Question about Maytag MER5765RAS Stainless Steel Electric Kitchen Range
Problem with Precision Touch Control 500 Electirc Smoothtop
I was using the stove the other day and everything was fine, but the next day the largest element (which is also a dual element in that it has a size selector for larger pots) stopped working. The second element (the one that makes the total heating area larger) works, but the main portion does not. The specific model # is MER 5165RAS. I'm not having any other problems with it. I have reset the breaker and unplugged it over night and plugged it back in, but it still does not work.
  • Michael Murphy Dec 21, 2007
    What would cause this and is there anything I can do to fix it or must I call a service tech.
    Scholar:
  • 146 Answers
It's more than likely an open element or a burner thermo. There are 2 ways to check. One is find a wiring diagram and trace the burner circuit to see if the element circuit is open. The other way (and you have to be careful) is to remove the top, being very careful not to crack it lift it off and check the element leads for an open element or element thermo. There will be several screws around the bottom out base of the top. Check it and you will find out what is wrong.
Posted on Dec 24, 2007
  • Kelly Sullivan Dec 29, 2007
    I doubt you have any burnt wires. It's more than likely the element. The only way to replace it is to remove the top. Just be careful.
  • 456 Answers
I think some wires may have burnt due to high voltage or overloading
Posted on Dec 20, 2007
Maytag precision touch control 500 electric smoothtop
The heating coils in the oven need to be inspected very carefully where they plug in to the oven wall. You will need to remove the back covers and check the insulators and wiring harnesses. Over time the insulation can break down and oxidize the metal connections. You can use a voltmeter or test light to verify that the coils are getting voltage from the thermostat/switch. replacing parts is cheaper than buying new if you can find the parts.
Oct 04, 2017 | Cooktops
The ON light for the stovetop on the left side will not turn off.
The switch controlling one of your left side surface elements is bad.
Aug 24, 2017 | Maytag MES5752BAS Stainless Steel Electric...
Need a new element for the large front burner on my Maytag Precision Control 500 smoothtop stove
That is the 2700W element. I have it available for $157.35 plus shipping.
Email me at buffalonymann@yahoo.com if you would like to purchase this part
Oct 17, 2009 | Maytag MER5775Q Electric Kitchen Range
One burner will not turn on - This is a Maytag Precision Touch control 500 electric smoothtop
hi there,
on this case try to clean the gas burner for any dust and corrosion inside. also check and test the ignititer of the stove/
let me know.
Jun 02, 2009 | Maytag MER5770 Electric Kitchen Range
One surface element went dead.
Make sure that element didnt come unplugged. Just push it in firmly and it should be fine.
Mar 18, 2009 | Cooktops
Kitchen range cleaning
Use Glass cook top cleaner by Weiman. For stubborn burnt on food use a scraper or razor blade and hold it at and angle almost parallel with the top of the stove top and scrape off gunk.
Apr 03, 2008 | Kitchen Ranges
Maytag,electric stove-
you need to order a custom control kit, electronic switch that contorls onlly that one burner
Dec 07, 2007 | Maytag MEC5430BDS Electric Cooktop
Maytag MER5765RAS Stainless Steel Electric Kitchen Range Logo
546 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
