Ya.......
Exactly only follow those steps.
Ok ...I see that ya displayed the memory series instead of the computer of mother board so that I could verify what compatibility and slots available ya have on the pc ...board..
anyway supposing that ya have an extra-slot ..and you bought the right kinda memory ..there are a few things that might worth thinking to ...
1 ...the memory have to be the same like the other ...I mean if you have ddr and ddr2 slots ...most computers support only one type at the time ...so ..if you was thinking in adding a ddr2 and keep the old ddr one ..forget about ....
second...to be sure that will be no problems the newly added its better be the exact frequency like the other .....I mean the speed...if its on 533mhz ...the other better be the same ...and so on
in what it regards the installation ..yes its as simple as it sounds...just open .,...insert carefully by pressing constant and gentle ..into the slot ...see that it has to locks on the sides..and do not handle the unit by the bear hand...just take it from the ends,,without touching any parts on it ...cause I understood there are very sensitive ...and its an issue with hand moist ..and magnetic field..or so ...
the last part is that you probably will have to remove the bios battery in order to recognize all mem..or at least to bring the settings top the optimal defaults ...but ...I had some issues sometimes that it would not want to boot at all ...and thats why I said to remove the battery ..cause if you dont boot ..you can not change settings but this way ...
remember that it might as well just boot without problem from the first time .....or not boot at all ( in case remove battery ) .. or boot but not read the new unit ...in this case remove battery ..restore time and ...etc..and reinstall operating system ...
anyway ...in all cases you better reinstall the operating system ..in order to make it recognize and take in all full features the newly installed unit and work at full capacity ..
Good lick ...and prompt me if you have answers...dont be scared..I have a way in complicating things ...it looks more complicated that it is ...in sort ..insert...rem battery ..reboot...and reinstall
