Question about Vacuums
Replace control switch on Dyson 04 Model
Switch is housed in the top of a tube and there is no visible means of fixing or removing the switch. There is a small keyhole at the rear of the switch housing. Is there a tool needed to remove the switch and if so how does it operate?
  • 10,865 Answers
You have to remove the yellow on /off switch first. This is actualy a cover to the switch below. I removed mine with x1 of the centre prongs of a fork. Bend the centre prong to 90 degress to the fork handle, and put a tiny kink at the end of that prong. (you should end up with a funny lookink "Z" shape. Bend the remaining x3 prongs totally out of the way. Keeping the yellow switch cover up - use pliers here- push the singular prong down the flat egde of the cover. ie inboard. When you think you have the clip pushed in pull the cover up with the pliers and - hey presto access to the actual sw and wires is revealed.
Posted on Oct 02, 2009
How do I remove switch housing on dyson dc18?
I have a similar problem and want to check the switches...the last release is not apparent...appreciate some help...edw@nebulax.cm
Oct 09, 2012 | Dyson DC18 all floors Bagless Upright...
HOW DO YOU REMOVE THE DYSON04 SWITCH
Dyson sell a bent screwdriver.....
.... to make it easier to remove the switch cover:
I have used an ordinary screwdriver pushed into the tiny gap between the flat side of the switch cover (see picture above) to force the 'tooth' away from its housing, and then pull cover off.
Underneath is a torx-headed screw, which when removed allows withdrawal of the switch assembly.
Jul 28, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Power Button won't stay down/on.
Hi There,
Most likely your switch has gone bad, and you'll need to replace the on/off switch on your Dyson DC07. If you have to hold down the switch in order to keep the vacuum on, this is indicative of needing a new switch. Unfortunately this is very common problem on the Dyson vacuums2_bing.gif . The switch that Dyson uses for their vacuums is one of the cheapest switches on any vacuum on the market today. The good news though is that this is not a extremely difficult repair to fix.
I took pictures of replacing the switch assembly on one of our customers repairs they brought in. It was having the same exact problem that yours is, it just wouldn't stay on. Here's how you can fix the switch on your Dyson:
- T15 Torx Bit Screw Driver
- Genuine Dyson DC07 & DC14 Replacement On/Off Switch Part 901181
- Needle Nose Pliers
- Patience (haha)
The switch above is actually a link back to our site if you have yet to purchase the switch yet. We carry most every Dyson part.
IMPORTANT: MAKE SURE YOUR VACUUM IS UNPLUGGED BEFORE DOING ANYTHING ELSE!
Step 1. First thing you'll want to do is to unwrap the cord from the machine, and remove the handle from the upright part, then slide the hose all the way down the wand, and remove the hose from the handle assembly completely and set it aside. Also remove the dust bin assembly completely from the machine as well.
Step 2. Once you've remove the handle from the machine I find it easier to work on if you lay the vacuum on it's back, with the switch button facing upwards. Now remove the T15 Torx bit screw that is directly below the switch actuator. I have circled the location of this screw in the picture below:
Step 3: After you have taken off the screw, you're doing to need to remove the switch box housing from the vacuum that the screw was securing. Simply use your flat head screw driver, and pry the two small arms upwards. Be careful when prying, the plastic components on Dyson Vacuums are really cheap quality plastic, and I can't tell you how many times I have seen these plastic parts break when customers bring in repairs to us here at govacuum headquarters. Here's a picture of the location of where you should pry the switching off:
Here's what the vacuum should look like after the switch housing has been removed:
Step 4. Use your needle nose pliers to remove the terminals from both of the switch poles.
Step 5. Take out the new switch assembly. I find it the easiest to use my needle nose pliers to reattach the wires to the new switch, but it also can be done with just your hands. Both both wires to your switch. If the cords have come loose while you have been working on the vacuum, you'll need to put the wires back into their proper places as well. This is how the switch and the wires should look like when you're done:
Step 6. Once the switch and cords are back to their normal places, simply put the switch housing cover back on, and screw in the one screw.
I hope that this repair was helpful to you, if you have any questions or have any problems, please feel free to use the clarification request form here on Fixya.
If you ever need any for your Dyson, we do carry most parts and accessories on our site under our Dyson Parts Section .
If this was helpful, please be so kind and leave feedback for the repair. This is really, really appreciated and is the reason repair professionals like myself continue to post free repair help on Fixya rather then just answering the paid questions.
Thanks again,
Chris J.
GoVacuum
Apr 17, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Will not stay on.
Hi There,
Most likely your switch has gone bad, and you'll need to replace the on/off switch on your Dyson DC07. If you have to hold down the switch in order to keep the vacuum on, this is indicative of needing a new switch. Unfortunately this is very common problem on the Dyson vacuums . The switch that Dyson uses for their vacuums is one of the cheapest switches on any vacuum on the market today. The good news though is that this is not a extremely difficult repair to fix.
