Question about ASUS Computers & Internet
Has vista on it, i need to put xp pro on but xp wont install after i deleted vista partistion
    President:
  • 1,653 Answers
You will need to recover the Vista partition or reinstall the Vista partition from scratch then follow the info contained in the following link article
http://windowssecrets.com/2008/02/14/01-Make-your-computer-dual-boot-Vista-and-XP
Posted on Oct 02, 2009
I have purchased an hp550 computer with the Vista operating system. i wish to downgrade to the win XP operating system. how is this done ?
Greetings.
There is no direct path to downgrade Vista to XP. You can’t simply insert the XP installation CD media into the CD-ROM drive and hope to ‘upgrade’ and replace the Vista with Windows XP usual install routine because Vista won’t allow it to be overwritten. XP will treat Vista as ’superior’ operating system and refuse to install over it. There’re actually few options available instead of completely uninstall Vista as listed below. But if you decide to downgrade from Vista to install XP, there is also a simple guideline that you can observe to ensure that the migration goes smoothly.
Option 1 – Dual Boot:
It’s by far the easier and best method to run XP instead of Vista if you have another partition or hard disk. Simply boot up any XP setup media and install XP into different partition or hard drive than the Vista installation. Once completed, you can choose to boot up either XP or Vista, and has the best of both world.
Option 2 – Virtual Machine:
Install VMware Server or Virtual PC 2007 (both free) or any other virtualization software, and then install Windows XP into the virtual machine
environment. You will get XP which runs inside Vista, with minor compromise on speed, performance and have to go through Vista first on every bootup.
Option 3 – Format the Hard Drive, Wipe Off Vista and Install XP:
For those who totally fed up with Vista and just want XP, or prefer a clean installation of OS has only this option to rely on. To downgrade to XP from Vista, you have to basically delete the whole hard disk that installed with Vista, and start anew with XP. Here’s a simple guide and procedures that you can try to follow to switch to XP. However, each system configuration is different, so you may have to adapt the steps to suit your own need.
1. Download all drivers for your system for Windows XP from the manufacturer’s website(in case if you don't have the CD/DVD installers). Copy the drivers files to a USB flash driver or external hard drive or burn them to CD/DVD.
2. Find a Windows XP installation CD (should be pretty easy to find or else you can search in torrent sites such as Demonoid to download via BT network such as uTorrent and BitComet or search and download via ED2K network client such as eMule. You can also use Volume Licensing (VL) CD, retail (FPP) disc, or system builder hologram CD provided by Microsoft.
3. You will also need a XP product key even if you legally can downgrade from Vista Ultimate or Business edition. The Vista serial number won’t works with XP. (try to search for XP product key on web).
4. Backup to USB flash disk, external portable hard disk or CD/DVD every data files and any other things such as documents, downloads, pictures, movies, programs and etc that you need and want to keep. You can also create a second partition with disk management utilities such as Acronis Director or Partition Magic, and then move the data files to the new partition.
5. Ensure that also you have CD or DVD setup media for the software applications that you want to install and use after wiping off your system from Vista.
6. If your OEM doesn’t provide you with recovery CD/DVD discs and Windows setup media discs (it’s because they’re stored in the hard disk in hidden location), you may want to burn a copy of recovery CD to CD/DVD first before you proceed, just in case the hidden partition is lost and you want to recover your computer to original state. (How-to Guide: IBM/Lenovo ThinkPad recovery CD)
7. If the system has SATA (Serial ATA) hard drive, locate the driver for SATA controller and put it in USB flash drive, diskette or CD first. If you have PATA (normal IDE) hard disk, simply go to BIOS CMOS to disable SATA or Native SATA mode if you don’t want to install XP on SATA hard drive. Else, you can also create an XP install disc with the SATA drivers integrated by using tool such as nLite.
8. In the BIOS, also set the CD or DVD optical drive as the first boot device in the boot sequence.
9. Put in the Windows XP installation CD into CDROM drive and boot up the computer by using the CD. You probably need to press a key when prompted with “Press Any Key to Boot from CD…”.
10. If you’re using SATA hard disk with driver on external media (not integrated into XP setup disk), remember to press F6 when you see the message at the status base: “Press F6 if you need to install a third party SCSI or RAID driver…” during the very initial stage of setup to load the SATA driver so that the SATA hard disk can be recognized.
11. Run through the setup wizard at per normal. However, when prompting for where to install Windows Vista, delete (by pressing D and then confirmation), create and format the Vista disk drive or partition (if you have multiple partition). And then choose to install on that just formatted partition or hard drive.
IMPORTANT: If you choose the wrong hard disk or partition with data to delete, you will lose your essential data.
Note: If the setup does not allow you to delete or format the Vista partition or drive, you will need to find a third party software that can recognize and read NTFS filesystem to clear the drive or partition first.
12. Enter any product key for XP. Vista product key will not work.
13. If you own a legitimate Windows Vista edition that allows for downgrade (See Vista downgrade rights), call Microsoft after performing the clean install of Windows XP Pro to activate the XP installation. Notify Microsoft that you’re downgrading from Vista and require to activate XP Professional or other version allowed newly installed. You won’t get a new Windows XP product key though. You will have to read out the long Installation ID plus your original Vista serial key, and Microsoft will provide an activation ID that will make the XP usable.
