LG Clean master 1021wh model 7.0kg washine machine not draining and in hold mode... Door locked. I have cleaned out pipe
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Check /clean filter
Posted on Oct 02, 2009
MY washer fills, sometimes stops without completing the wash, sometimes it shows a completed cycle but the clothes are too wet to dry, sometimes during a cycle it will turn off with the door locked.
Sounds like a draining problem - Check the drain filter isnt blocked, if fitted before doing anything else - remove the filter and clean it. Then, can you hear the drain pump running on the drain cycle (drum not moving but pump should be) - a chug chug chug noise and water should be flowing down the waste pipe. Door WILL lock if the machine is full of water or is slow to drain - to prevent floods. Do NOT force the door open without draining - you will only break the door handle.
If water not flowing on drain - and filter clear - may be blocked pipe, sock stuck in sump hose - coin or counter flipped on edge in a pipe and blocking it - something like any of the above. Clothes too wet to dry is classic partially blocked drain pipe symptom - or spin aborted as drum out of balance.
Feb 01, 2018 | Washing Machines
Water draining problem
remove the pump and clean out the spindle it's a magnetic motor and hair etc can get logged in the motor inturn slowing the motor down, its just 3 screws holding the pump cover top on, blowing down means there is something in the way as well this can be in the filter housing
s-l1000-v3m3v51i33m4hqmvscjwnkwd-2-0.jpg remove from the lower part of the washer, lay washer down on side to gain access, lay on left side as looking a washer and you will have some water come out so have cloths handy, remove the pipes and fixing plate, and remove the filter cap before removing.
Dec 21, 2017 | Washing Machines
LG washine machine starts to makes noise when its starts to spin, how best can i be helped
Hi yawkentikron,
I believe there is something in the drain pump rubbing against the impeller, this needs to be cleaned out.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | LG Washing Machines
My LG washer shoes OE and I don't know what to do??
If I'm not mistaken this is a drain issue so check to make sure nothing has your drain hose kinked or clogged. There is also a drain filter that you need to check and clean if needed. There is a small door cover on the bottom fron of the washer. First pull the tube out a little and hold it over a container then remove the cap. This will drain the pump and when no more water comes out you can remove the drain filter by turning the cap thats next to the tube you just drained. Sometimes there is still a little water left so you may have to clean up a little but not much. Clean the filter if needed and you can also look in the pipe to see if any debris was left in the pipe. Place everything back and this should get you back to doing more laundry.
Nov 08, 2010 | LG WM1814CW Front Load Washer
LG Intellowasher (Model WD-1023C)
The water pump can be blocked and thus stop the machine from finishing the wash cycle. In front on the bottom there is as hatch that can be opened with a flat screwdriver, the small black rubber pipe can be used to first drain all the water before the opening the filter. Small objects such as coins coluld be found in here, blocking the pump. Clean the pump by removing these, optionally blowing into the outlet (yuck!), to dislodge anything. If that does not help to fix the problem, you can clean that actual water pump, but this requires you to use a screwdriver to remove the pump.
Tilt the machine on its side, the pump is attached with 3 self-tapping screws. (if you can't figure out what the pump is you should probably let a technician do this). The pump has 2 parts to it, take it apart carefully and clean out all the dirt that has accumulated in there. Plastic friendly, waterproof grease can be applied to the pump spindle and bearing if available.
If the problem still persists a new pump is available from LG at a reasonable cost.
Jul 30, 2010 | LG Washing Machines
Homemaker HMWM8000 shows E2 error and will not pump out water
Maybe just a blocked filter?
If the waste pipe is clear and nothing in the filter, the pump is worn or faulty.
Remove waste pipe and lay it flat on the ground to drain.
Hope this helps
john
Aug 27, 2009 | Washing Machines
Whirlpool 6sence washin machine problem
Probably a faulty door lock mechanism. Since you live near the ocean there could be corrosion in the harness connections. I would clean them real good with contact cleaner.
Apr 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The door on my front end Whirpool Duet Washer will not open?
Plug off the mains. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
For some front loader models after removing the panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment.
For the door to unlock, press & hold 'end of cycle' for 3 seconds, power shd be on for this, try door after 2 minutes. Your machine may not open if there is water inside, so first drain.
Apr 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint WD440 1400 Spin
There has been an unbalanced load and the machine could not spin
(see ‘Automatic Features’, Starting and Programmes).
Has the drain hose been installed correctly (see Installation)?
Are the drain hose, standpipe or undersink connections blocked?
Has ‘Rinse Hold’ option been selected? If so press the Rinse Hold button
drain hose make sure there are no kinks and the end is over the top of washer to drain this ensures that there is no back flush with drain pipe
clean the dispenser drawer regularly
Clean and dry the dispenser
drawer, syphons, grate and
fabric conditioner exit channel
(A). Also regularly clean the
outlet pipe area
Never force the machine door: this could damage
the safety lock mechanism designed to prevent
any accidental opening
May 21, 2008 | Hotpoint Aquarius WD640 Front Load...
E21 error code
Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin lights should light. Any error codes should be displayed when holding those keys.Your pump is clogged up.Remove the 2 hoses from it & clean out any debris
PLEASE RATE THIS !
Apr 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
