Question about Philips Audio Players & Recorders
Philips mx5700d.Power goes in but no power from first circuit board.How can i get this repaired or could i buy a new circuit board.BigRons1
I bought a second hand one of ebay which was also faulty in another area and took the part out that i needed and replaced.A lot cheaper doing it this way then buying a new circuit board.Thank-you for your intrest.Ron.
Posted on Oct 05, 2009
I was watching my Philips tv model number 50pfl38507f7 then turn off I try to turn on again but don't work no more what can be to fixed what I need to buy for repair
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. ..
Jan 19, 2017 | Philips Televison & Video
Need help fixing Philips LCD TV screen that is dark on one side and flickering.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 29, 2016 | Philips Televison & Video
I need help with my television repair.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 19, 2015 | Philips Televison & Video
Philips tv jarred in drop
Tv's don't take rough treatment well,picture tubes and other displays break,circuit boards are easily cracked usually around heavy parts,that sounds like your type problem broken board,if the damage is not severe it may be possable a tech.can repair the broken copper traces but this is becoming more difficult with newer more densely packed circuit boards with thinner and thinner traces many are not repairable and even if a new circuit board is available from the mfgr.it will cost more then a new tv.Good luck
Feb 26, 2012 | Philips 27PT643R 27" TV
Picture pulsing, tv turns off and on
Sounds like a power supply problem, If you are competent with electronics, you may find some blown capacitors or resistors on the power supply board. Equally you can probably buy a new power supply board.
WARNING: the power supply board contains lethal voltages even when switched off and unplugged. If you are unsure what you are doing take it to a repair shop.
Apr 05, 2010 | Philips Televison & Video
Philips 28pt4523 tv - power on but no response to
check capacitors on power board if they are ok suspect is the tuner board
Mar 26, 2010 | Televison & Video
Philips 42pf9630/37a, Blink red LED 7 times, No Picture No Sound
7 blinks indicates a bad buffer board, usually I replaced the Y board and the buffer/s about $500-600 in parts. but before you buy anything open the set and look at the power supply if you see two capacitors that look swollen , bulging on top they need to be changed and may solve the issue. the power supply is middle top . If you are not wanting to repair it yourself then know that you do have some circuit board repairs needed.
thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 17, 2009 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Red light on my Philips tv goes 7 times
It's basically a common problem with all brands of flat panel TVs. Heat is the biggest enemy for circuit boards. And the flat panel TV generates a lot of heat.
The most common part to fail is the power supply board (Backlight Inverter Board) for the screen or the Main Power Supply Board for the TV itself. The flashing 7 times is a code for a technician look at a certain circuit path for the malfunction.
If you have some electronic experience and you want to repair it yourself, you can sometimes find a Service Manual over the internet for less than $20. It will have red light flashing codes, diagrams, schematics, and part number list. Cheaper than buying a new TV. :)
Aug 12, 2009 | Insignia 42" LCD Flat-Panel HDTV
I have a philips 42PF9631D/37 and it will power on and the light stay green the screen seems to light up but there is no pic or sound. Please help i love this TV
If you have eliminated other potential sources of trouble such as a missing input signal from cable or satellite box, you have a partial failure of the main power supply. If you have a later 2nd set, I would try that first to make sure there is a signal for the set to see.
The power supply assemblies are normally on separate boards from the main one and in a plasma set you may have two power supply boards; one that services all the lowre voltage needs and a high voltage supply for the plasma tube itself. If the latter one fails, you would probably still have audio but since both sound and picture are missing, the problem is likely in the main supply. Power supply boards can be fairly easy to find; look for boards that have larger components on them; cylindrical cases (capacitors) black blocks (chokes and transformers) and beefy-looking semiconductors. I would check with the mfr. to see if they have an exchange program or only sell replacement assemblies. Power supplies are fairly easy to repair with some techincal training so if you are forced to buy a replacement, don't discard the old one as there are smaller independent companies who will repair them for a few dollars less than replacement cost.
If you plan on opening the set to peer inside, please pull the AC plug overnight as there are dangerous voltages present for some hours after being without power.
Jul 15, 2009 | Philips 42FD9954 42 in. Plasma HDTV
Red light flashing on tv
My 37" TV Will not yurn on . The green light goes on for 2 seconds then goes off and red light starts flashing. What Repair/Part is needed.
Aug 31, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
284 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
