Question about Hitachi 43UWX10B 43" Rear Projection Television
I have a Hitachi 43 " projection tv. There was double image in green and purple. I was able to fix it manually. The auto focus would not work. Now the problem is the appearance is curved at the top and bottom, when I try to adjust the verticle from the menu it will not let me, that option is in gray and skip over it in the choices on the menu. Is there a way to unlock this so I can adjust.
  • Hitachi Master
  • 5,138 Answers
Pull front bottom panel off of TV on convergence board where ICs are in Front of board is a setup switch Small blue contact switch Press and hold untill convergnce Pattern appears Now aline convergence, you must have you hand unit that came with TV.
Posted on Oct 02, 2009
The picture has colored shadows and doubled images. People are doubled shadows are red green purple. I would like to know if it worth fixing the tv is about Ten years old. Thank You
In a nutshell, the convergence ICs have failed. The cost to fix by a service company is likely about $300. You may find someone who does it on the side for around $150.
If you are happy with the picture, you like the tv, then $150 might be worth it.
It is possible to do this repair yourself if you have an electronics background.
Feb 18, 2011 | Hitachi 43FDX15B 43" Rear Projection...
Red, green and blue colors don't match up on screen.
Please replace convergence out ICs (usually two) in TV.
If it is Hitachi 43UWX10B then its convergence out ICs are available in Part Store
Thanks.
Aug 24, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Words are doubled red borders???
Just to clarify, it sounds like what you are saying is that the image appears to duplicate in either red or blue along the edges of the image (especially white lettering and probably increasing along the boarder of the TV). This is resolved by converging your TV. Convergence will drift normally on large screen projection TV's over time or through moving them. The Hitachi 57f500a has a feature called "Magic Focus" (pg 36 in your manual) which will auto converge the image. If the auto converge feature doesn't work, on page 37 in your manual, it explains how to converge manually. If you do not have the manual, I have the image of the pages below. If for some reason this doesn't work, please provide additional info and detailed prior to rating the help.
Apr 20, 2009 | Hitachi 57F500 57" Rear Projection...
Hitachi TV HELP!
Hi, magic focus button is behind a small door on the front of the set just below the screen, I don`t think it is going to help I believe your convergence IC`s have failed,try pushing it once and let it finish, if still 3d image you need to call a tv tech, good luck, video-tek
Feb 09, 2009 | Hitachi Televison & Video
53 Hitachi Rear Projection TV with shadows and double images
Does the magic focus work on your set ?
If it doesn't you must replace the convergence Ic's with a kit that is available through your local parts distributor
You must replace all resistors in the kit
If you are not good at soldering and de- soldering have a local tv shop do it for you
Good luck
Jan 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Double image/ out of focus with green and blue seperation
Your tv is crt-based and is out of convergence. In other words, the settings for keeping the Red, Green and Blue images aligned have drifted and must be reset. This is common with CRT projectors and CRT rear projection tvs.
Refer to your owners manual for instructions on re-aligning it.
Apr 18, 2008 | Hitachi 51UWX20B 51" Rear Projection...
Hitachi TV Problems
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 23, 2007 | Hitachi 43F300 43" Rear Projection...
It needsre- align the projection bulbs to get rid of the double image
More than adjustment...needs convergence circuit IC's replaced.
STK392-110 subs to upgrade STK394-160E Hitachi CZ 01341..
then use magic focus........................................T.
Dec 17, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
151 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
