Question about Refrigerators
Removing fridge door panel
Removing fridge door liner panel
    President:
  • 1,304 Answers
Look behind the gasket, there should be 32 1/4 in screws
Posted on Oct 03, 2009
Water pooling and freezing in lower freezer, whirpool gold french door? How do I rmove liner in fridge to follow line?
Sounds like a clogged drain. Remove food, remove bins and shelves. Remove ice maker if freezer is in the bottom. Remove back panel. .melt ice on drain pan and run hot water into drain.
Feb 14, 2015 | Whirpool Refrigerators
Mzd2766geb maytag ref freezer door insulation frozen solid with ice
Even if the unit if issue free, this older design is still suseptable to moisture intrusion behind the inner liner. If your ice is below or around where the fointain area is, than you may be leaking water from the fountain behind the outer door shell. Since your outer door and inner liner are no longer avail, the best suggestion is to turn the entire fridge off, and let everything completely dry before re assembly. Once insulation gets imbedded with moisture and freezes, the insulation factor diminishes. Although your outer door insulation should be the newer style semi solid foamed in style, so moisture intrusion will not be any deeper than an inch or so. If the fountain heater has failed around the dispenser, you attract moisture to that area too. Pleazer Appliance...
Jan 06, 2015 | Maytag MZD2766GES Side by Side...
Remove rear passenger door panel Mercedes ML350, 2005
Open crank window.
Remove cover for door handle and unscrew 2 screws.
Unclip SRS panel and unscrew screw.
Press door liner off bottom, fron and rear inner door panel with wedge.
Lift door liner up and out.
Unhook inner door actuator.
Unclip inner lock on door liner.
Remove lamp.
Sep 24, 2013 | Mercedes M-class Ml Ml350 Ml500 Ml55...
Want to remove freezer liner on a magic chef rb150 frig. I'm a retired refer man but these new plastics got me wondering. Need to get to the evaporator.
You must remove the doors and all screws in the hinge bracket holes. Also remove 2 torx screws at the front/top of the fridge compartment. The liner then slides out toward the door.
May 29, 2011 | Refrigerators
The door liner is cracked and broken the the fridge works great i would like to replace it where do i get a new one
Door rubber gasket is available with any fridge dealer retail shop. And also easy to replace.Below the gasket there are screws. Unscrew and fix new rubber gasket after removing existing one. If you can't call repairman. Matter of 2 to 3 hrs job. Thanks.
Jan 23, 2011 | Refrigerators
I have water in my refrigerator on the shelves and in some areas it is freezing?
Could be a clogged condensate drain. Since you did not give a model #, I will assume this has the freezer on top. When it goes into defrost, the water cannot go down the drain hose to the drain pan and accumulates as ice in the freezer, below the bottom liner and may drip into the fridge. Empty the freezer and open the fridge door. The open fridge door can help thaw the drain. Remove the screws holding the bottom of the freezer liner and remove the liner. If there is ice below it, the drain is clogged. Remove as much as possible by hand and then use a hair dryer to carefully melt the ice at the back of the freezer. Blot up any water from the melted ice and concentrate on clearing the 1/2" hole in the center back. That is the drain. When you think the drain is clear, check it with a large glass of hot water. This can be take some time. When done, reassemble, but also make sure the fridge is tilted to the back by adjusting the legs at the front bottom corners of the fridge. You may have to take the grill off the bottom of the fridge to do this. The legs screw down to lengthen them. Adjust them far enough down that the fridge door swings shut by itself. This will help the water down the drain before the fridge comes out of defrost, starts cooling and freezes it in the drain hose.
Mar 03, 2010 | Whirlpool Refrigerators
How do i get a dent 2 by 4 out of the fridge. there really isnt any scratchs but just a dent. can i some how get it out with out having to replace the hole stainless steel door
there arent any real solutions outside of some auto body repair shops have a suction cup dent puller that might help. most of these doors have a molded foam isulation inside that prevents you from getting to the inside of the door panel to push a dent out. even if you could it would be a rough job . you would have to remove the inner door liner including lots of screws, if the inner door liner isnt molded to the outer door panel. so unless you know someone that works in a body shop, the only real option is to replace the panel, which wont be cheap and i would suggest having a tech install it because if you damage it while installing it, that would be on you and the parts company probably wouldnt replace it for free. Good luck!
Dec 17, 2009 | LG LSC27950 Side by Side Refrigerator
Change out refrigerator door gasket
Hello D Lassiter, You can do this repair yourself with just some basic tools and a little patience and assistance.
You'll need to remove all food from the fridge as it will take at least 45 minutes or longer, depending on how well you do.
If you roll back the door gasket, you'll see the fasteners that hold the gasket in place. Remove these starting with the ones on the bottom edge and then the sides. Finally, remove the top ones, leaving the two top corners for last, that way you can have someone help hold the door liner, so it doesn't drop to the floor and get damaged.
I would also suggest that a day or so before you're going to do the repair, that you let the new gasket lay out on a floor somewhere where it can't get damaged so it will relax and get most of the kinks out of it from shipping, etc.
Then simply put the gasket onto the door liner and reinstall all the screws back onto the door frame.
There are some models (you didn't provide a brand or model number to zero in on the exact version you have) that have the door gaskets glued onto the door frame. On this types, you'll have to use either a plastic or metal putty knive to gently run around the entire edges of the door, between the gasket and the door frame, to get it to come off.
Then you'll need to have someone help you reinstall the new one, as you'll have to reglue the gasket onto the door frame. This will require some non-marring clamps (about 4-6) to hold the inner door panel and gasket onto the outer metal door frame, while the glue dries. Typically, this is done with the fridge door removed from the fridge and takes at least a day once it's installed to glue in it place and fully cure.
In either case, please go to the link below and enter in the model number of your fridge so you can see which type you have and get a line drawing that shows the replacement parts you'll need. You can order them anywhere you wish, it's just very convienent that Sears provides the info for just about all brands of appliances made.
You can find your gasket part at www.searspartsdirect.com by entering in your model number for your unit and looking at the drawings and parts list provided.
You might have to look under the inner door panel edge, hence the reason to look at the middle section or corners to make this a bit easier to do. You might have to remove the inner door panel from the gasket first, in order to get at the screws that hold the gasket onto the metal door frame.
Don't pull on the inner door panel too much, as you really don't want to crack or break it, since your goal is to only remove and replace the gasket. Take your time and you should be able to get it off and replaced.
Of course, don't remove this until you've got the new one available and then allow plenty of time to do the job, which means getting the fridge and freezer emptied completely, so have plenty of coolers available with lots of ice!
I hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 14, 2009 | Roper Refrigerators
I want to remove door handle to replace broken fixture.
I think you may have to remove the door gasket, if you look behind the gasket you will see the screws holding it and the inner door liner in place, both should be removed and you will then have access to the handle screws from within the door.
May 27, 2009 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Whirlpool ED5VHGXML10 Side by Side Door shelves cracked
HI thanks for your question. its the door liner, that's broken, if you can repair with some epoxy puddy, only problem with epoxy puddy , it smells. so the door liner is to be replaced. thanks the appliance doc. please rate my answer. thanks.
Oct 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
137 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
