Question about Lexmark P4350 All-In-One InkJet Printer
SCAN WHEN I SCAN A PICTURE IT ONLY SHOWS HALF THE PICTURE!
  • 55 Answers
Ok" what you have to do is a pre-scan, in the pre-scan menu click on the your picture hold button down and drag a box will apear around the picture telling the computer what part of the picture you want scaned by draging that box.
Then do a regular scan
Posted on Jan 16, 2008
Sony model kv327fv310 tv only bottom half of picture shows
Vertical scan output section fault. Contact any service technician, to replace the damaged component/s. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 09, 2013 | Sony FD Trinitron WEGA KV-32HS510 32" TV
I have the 52 inch home theater and the picture shifted and is shows the picture but half way because the top of the screen shows black
hi,
you could try resoldering the vertical scan ic and changing electrolytic capacitors near it, as they have probably dried out due to the heat over the years. cant give you the position numbers as i have no manual but the ic should be on a heatsink on the deflection board,usually vertically mounted and with 5-9 leg.
ok
Dec 23, 2010 | RCA P52926 52" Rear Projection Television
TV shows on half screen. other half fuzzy
You have some cold solder joints on the PC board. Flux and re-flow all of the electrolytic capacitors connections..
Aug 29, 2009 | Televison & Video
The left half of my desktop shows half of the picture
try replacing the video card. if the video card is working just fine then try replacing your monitor
Jul 02, 2009 | Dell Computers & Internet
When I scan a picture, the resulting scan is
scaning time use enlarge option in scaning software
Apr 18, 2009 | HP Scanjet 5470c Flatbed Scanner
42" LCD tv shows picture on only half of the screen,other half dark!
The T-Con board (otherwise known as LVDS) connects to two seperste parts of the LCD panel. If you do have half a picture (left or right) replacing the T-Con board should resolve this issue. Open your TV, find the part number and search on eBay or at sites like www.flattvparts.co.uk where you can search by TV model number.
Oct 27, 2008 | RCA L26WD26D 26 in. LCD TV
Half picture shows up and top portion is black
The camera firmware should be reloaded, if this fails then the camera is likely beyond end user servicing and should be repaired by a professional.
The reason your only seeing bottom half is as the reflex mirror is opening upwards to expose the sensor ( traditional cameras opened the mirror then a shutter to expose film ) your cameras sensor is only registering or transferring the bottom half of the image because it is the image is registered bottom first to the top until the shutter closes and the mirror returns to resting position.
Your problem could be the result of firmware or a more serious issue.
Aug 10, 2008 | Nikon D40x Digital Camera
Stuck on P-Scan
Most DVD players has a P-Scan on/off button in the remote control. On the other hand, Memorex in some of its models have the P Scan switch at the rear of the unit. It is a slide switch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 25, 2008 | Memorex Progressive Scan DVD Player...
Lexmark P4350 All-In-One InkJet Printer Logo
109 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
