Question about Garmin nuvi 780 GPS
The NUVI 780 tells me it is currently locked and to unlock slid the button to the left. However, this does not unlock the system.
  • Garmin Master
  • 2,130 Answers
Most likely the switch is bad. Do you feel it click when you put it back to the center position? Is it in the center position? How does the switch work when you use it to turn the unit on & off? That switch has (2) sections to it.... one for on/off and one for screen lock. It's possible 1/2 of the switch is bad. I've replaced them before.
- Jim
SHARCNET-USA
Posted on Oct 02, 2009
Unable to unlock Nuvi 780 screen. The slideing button on the top left dosen't work, it lost the grip and just move on either direction with out any action. Please help
Try to remove the battery and re insert it back in to see if it will work. Or hold down the power on/off for about 15 seconds, that should do the job.
If that does not do it, then you have to calibrate the screen. To calibrate the screen, follow the steps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
That should do the job for you. hope this helps.
Dec 24, 2010 | Garmin nuvi 780 GPS
I have used Garmin Nuvi 780 for the last one year. But recently the message of "requiring pin #" pops up. I don't have a pin #. What shall I do?
If you have a Garmin Lock on your nuvi, zumo or StreetPilot c500 series and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device.
If you have forgotten your PIN and Security Location please contact Product Support for assistance. Please note we will require a copy of the receipt and there will be a charge to unlock the device as this issue is not covered by the warranty.
To contact Product Support in your area go to http://www.garmin.com/garmin/cms/site/us/support/supportcontact
Oct 20, 2010 | Garmin nuvi 780 GPS
My garmin nuvi 780 is lock how do i unlock it
my nuvi 760 has locked me out, how do i get back in
Apr 09, 2010 | Garmin Nuvi 760 Car GPS Receiver
Unlocking my 780 garmin
Hello. Carefully lift the frame around the screen using your fingernail. Under that frame is the reset button. Push it and you are good to go. Regards, Joe
Dec 22, 2009 | Garmin nuvi 780 GPS
How to unlock password for garmin 760
Your only options for unlocking a PIN locked Garmin are:
1 - Enter the correct PIN
2 - Take the unit to the location at which the PIN was originally entered
3 - Send the unit back to Garmin.
Dec 12, 2009 | Garmin nuvi 780 GPS
My Garmin 780 asking for a unlock code
Mar 28, 2009 | Garmin nuvi 780 GPS
Nuvi 200 Cannot unlock maps, it says
To answer your first question: The screen is currently locked. Slide the power button all the way to the left
For your general question, a Google search for "nuvi 200 instruction manual" produces 43,000 results
Jan 22, 2009 | Garmin nuvi 200W GPS Receiver
Your answer to my nuvi 780 stuck loading maps
Check out this link, good luck!
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=95274&whichpage=5
Jan 10, 2009 | Garmin nuvi 780 GPS
Nuvi 780 stuck in "loading maps"
On the back of the unit there should be a reset button, press this in till the unit starts to turn on again.
~Phil
No reset on my Garman!!!
Try holding the power switch to the left for 8 seconds, then switch on (soft reset). If that doesn't work, try a hard reset; remove the SD card, hold the bottom right corner of the screen and keep it pressed while you switch the power on. This resets all user data, but if you haven't used it yet, it won't be a problem. Good luck
Jan 09, 2009 | Garmin nuvi 780 GPS
Garmin nuvi 780 GPS Logo
134 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
