Question about Tasco Target/Varmint 6-24x42mm Rifle Scope Mil Dot Reticle
Crosshairs look like an x instead of a cross got back from ABO repair for stripped tube, where eye bell fits on. they said they changed the tube. I shot about 50 rds with it when problem developed tasco var 624x42m
  • 2,100 Answers
You can get to the cross hairs of a scope, but not much further without some special tools. Take off the rear lens, just unscrew the whole thing, and you will see inside there a ring with slots in the side? A small screwdriver in one of the slots should spin the threads out. You should be able to remove the cross hair tube, inside of it on the front, you should have another lock ring with the slots, spin the cross hairs straight and lock them down. This is a basic scope, I'm sure they are all different, but basically the same. Try it. You cant hurt it, it's already broken, and you will have to send it back out again if you fail. I don't know what they charged you, but there is a guy on ebay advertising scope repair, $45, all scopes.Hope this helps.
Posted on Apr 19, 2010
Transmission dipstick tube won't go back in on this 91 Silverado. Just had trans rebuilt and everything in place except the dipstick tube.... won't go in at all.... any suggestions?
Remove the cross member, remove the torque converter bolts and back the bell housing bolts out about an inch, so the transmission will drop some. It's still difficult to get in, but it will go.
Apr 25, 2015 | Chevrolet Silverado Cars & Trucks
Crosshairs are broken in Starrett No. 99E Telescopic Transit
I too am looking for an answer to this, my cross hairs are gone on my Starrett 101 A transit. Not even sure how to take it apart to look at repairing it myself. Just bought it.
Apr 18, 2014 | Buyenlarge The Berger Complete Engineers...
Why will my crosshair not raise up and down on my leopers scope
The cross hair is located in an erector tube and will not move in your view even when the point of impact moves.
May 08, 2013 | Optics
Where can I get them collimated?
All Tasco Warranty is now ceased and it is a new ABO (USA) policy will be in effect as follows.
  • ABO (USA) will promptly repair or replace, as it deems most suitable at our option, the product which is defective in workmanship at the nominal cost of $35.00 per unit, within the continental USA, to cover for basic repair and return shipping & handling costs. Make your check payable to ABO (USA), INC.
  • New policy of ABO (USA) does not cover the parts, defects caused by improper handling, installation, maintenance, abnormal use, alteration, wear and tear or accident. You will be advised of the additional cost prior to any repair.
  • All costs associated with the shipment of the product to ABO (USA) are the responsibility of the product owner.
repair service....305-860-4858
customer service..305-859-2010
Sep 11, 2011 | Tasco Waterproof Offshore Binoculars
I have Tasco Offshore 21 binoculars, that are out of alignment. Can I repair them?? Or do I need a PRO??
Repair Info....305-860-4858
customer service 305-859-2010
Jun 20, 2011 | Tasco Waterproof Offshore Binoculars
When I have my 8mm or 4 mm all I see is black. any suggestions? with the naked eye I can see stars and with the aiming scope I see them but through main eyepiece I see nothing.
The finder scope must be aligned with the main tube. Get a bright star into the MAIN tube eyepiece. Then without moving the scope adjust the crosshairs in the small finder scope so they CROSS at the same star.
Mar 27, 2011 | Vivitar Optics
Cross hair broken on my B S A mil dot 4-16 x 40 scope will any gun shop be able to repair
Yes, more than likely.
The scope just needs to be disassembled and the crosshair flange repaired or replaced.
A dealer should be able to order the part or at least fit one similar enough to work.
The trick is not to allow any moisture into the scope's internal cavity during the repair.
Mar 06, 2011 | BSA 4-16X40mm Mil-Dot Rifle Scope - ...
I have a Redfield 'LO-PRO' rifle scope, 3X9 variable, on my 300 Win Mag. It is about 20 to 25 years old and the cross hairs must be loose. They are not straight up and down anymore. Will this affect the...
It doesn't sound like anything's broken, it sounds like the scope has shifted in the rings, as you said "they are not straight up and down anymore", which won't effect your accuracy at short ranges, but if there's long ranges (more than 100 yards) you're going to be off some.
You can loosen the ring screws until the scope will turn, either 2 or 4 screws that hold the two halves of the ring together. There are numerous tools to help you align the crosshairs, but when I do this job I just square-up the reticle (crosshairs) by looking at the center of the reticles and let your eye follow the bottom crosshair down and make sure it is centered on the back of the bolt or receiver. If you need help doing this job, take it to your local gunsmith, he'll be able to square these up for you and boresight it.
Hope this helps, Mark the Gunsmith
Dec 09, 2009 | Optics
Tasco propoint PDP2 scope
Are you looking set the eye relief or the focus ring?
For eye relief you need to loosen the scope in the rings, mount the rifle to your shoulder with your standard hold and cheek weld. At this point, slide the scope back and forth in the rings until you obtain a full field of view. Tighten one of the rings slightly, dismount and remount the rifle several times to ensure correct adjustment. Level scope and tighten rings a final time.
For focus adjustment (remember that you are using the eyepiece to focus on the cross hair, not your target!) loosen the lock ring and turn the eyepiece until the cross hair is focused. It is best if you check it several times by closing and opening your eye several times. The crosshair should be instantly in focus. If your eye must adjust, then you need to refocus until the focus is instant.
The two dials on the scope are for adjusting the bullet point of impact. They will typically move POI 1/4 inch at 100 yards.
Nov 08, 2007 | Optics
Tasco Target/Varmint 6-24x42mm Rifle Scope Mil Dot Reticle Logo
584 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Tasco Optic Expert? Answer questions, earn points and help others
