Question about Lexmark T522 Laser Printer
I have a lexmark t522 printer which was working fine about an hour ago but now it won't even power on. Can you advise what you think the problem may be
  • 320 Answers
Do this disconnect the scanner motor plug from the engine board this plug is at the top of the engine board it will be either all white strands or blue black and red standed wires. then see if it powers on. this sounds like the scanner motor is dieing and is shorting out when it gets warm.
Posted on Nov 16, 2009
I have just received a lexmark t522, which was an ex-work printer that was attached to a network. i want to use it as a stand-alone printer now. when it was attached at work it worked fine, but now keeps...
This printer has both a USB and parallel printer connection.
I suggest you connect this printer to your computer using the USB printer cable and install the printer driver software on your computer.
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :- http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Aug 03, 2011 | Lexmark T522 Laser Printer
HOW i get engine code for t522..i have engine code/900 rip error??? \r\nMy email address is Heikki.Rossi@huoltoverkko.com
The 900 error usually indicates a software or communications problem. The first thing to check is the base printer.
  • Turn off the printer and disconnect every cable, except for the power cord.
  • Turn on the printer and see if the error returns.
  • If the error does not return, try to print a test page from the Test Menu.
  • If the test page prints correctly, the printer
Jun 05, 2011 | Lexmark T522 Laser Printer
922 service fuser error
  • 921 Fuser Error and 922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
    • If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
    • If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
    • If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine.
    Nov 10, 2010 | Lexmark T522 Laser Printer
    Lexmark T522 printer I need to go into Tech Mode to move the Paper Down so that it does not clip the list line. I know you turn it off and then perss 2 buttons and hold them while starting it...
    hold the go and return buttons while powering up the unit it will come up to registration hit select this is where you adjust the laser lock of the scanner
    Oct 23, 2009 | Lexmark T522 Laser Printer
    Lexmark T522 (invalid Machine code)
    i take it that your getting an invalide engine code error? this is caused usually by the printer taking a power surge. you can get a batch file from lexmark to reflash the engine board however if it will take the code it usually odesnt last to long. change the engine board and your problem will go away
    Mar 17, 2009 | Lexmark T522 Laser Printer
    Lexmark t522
    Here is what you need!!! Click on the Above Link. Download Software!!!
    Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
    PREM
    Mar 13, 2009 | Lexmark T522 Laser Printer
    Diamonds on the T522 LCD
    do you get 5 beeps when the printer powers up? three things can cause this the control panel, the logic board and the engine board if you have replaced the logic board the engine board is the problem change that and your problem should go away
    Dec 18, 2008 | Lexmark T522 Laser Printer
    Lexmark t522 black marks on leftside of pages
    the top roller is the charge roller and the bottom one is the transfer roller if a foriegn substance got on either roller they could create this problem the oil from your fingers getting on them could create this. given everything youve changed the rollers are whats left. you can clean the charge roller but its better to get new ones these are consumable
    Apr 22, 2008 | Lexmark T522 Laser Printer
    Lexmark T522 Laser Printer Logo
    85 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
