Question about Black & Decker Ba - 075 Side Bag Assembly
I can not find how to attch this. The shoot is
For the Black and Decker electric mower(MM-675), side bagger attachment (BA-075), I can not find how to attach this. The shoot is self explanitory but where does the pole connect to the mower?
  • 22 Answers
SOURCE: I have Black and decker electric lawn mower does not start
one of the problems i found with electric detectors was that they do not tell you if there is a break in the neutral cable so you could have a break there,another problem is that the levers can break inside the cover giving the impression that it should work but is not making contact with the switch ,hope this helps
Posted on Mar 30, 2009
  • 18 Answers
SOURCE: Black and Decker 18 inch electric lawn mower turned off
Try the link at the bottom of this page : "Find Manuals".
Posted on Jun 11, 2009
  • 52 Answers
SOURCE: Black and Decker Electric mower #M2370 lever
you could just try drilling the case out where the lever pivots and put a long nut and bolt to hold the lever in place
Posted on Apr 15, 2010
  • 52 Answers
SOURCE: Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
  • 52 Answers
SOURCE: 19" black and decker electric mower just quit!
check the brush on the motor the one with the black wire usally wears first
This item is discontinued by the manufacturer. Is there another bag I could use with my black and decker LM175?
if the manufacture doesn't have or recommend a replacement, either buy another lawn mower or get a really good mulching blade... a gator blade or similar
Oct 19, 2014 | Black & Decker Ba - 075 Side Bag Assembly
Where to buy
I would imagine their website would be a good place to start. Maybe then eBay or Amazon once you get the manufacturer part number
Sep 16, 2014 | Black & Decker Ba - 075 Side Bag Assembly
How do i replace the battery on my craftsman mower
You will need to remove the back bagger mount to get to the battery at the back base of the mower deck and the bagger mount is in the way.
Start at the side shoot and then work you way back to the bagger mount. The battery should be under the black cover.
The battery is located in the back cover between the rear wheels.
I hope this will help.
Jul 17, 2014 | Garden
No start on a mm 1800 18"
check the cord for cuts then check the safty engagement on the handle and make sure it disengages to cut thats about all you can do turn blade make sure turn freely not plug in after you will have to take it in
May 31, 2014 | Black & Decker Black and Decker Mm575 18"...
Black & decker MM 850 Electric Lawn mower/mulcher. Upon start up, there is major vibration. No way I can run it like this..
Try removing the blade. If the mower runs smooth, replace or balance it.
If not, the mower shaft may be bent. Did you hit something hard with the blade?
Gary
Aug 11, 2011 | Black & Decker 19" Electric Lawnhog...
I cannot remove the blade from my B&D MM575 mulching mower. The manual says to block the blade, then loosen the nut. However, when I block the blade and turn the nut, the shaft continues to turn,...
You can use a pipe wrench on the shaft and a regular wrench on the nut. Disconnect your spark plug and tip the mower onto it's left side. You will have to use your left hand to go down through the mower shoot to hold the pipe wrench and your right hand to unbolt the the blade attaching bolt, it should come off immediately.
Remember you may have to purchase a new blade holder, since your problem shouldn't occur if your blade holder was OK. GOOD LUCK.
Jul 28, 2011 | Black & Decker Black and Decker Mm575 18"...
WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER MM 850
looking down at the terminals, rotate push-button to the right. the wiring sequence is R, W at the top, then Black (in, from power source) , Black (out, to motor).
Sep 27, 2009 | Black & Decker 19" Electric Lawnhog...
Saw your post about Black and Decker MM525 Lawn Mower
Most lawn mower mfgs offer a mulching kit which usually consists of a metal plate to block the discharge opening and a mulching blade which just has a longer sharpenned cutting edge.
With a little labor you can make your own.
Johnww1422@aol.com
Apr 19, 2008 | Black & Decker 19" Electric Lawnhog...
2 way switch,
see dewaltservcienet.look for search info.type in model #
Apr 05, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker Ba - 075 Side Bag Assembly Logo
61 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