14. Install the drivers for your system devices.
15. Reinstall any software programs that you want to use.
16. Move back the data files and documents.
Thanks
Nov 03, 2009 | HP Business Notebook 550
Trying to load xp on HP Pavilion p6144f desktop that has Vista on it. I run setup at boot and get fatl blue screen. If I try and run within Vista, I cant get install oftion. How can I put XP Pro on...
First boot computer with xp isk.
Then follow the procedure then delete all partition and create again .then install in first partition try this 3 to 5 times you can able to install/
Aslo refix your RAM memory check your winxp disk to that it is fine.
Let me know if you need more assistanse.
Thanks.
Sep 23, 2009 | Computers & Internet
Changing Vista to XP Pro on a Compaq Presario SR2180NX Desktop PC
SR2180NX has the Vista 32Bit OS from HP. The restore partition will always put Vista 32Bit back on if you use it. Windows XP can only be put on from scratch and I have done it while I still have Vista installed. One problem: there are no XP drivers under SR2180NX webpages. Do your research on the parts that are installed in the 2180 and any other HP machines that have the Windows XP operating system as the OEM OS. But First, check the Intel Site for the 945 chipset drivers (include the SouthBridge, too) under XP. Get them downloaded to a CD and burn the rest of the drivers you find for XP on the same CD. This way, you will have them ready when you are performing the down-grade to windows xp. After you are done with the XP install, you will still have access to the files & work you had done while in Vista. The Vista files are still readable. You might want to consider getting the Windows 7 Professional (not basic) available October 22, 2009. AND you will still have to get the Intel Downloads for Win7 any way, so why not make it a project and make it last for a few years. XP Support stops in 2014.
Sep 07, 2009 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
How want to downgrade win vista to xp pro hp compaq v3000
If you have a Windows XP Pro installation disk, put it in the optical drive, restart your computer, on startup, go to BIOS settings (usually press [Delete] and set the optical drive as first boot device. Save changes and exit. When the computer starts it usually says to press any key to start from CD. Press any key and the windows installation will start. Make sure you format C: and you will downgrade to Windows XP Pro. If you want to upgrade to Vista again, you will need to know the keyboard sequence to start Vista from Its partition or have Vista install disk.
May 25, 2009 | HP Compaq Presario V3000T Notebook
Modedm driver not installe
Vista or XP? below are drivers for XP..
this is the driver you requested
http://www.getpcmemory.com/goto/mdm_20080908152014_ZIP/1015/7
and here are other drivers in case you need them
http://www.getpcmemory.com/drivers/download-toshiba-satellite-pro-l300-notebook-windows-xp-drivers/
Jan 26, 2009 | Toshiba Satellite Pro L300 Notebook
Vista
if you do not have the installation disk you are out of luck, unless you can borrow some ones, removal of operating systems is reletively easy, to need to know which one your are currently connected with, going to the start menue and run the folowing click run, type %windir% and click ok, write down the folder that is open, do not touch that folder if you want to keep that operating system, otherwise your dead, go to microsoft website its all there for you to download and follow the directions, not to hard at all. good luck
Dec 23, 2008 | Microsoft Windows Vista Home Premium with...
Acer aspire 3680 PQSERVICE
if you have installed vista and change it to xp, you should first delete or reformat your current OS (Operating System) which I believe is the ur vista.
formatting OS:
-insert your xp disk then press F8
-click format or delete files ( i don't know the exact message that will appear on the screen)
-then install windows XP (just follow the instruction that you will see on the screen)
hope this would help you solve your problem..
thanks.. :)
Aug 22, 2008 | Acer Aspire 5610-4648 Notebook
Reformat Of Acer Aspire 3680 Help
If all you need is to format the disk
  1. Insert your XP disk
  2. reboot you machine after cancelling all the installation set up details
  3. Follow the instructions that follow as if you are installing Xp afresh (install, Accept terms,) then choose drive to install XP on (the one with current XP or else others) press delete (D) and follow the instruction to accept
  4. After deleting choose Install XP and chose to format your disk the way you want Fast/Slow to FAT/NTFS
Please note formatting is deleting everything (EVERYTHING) on that disk preparing to store new information as a blank HDD i.e. you will lose everything on the disk viruses, bad stuff and all your valuable data on it
Mar 24, 2008 | Acer Aspire 3680 Laptop
Remove Vista OS and Replace With XP Pro
1. make sure your laptop is set to startup from a cd
2. after laptop finds the bootinfo from the cd and asks you to press any key to start from cd, press any key and xp setup will start.
3. in xp setup your going to need to delete your vista partitions, preferably all partitions and then proseed to install xp into a new partition.
4. proseed with the windows setup follow the instructions and configure your settings as you wish.
Mar 17, 2008 | Acer Aspire 5100 Notebook
Downgrading to xp
You did this right:
1.Boot from XP disk
2.Deleted partitions
3.Installed XP on the new partition
4.Installs but then wont go through the rest of the process?
Thanks,
Cam
Oct 17, 2007 | Microsoft Windows Vista Business DVD...
Computers & Internet Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
