Question about HP Pavilion dv6000z Notebook
HI, Ihave a serious problem with my keyboard, i do not know what it is but i think it has to do with the spacebar,arrowkeys and backspace..........whenever i am typing and i press the spacebar or backspace the cursor always jumps back to the begining of the line.its so annoying and makes my work so difficult,i need hesome assistance here..pls help
  • 788 Answers
I wonder if something may have be spilled on the keyboard.?
If you are sure that this is not possible, You may have picked up a virus and have some bad files.
If you are running VISTA, type recovery manager, then choose hardware driver re-installation and next, allow the system to re-install your hardware drivers.
This will not effect your saved files or programs. Will only reinstall the hardware drivers.
If you still have the same outcome, you will have to replace the keyboard.
In the meantime, you can pickup and USB keyboard and use it until ready to have repairs completed.
Hope this info has helped you.
Posted on Oct 06, 2009
    Problem Solver:
  • 15 Answers
May be ur having internal wiring problem or the electronic sheet is being disturbed or scratched.
If u can open key board by yourself try to rearrange the white buttons below the keypads or else take it to some repairing shop.
Posted on Oct 02, 2009
How do I unsplit the spacebar on a microsoft keyboard
I don't know why you would want to "un-split it" but, if I were to try such a thing without disassembling the keyboard, I would epoxy something thin and rigid - perhaps a piece of the long spacebar from an old keyboard - across the tops of the two keys. If I wanted to take the keyboard apart, I'd just epoxy a small piece of plastic between the two keys and, if space allowed, reinforce with a small screw being careful to maintain the original distance between the keys so they would still line up with their sensors. In both cases I would use epoxy rather than glue because the spacebar is a very heavily-used key and epoxy is MUCH stronger than glue. I hope this is helpful. Good luck!
Jul 18, 2014 | Microsoft Sculpt Comfort Keyboard
My..spacebar.not.works
in think that you must change keyboard
Oct 28, 2012 | HP Computers & Internet
Spacebar on keyboard makes my computer go to sleep mode
Sounds like your keyboard is sending the wrong signal (the one telling your PC to enter sleep mode) to your motherboard when you press space key, which (if true) would indicate it's faulty. It could also be you've contracted a virus and is playing a particularly nasty practical joke on you (let's hope that's all it does). Try connecting another keyboard to your PC and see if that helps. If it doesn't, then you'll need to clean your computer of any viruses. Try also disconnecting your mouse and see if that changes anything. If your keyboard comes with a shortcut utility software for it, run it and check there's no shortcut set on your keyboard's space bar. You've additionally specified you're not using wireless keyboard, but could you also please write what OS you're on?
Mar 23, 2012 | Compaq Keyboard
Hi my keyboard started working erratically a few days ago. it's an A4tech keyboard. and at first while using photoshop the spacebar stops working then I would have to reset it to have it start working...
It sounds like the keyboard is starting to you can try a different keyboard if you have one and it that works your keyboard is bad. If your other keyboard doesn't work to your port were your keyboard is plugged into maybe going bad, let me now if any of this helps.
Aug 02, 2011 | Compaq Keyboard
I broke my spacebar off my laptop gateway computer! How do i fix this?
Of all the keys on the keyboard, replacing the SPACEBAR is probably the most difficult. The SPACEBAR is kept even by a metal wire that is inserted into slots on each leg of the plastic bar key. However, you have to get the wire into the slots without depressing the wire. If you push the wire down, you compress the wire and installation becomes impossible. As a general rule, do not remove the SPACEBAR unless absolutely necessary. If you remove the SPACEBAR, remove several surrounding key caps also. This will let you get some tools under the SPACEBAR wire later on. Once the SPACEBAR is reinserted, you can easily replace any of the other key caps.
Jan 19, 2011 | Gateway 2520915 Keyboard
I can't login via telnet on my SRW2008 Instead of the normal sreen (with only User Name/Paswoord) I get this menu and when I give User/Password and press Enter it just toggles between User en Password...
The 'TAB' key on your keyboard should move the cursor from one field to the next. On the 'Edit/Execute' field, press the 'SPACEBAR' key to rotate through all the options within a field, e.g., "yes" or "no", and press the 'ENTER' key to select from one of the options. In the 'ID' or 'PASSWORD' field, press 'ENTER' to move on to the next screen.
Dec 23, 2010 | Linksys SRW2008
Can't/use/my/spacebar/ don/'t/have/recovery/cds/for/satellite/135/using/vista
I'm afraid that your recovery CD's won't help you get the space bar working.
There could well be dust, biscuit crumbs, hairs etc that's preventing the spacebar from working, turn the laptop off but don't close the lid, stand the laptop on it's side and get yourself a clean, dry paintbrush.
Start to brush the keys and gently tap the keyboard with the other end of the brush to knock out any foreign objects that could be trapped under the spacebar.
Once your happy it's clean turn the laptop on and see if the spacebar works.
If you still have the same symptoms then the keyboard will have to be replaced.
You can use the on-screen keyboard to substitute for the spacebar for the time being.
Good luck.
Aug 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Whenever im typing and hit the spacebar the cursor skips. its driving me nuts. pelase help me.
Could be something wrong with the spacebar on your keyboard. Try another keyboard and see what happens.
Hank
Aug 04, 2009 | HP Computers & Internet
Spacebar came off;wont fix now.
I don't think it is worth messing around with it anymore..Look for a replacement on ebay..Unless you get another same model and remove the needed bits..
Jun 12, 2009 | Compaq Presario C700T Notebook
Keyboard spacebar sticking
Just solved it, after a bit of tinkering...
the prongs of the floating plastic frame need to sit inside the clips of the spacebar key, you can't just clip it back on with the prongs either up or down. It's fiddly, you need a paperclip or thin screwdriver to do it, but it's stopped the sticking problem.
Oct 25, 2008 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
HP Pavilion dv6000z Notebook Logo
244 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
