Question about Plumbing
Bath sink hot tap doesn,t turn open fully
Bath sink hot tap wont turn open fully
  • 119 Answers
You need to replace stem/cartridge assembly depends on the brand if it is a stem or a cartridge
Posted on Nov 15, 2009
I have a single faucet Koehler for the kitchen sink. Cold and warm water are fine. When I turn it to hot, there is a tapping sound and the water spits out instead of a steady stream.
Simply check to make sure the valve under the sink is fully opened. Or u may have to remove the hot supply to check if it clear if debris.
May 30, 2017 | Plumbing
How to bleed water pipes
remove the aerator from the end of the faucet where the water comes out and check there is no blockage or unwanted material. do this to both outlets. with the aerator removed open both taps and let the water run until all the air has come out. replace aerators if you wish.
Dec 16, 2013 | Plumbing
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
Sep 19, 2011 | Bosch 425HN NG Tankless Water Heater
I have a mixer tap in the kitchen sink. The hot water tap runs fine but I am not getting any cold water. I also have a bath downstairs and the cold water tap there is fine
You will have to turn off your water mains and strip your mixer tap. It is possible that the seal (if it is an older tap with a rubber seal) has become stuck or the threaded part that turns it has gone faulty. If it is a modern tap with ceramic seals, check the operation of the mechanism and see why the ceramic seal is not being opened.
Mar 26, 2011 | Microwave Ovens
The hot water is not coming out the tap in the bath,only slight dribble,it wont turn on fully also.
possibly some sediment caught in the cartridge or stem. put some water in a bowl or sink, turn the water off to the fixture, remove the cartridge or stem, flush the cartridge or stem in the water, check for blockage inside valve body, replace parts, turn on water.
Dec 05, 2010 | Home
Slow filling with cold water
Hiya,
this can be a water presure issue with your mains or maybe the inlet tap to your machine is not open fully i would surgest checking the connection tap is open fully & allowing the maximum amount of water through to your machine.. if you sink taps run slow then this would be a sign of your water mains presure needing attention.. presure can also be reduced by using water around the house at the same time as the machine is on for example running a bath, dishwasher, flushing the toilet etc.
Hope this helps
Apr 23, 2010 | Zanussi FJS1225W Front Load Washer
When I turn on the cold water tap in the Bathroom Sink the water comes out in a very slow drip or not at all, the CW bath tap is ok
Confirm that the shut-off valve under the sink is open all the way. If it is, then close it and remove the cold water tap. If this is a single handle tap you will of course have to turn off the hot water shut off under the sink too.
With the tap removed and a bucket and towel handy, open the cold water shutoff just a little bit. If water comes rushing out, the problem is obviously with the tap. You may be able to clean or repair it, or you may have to replace it.
Mar 19, 2010 | Home
Hi there, my hot water tap in the bath tub was working b4 but it's not anymore, but the cold water tap works in the bath tub. can you help me out please?
Was the tap shut-off very tight and the tap is turning but the main shaft may not be turning. Check the hot tap mechanism and compare it to the cold tap.
Oct 09, 2009 | Porcher 5535-254.___ Reprise Pillar Taps...
Thundering noise coming from hot taps,bath,sink taps...
Sounds to me like you need to have a water hammer device installed into your plumbing, I have only run across this just once before, the noise is very loud and very bothersome, you will need to contact a plumber and have him install a water hammer device into your system, also vibration dampers would probably help as well, if your water lines are running through floor joists and touching them, hope that helps
Jan 18, 2009 | Bosch Exxcel KSR34423 Refrigerator
Had new mixer taps fitted on sink and bath (water pressure was fine hot and cold before) but now have very low pressure on hot water. can anyone please help, as its taking 35 mins to run a bath.??????
can you check some other source of hot water? if the pressure there is ok?..if it is, then the problem is on the new tap that you fitted.
Jun 27, 2008 | Heating & Cooling
Plumbing Logo
772 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
