Question about Garden
I have a Grasshopper zero turn mower that uses 20.00 per quart Grasshopper brand hydraulic fluid, how can I find out if there is a substitute such as ATF or Synthetic motor oil? it is a 1990 model 718D
  • Rich Kekic Oct 18, 2013
    I found metal shavings under the top oil seal ? The motor will seize up if I keep running it
  • Anonymous Mar 30, 2014
    i have a 1989 grasshopper zero turn i need a break down on the hyd pumps
  • 157 Answers
Yes just reguler hydralic oil it wont hurt a thing. but dont use atf its for transmissions in vehicles
Posted on Oct 26, 2009
  • Chris Claussen
    Chris Claussen Aug 25, 2015
    Never use Regular Hydraulic oil, it will harm the very costly hydro, they are made to be used with full synthetic oil.
  • 3 Answers
Posted on Sep 03, 2015
Left hand drive handle hard to move forward
drain and replace your hydraulic steering system oil and replace the hydraulic filter then refill system
Jan 26, 2016 | Toro TimeCutter Zero Turn Lawn Mower...
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
Do husqvarna zero ten mowers use hydraulic fluid?
no they use hydrostatic fluid only use hydrostatic fluid
Aug 17, 2014 | Garden
Why did my zero turn mower suddenely quit pulling on the right wheel
That's going to be expensive. You will need to take it to a shop unless you have a lot of specialty tools. Example : hydraulic flow tester and a very good understanding of hydraulics
Aug 06, 2014 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
1992 Plymouth Voyager valve adjustment
Your car has hydraulic valves, which means they are not adjustable.
If they are clattering, you may need to change the oil (If it is dirty) and run some cleaner through the motor.
What I mean is, add the cleaner to the fresh oil and filter you put in the motor.
50 years ago, we used to add a quart of automatic transmission fluid to the oil to clean the motor.
Automatic transmission fluid is basically colored detergent.
We would then drain the oil and transmission fluid when it got dirty, like maybe 500 or 1000 miles.
You do not want to put too much oil in the motor, so you would substitute the tranny fluid for the last quart of oil.
Be blessed.
Apr 21, 2013 | 1992 Plymouth Voyager
Grassshopper 425 Mower - Ignition key will not turn. Blades are not engaged and it is in neutral. Any suggestions?
if the key will not turn its a bad switch even if a safety switch was bad the key would turn
Apr 07, 2012 | Garden
Garden Logo
2,241 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
