Question about Vacuums
In error I picked up a couple of screws with the Airo brush and now the brushes do not spin. What can I do?
  • 41 Answers
What happen is that there an impeller where the screw got stuck and block the whole machine.to remedy over turn your machine remove the brushes,their some some screws , remove the cover with precaution, after you will see the impeller,turn it end remove the screws and reassemble and start
Posted on Oct 02, 2009
Testimonial: "Thank you for the advice,it worked."
Motor runs but brush don't spin and belt is not broken
Two core baseline things to check. Brush won't spin if the handle is all the way forward (this is where the handle mode engages), so tilt it back before turning unit over to check the brush. Also, run the brush clutch back and forth between hard floor and carpet mode a couple of times and make sure the clutch is fully engaged. Hoping it might be as straigtforward as that (I just picked up a Dyson at a flea market, a really good deal since I couldn't get the brush to spin there. After some research at home, the above finally entered my sphere of knowledge, and no problems with the brush since (other than cutting large volumes of Labrador hair off of it).
Aug 27, 2015 | Dyson DC28 Animal Airmuscle Vacuum Cleaner
Henry hoover airo brush not working
yes, it probably is stretched.
Jan 07, 2014 | Vacuums
Brush won't rotate
Hi!!
Check belt, probably broken. it is located on one of the ends of the brush, you may need to remove a couple of screws to gain access to it.
Replacements can be found at Walmart, Home Depot, or an Authorized Kenmore Service Center.
Don't forget to rate this post. Good Luck!!
May 27, 2010 | Kenmore Progressive Bagless Upright with...
Brush roller not spinning properly
Yes there is a belt and yes it is easy to replace it. There are a couple of screws that hold the cover on and then you can just lift out the brush, get the new belt around the motor shaft and then around the brush. The new belt will need to be stretched tight but that is a good thing....
new belts can be purchased at many grocery stores or vacuum repair shops...
heatman101
Apr 29, 2010 | Hoover Commercial Windtunnel C1705-900...
Vaccum not turning or sucking
It definitely sounds like your belt is broken. If something gets vacuumed up into the brushes, and prevents the brushes from spinning, the motor will continue to try and spin the belt and the brush, but since the brushes can't spin, this will burn right through most belts.
Especially since you mentioned a sock being sucked up, and the roller brush not spinning, this is a tell tale sign of your belt needing replacing.
Here's what you'll need to complete this repair:
- Phillips Head Screw Driver
- Hoover Windtunnel Replacement Belt, Non-Self Propelled, Hoover Part # 38528033
- Depending on how long the sock was stuck in the brush, you may need a new roller brush as well. The roller brush for your model is Hoover Part # 48414110. Here's a direct link for the roller brush for your vacuum on our website:
http://www.govacuum.com/generic-hoover-windtunnel-tempo-fusion-upright-12-inch-replacement-roller-brush-hoover-part-number-4.html
If you have the Hoover Tempo Widepath vacuum that you listed the repair under, then here's a direct link back to our website, govacuum dot com, to the exact belt for your Hoover Tempo:
http://www.govacuum.com/agbelhoovpar9.html
Now, once you have a new belt, this repair is pretty straight forward. I'll explain step by step what you'll need to do to change the belt.
Step 1. Make sure your vacuum cleaner is unplugged. The easiest way to change the belt in your vacuum is to turn the machine upside down, so the handle is on the ground holding it up, then lean the vacuum over a counter top or work bench.
Step 2. Remove the bottom plate of your vacuum cleaner. You'll see on the bottom of the vacuum 4 screws that are located on each corner of the brush, remove all 4 screws, and lift up on the bottom plate that covers the roller brush.
Step 3. After removing the bottom plate, you should now be able to access the roller brush completely, and you'll probably also notice that the belt on the right side of the roller brush is broken. You may just remove the broken belt completely and throw it away. Lift straight up on the roller brush itself to remove it from the vacuum.
Step 4. Test the roller brush. After something gets stuck in the brushes, and it causes the belt to burn, there's also a good possibility that your roller brush may need replacing as well. Also the roller brush will wear down over time, and the brushes will wear down as well, greatly reducing the cleaning ability of your vacuum. You'll want to test your roller brush, to ensure that it spins freely. If it doesn't, then as you install the new belt, it's possible it could also break immediately. To test the roller brush, remove it completely from the vacuum. Holding just the end caps of the bar with your fingertips, try to spin the brush in your hands using your thumbs. This is how it should look when you test your brush (the roller brush is to a different machine, but testing it will work the same):
The roller brush should spin at least 3 or 4 times in your hands on each spin. If the brush will not spin at all, or you feel some resistance when spinning it, then you'll probably want to go ahead and replace the roller brush as well at this point.
