dynamic menu error... configuration error. please contact your network operator or service centre. what do i do????
    Brigadier General:
  • 7,752 Answers
You need to flash your mobile phone...the firmware for your phone should be .....R4EK001 CID50....you can go to www.topsony.com...but to get the firmware is going to cost a fee.....
Posted on Dec 21, 2007
Unclock security code
Steps to perform Master Reset
All configuration settings will be set back to their factory defaults. Personal data and downloaded content, however, will not be lost.
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Phone Settings.
  4. Scroll to and select Reset Settings.
  5. Select Master Reset.
  6. Select Yes.
  7. Enter Security code, then press OK. The default security code is 0000.
Steps to perform Master Clear
All configuration settings will be set back to their factory defaults. Also, all personal data (including contacts) and downloaded content will be erased.
  5. Scroll to and select Master Clear.
  6. Select Phone.
  7. Select Yes.
  8. Enter Security code, then press OK. The default security code is 0000.
Warning!: While reset/restore operation under process, you are advised not to remove your battery until the operation is completed and cellphone restarts otherwise phone damage may occur.
Dec 20, 2012 | LG Neon GT365 Cell Phone
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
How to do hard reset lg r500
I am supposing you are using the LG Xenon GR500.
Soft Reset
To perform a soft reset, remove and re-insert the battery.
Master Reset
IMPORTANT: All configuration settings will be set back to their factory defaults. Personal data and downloaded content, however, will not be lost.
  1. From the standby screen, press the menu icon.
  2. Tap the Settings Icon.
  3. Tap the Phone icon.
  4. Scroll to and tap Reset Settings.
  5. Tap Master Reset.
  6. Tap Yes.
  7. Enter the device's security code, then tap OK. The device will reset.
    NOTE: The default security code is 0000.
Master Clear
IMPORTANT: All configuration settings will be set back to their factory defaults. Also, all personal data (including contacts) and downloaded content will be erased.
  5. Tap Master Clear.
  6. Tap Phone.
  7. Tap Yes,
  8. Enter the device's security code, then press OK.
Oct 27, 2011 | LG Shine KE970 Cellular Phone
Dynamic menu error. I cant open my phone menu. What would I do?? It says 'configuration error. please contact your network operator or service centre.
To get the phone working again, you need to download a W200i EUROPE_2 custpack (depends on your phone's package). You have to create folders that go tpa then inside the tpa folder, a folder named preset then inside that folder, a folder named custom. So, it goes tpa/preset/custom with the customize.xml ..., in the custom folder now zip it up so you have tpa.zip, put it in the MISC box and press flash.
Jan 21, 2010 | Sony Ericsson W200i Cellular Phone
Sony k800i configuration error
You need to get the Settings for Internet/Wap and MMS from your Network Service Provider. These settings are usually sent as a text msg. When you receive the msg. choose save or install on your phone. Or get the settings directly from their website. The MMS service doesn’t always work between networks.
"Beware of Geeks bearing gifs"
Apr 06, 2008 | Sony Ericsson K800i Cellular Phone
Please help me...
you need to reflash the firmware on the phone.
Apr 01, 2008 | Sony Ericsson K800i Cellular Phone
Configuration error
You need to flash the phones firmware. You can try the Sony Ericsson Update Service, Wotanserver or take it a place that specializes in flashing or service point. There is no other solution...sorry...
Dec 20, 2007 | Sony Ericsson W550i Cellular Phone
Configuration error
i got sony ericsson w580i. i can't operate my mobile as on screen shows "configuration error. pls. contact your network operator or service centre" i did contact my network operator but confirmed that my sim is in usual working state. i can only listen to call but i cant go to main menu,neither i can listen to song. even i cant able to make call. pleasehelp me
Aug 01, 2007 | Sony Ericsson W550i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
293 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
