I have an american top loading style washing machine, and it is a few years old now.. its started leaving a brown streak on my white clothing in wash cycles. I have tried hot rinses without a load, bought special cleaning products to run though, and nothing seems to work. Have you any suggestions?
    Genius:
  • Washing Mach... Master
  • 1,466 Answers
Check water inlet pipes /clean filters at this point.could of course be bearing trouble which would leak oil and be noisy on spin
Posted on Oct 02, 2009
White streaks on dark clothes
The white streaks are of soap build up on your machine tub. You can get ried of that by putting cascade dish washing soap in your washing machine and run full cylece , with out clothes.
Apr 13, 2013 | LG WT4801CW 3.7 cu. ft. top load washer
Tip
With only two fairly clean adults in the house, I use the front loading Kenmore...
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
on Apr 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I get brown streak type stains on my clothes regularly. They are about 1 to 3 inches long and orange-brown in color. They are very difficult to remove. I have a 5 year old Kenmore Elite top loading...
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore top loading washing machine does not clean clothes well.
I would seriously consider getting a newer machine. A brown stain could be rust, or an oil leak. Either way it probably is not worth putting any money into. If this helps, please rate my answer. Thank you.
Jan 07, 2010 | Kenmore Washing Machines
My front load kenmore leaves faint dark streaks in
look carefully inside the tub, gasket, lid. There may be some debris of some sort stuck somewhere causing this problem.
Then run the machine adding only two cups of vinegar. this will clean it.
Aug 20, 2009 | Washing Machines
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Jun 06, 2009 | Kenmore 44102 Front Load Washer
Brown streaks on white clothing in front loading washing machine
more than likly it is coming from the dryer. get a paper towel or a towel and run it between the inside of the drum and the front where they come together. stick it through the slot and run around the drum. do the front then do the back see if you see the same streaks. and let me know thanks
Jun 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brown stains from wash machine
Hi!!! Your tub inner seal is worn off its a seal which protects the inner tub fron the transmission..Need a new tub seal..Good luckk..
Jan 03, 2009 | Washing Machines
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Washing Machines Logo
Top Washing Machines Experts