Step 5. Once you have your new belt, and new roller brush (if needed), it's time to install them. First wrap one side of the belt over the metal motor pulley in the back of the vacuum, opposite the roller brush. Now after you have one side of the belt wrapped around this metal pin, put the roller brush through the other end of the belt. Using the roller brush as leverage, stretch the belt with the roller brush inside of it back into the roller brush tray. You'll notice that on the left bearing cap on the end of the roller brush, there's a little rectangular shaped notch. Make sure that the rectangular notch is vertical, and slide this end into the agitator housing first, then fit the other side (circular notch) into the housing. With a little bit of elbow grease, you'll be able to stretch the brush with the belt back into place.
Step 6. Test the belt and the brush before putting the bottom plate back on. To make sure that belt and brush are properly installed, pull the belt forward towards the brush, and make sure that the brush spins while you're pulling the belt. If the brush does not spin, then either the belt is pinched underneath of the roller brush, or the brush is bad / installed incorrectly. Make sure that the brush spins freely before reinstalling the bottom the plate, otherwise the belt will burn and break again as soon as you turn on the vacuum.
Step 7. Reinstall the bottom plate, and screw down the four screws. Now you can turn the vacuum on, and make sure that the brush is spinning. If the brush is not spinning, repeat the steps above to make sure that the belt and brush were put in correctly.
That should fix your problem. Ideally you should change your belt at least once a year. Even if the belt doesn't break, it will stretch out. When the belt is stretched out, it will not pick up as well as a new belt will.
If you have any problems, or questions about how to do it, please feel free to use the Clarification Request here on the Fixya repair page, and I'll be more then happy to answer any follow questions for you.
Here's a link to the owners manual for your model that will also give you diagrammed pictures of how to replace your belt.
http://www.hoover.com/pdfs/manuals/U5140900.pdf
If you found this repair helpful, please be sure to rate this repair helpful by clicking the thumbs up icons. This small token of appreciation keeps Fixya repair experts continue posting free repairs to help the community. Thank you very much, that's greatly appreciated.
Chris J.
GoVacuum
Apr 07, 2010 | Hoover Tempo Widepath Upright Vacuum -...
I have cleaned & cleaned this thing! It runs for about 2 mins & stops, says "Clean Brushes"! and now it's very noticeable it's not picking up well... but is picking up a bit. I take the dust bin...
Ok, this is a "Brush Height Adjustment" issue. It will probably work great on a hard surface but on carpet the brushes bog. If you've taken the unit apart already...Sorry....do it again. When you do, you'll see a String which allows the brushes to "Float" on different surface heights. Loosen the screw a little and pull a bit more string through. Re Tighten the screw and put it together enough for a test run. Now reset the roomba.To reset the Roomba, power the Roomba on, and press the Spot, and Dock buttons together for at least 8 seconds. Until it plays a tune. The clock, and any schedule is erased at this time. Try running the Roomba with the dust bin removed to see the brushes spin easier.
Second method, is taking off the bottom cover, and removing the battery. While it's removed, and not plugged into the charger, press the clean button for at least 20 seconds. This will erase the memory. Replace battery, and cover. Run the Roomba to see if the brushes start to spin. You can also remove the brush housing by removing the 4 screws and reseating it, to see if it was a bad connection, since you have the bottom cover off.
Mar 26, 2010 | iRobot Roomba 560 Robotic Vacuum
The brushes at the bottom wont spin round or pick anything up?? help
the belt needs to be changed. to replace the belt remove the screws on the bottom of the brush housing and you will see hte belt, make sure the spindles that the belt goes on are clean.
Oct 28, 2009 | Vacuums
The bottom brush that spins around is not moving anymore
The belt that drives it has probably broke,If you can remove the head on that model remove it and replace the belt . You make have to access the belt by removing the screws from the bottom of the power head.
Aug 18, 2009 | Vacuums
In Carpet setting, the vacuum brush does not spin
I put 3 turns of electrical tape around the area of the beater bar that meets the vacuum belt. This solved the problem short of replacing the beater bar.
Jan 18, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Samsung jet propel 1800w power clean vacuum not sucking in/picking up on main front edge roller whilst the hose / attachment does have plenty of suction when taken out of its dock
Just had the same problem. Turns out to be the belt that spins the brushes...
Check to see if the brushes are spinning, if not, undo the four screws on the plate over the brushes and the belt is easy to get at. Replacement should be available in any spares store.
Jul 05, 2008 | Samsung Vacuums
Vacuums Logo
35 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