I took oictures of replacing the switch assembly on one of our customers repairs they brought in. It was having the same exact problem that yours is, it just wouldn't stay on. Here's how you can fix the switch on your Dyson:
- Needle Nose Plyers
- Patience (haha)
IMPORTANT: MAKE SURE YOUR VACUUM CLEANER IS UNPLUGGED BEFORE DOING ANYTHING ELSE!
Step 2. Once you've remove the handle from the machine I find it easier to work on if you lay vacuum2_bing.gif on it's back, with the switch button facing upwards. Now remove the T15 Torx bit screw that is directly below the switch actuator. I have circled the location of this screw in the picture below:
Step 3: After you have taken off the screw, you're doing to need to remove the switch box housing from the vacuum that the screw was securing. Simply use your flat head screw driver, and pry the two small arms upwards. Be careful when prying, the plastic components on Dyson vacuums2_bing.gif are really cheap quality plastic, and I can't tell you how many times I have seen these plastic parts break when customers bring in repairs to us here at govacuum headquarters. Here's a picture of the location of where you should pry the switching off:
Step 4. Use your needle nose plyers to remove the terminals from both of the switch poles.
Step 5. Take out the new switch assembly. I find it the easiest to use my needle nose plyers to reattach the wires to the new switch, but it also can be done with just your hands. Connect both wires to your switch. If the cords have come loose while you have been working on the vacuum, you'll need to put the wires back into their proper places as well. This is how the switch and the wires should look like when you're done:
If you ever need any supplies for your Dyson, we do carry most parts and accessories on our site under our Dyson Parts Section .
Thanks again,
Chris J.
GoVacuum
Apr 08, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Red button won't stay on
Greetings,
Most likely your switch has gone bad, and you'll need to replace the on/off switch on your Dyson DC07. If you have to hold down the switch in order to keep the vacuum on, this is indicative of needing a new switch. Unfortunately this is very common problem on the Dyson vacuums. The switch that Dyson uses for their vacuums is one of the cheapest quality switches on any vacuum on the market today. The good news though is that this is not a extremely difficult repair to fix.
- Patience (haha)
Step 2. Once you've remove the handle from the machine I find it easier to work on if you lay vacuum on it's back, with the switch button facing upwards. Now remove the T15 Torx bit screw that is directly below the switch actuator. I have circled the location of this screw in the picture below:
Step 3: After you have taken off the screw, you're doing to need to remove the switch box housing from the vacuum that the screw was securing. Simply use your flat head screw driver, and pry the two small arms upwards. Be careful when prying, the plastic components on Dyson vacuums are really cheap quality plastic, and I can't tell you how many times I have seen these plastic parts break when customers bring in repairs to us here at govacuum headquarters. Here's a picture of the location of where you should pry the switching off:
I hope that this repair was helpful to you, if you have any questions or have any problems, please feel free to use the clarification request form here on Fixya. If this repair was helpful to you, please be sure to rate the repair helpful by clicking the thumbs up icon in the top right hand coner. This is a nice gesture that will ensure that professionals will continue to post free repair solutions here on Fixya.
Thanks again,
Chris J.
GoVacuum
Apr 03, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Power switch does not work. Vacuum only runs while holding down the power button.
Greetings,
- Patience (haha)
Thanks again,
Chris J.
GoVacuum
Mar 28, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do i fix the on/off button on my dyson.
Greetings,
- Patience (haha)
Thanks again,
Chris J.
GoVacuum
Mar 11, 2010 | Dyson DC07 All Floors Bagless Upright...
Dyson upright will not power up
As was my problem, checked and washed filters (both) checked all accessable tubes but problem was that the tube inside the drum and the tapered section at the top ws solid with dust.
remove 3 small screws in top (Torx heads) and clean out. Job Done!
May 02, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson will not stay on when i press the button.
OK...so while I'm sure that hitting the power button w/ a mallet will work...I was having the same issue and felt uncomfortable hitting my very expensive Dyson w/ a mallet.
Here is what I did to fix the problem I have a DC17...I am sure instructions will vary by model Here is what you will need: 1. flat head screw driver 2. Torx -15 screw driver.
1. remove the dust tank  2.Pull the extension tube (handle) out (as if you were going to  vacuum a tight area.  3. there are 2 torx screws that you will have to remove 4. there are 4 retaining clips that you will use the flat head screw driver to unlatch.   5. After you remove the torx screws and release the 4 retaining clips, the front panel (that houses the power button) can be removed.  6. This will expose the actual power button itself.  Most likely it was jammed. 7. Once you think you have fixed it...test out your fix. 8.  If fixed...reassemble
Dec 29, 2008 | Sharper Image Dyson Slim DC18 All Floors...
My DYSON DC07 upright vacum
the actuator in the switch is defective, you can replace just the switch. There are several places to get just the switch, just google "dyson dc07 parts" for places on where to get the switch.
Jun 22, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
64 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
