Question about Dell Inspiron 1525 Laptop
Battey not charging, red light flshing
My battery wont charge in my inspiron 1525 says "plugging in not charging!" tried a new AC adapter and a 2nd hand battery still no change. ideas please. its only 2 years old.
  • Dell Master
  • 32,281 Answers
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Posted on Oct 02, 2009
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1525 is now around 4 years old and recently it has not been able to charge and only works when it is plugged in. Also when i start the laptop, it displays a message saying i need to...
As you say the system is 4 years old update the bios
your download link is here!
IMP. Be sure to plug in the battery and it should be charges above 10 % and the system should be connected to the mains power supply also ensure there will not be a power outage during the update process
this will resolve the issue 100 %
Dont forget to say thanks!
Aug 11, 2010 | Dell Inspiron 1525 Notebook
My computer would not hold a charge and eventually stopped charging all together. I have tried a new battery and tried to charge on a different power card. Neither have worked.
if you have tried both a known working ac adapter and battery and still wont charge, then possibly, the issue is with the motherboard. You may need to replace it.
Jul 18, 2010 | Dell Inspiron 1525 Notebook
Problem of charging the battery
Check battery indicator. If OK, update BIOS. If no change, check battery bios info, if AC Adapter is incorrect, replaces it. Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
Jul 12, 2010 | Dell Inspiron 1525 Notebook
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery doesnot charge
1. remove all external peripherals 2. try to use ac adapter alone check if laptop will power on. 3. put back batt in with ac adapter. 4. check bios (power on laptop keep tap on F2) 5. check for the bios version, battery info and battery health. 6. check if batt is 0% or 10% charge 7. check battery health and info if the ac adapter is determine or not. also check if batt is performing normally. 8. if batt has 10% charge then download the latest bios for your system. download it from support.dell.com
Nov 12, 2009 | Dell Inspiron 1525 Notebook
Battery wont change
A problem is just like a mountain. You don't jump over the mountain, you climb it in steps, one step at a time.
1.How old is the battery? 1 to 2 years old, you can expect it to be at the end of it's Life Cycle. Batteries are rated in so many hours of usage.
Best bet is to let the battery charge 24 hours, then try it.
Would be nice if you someone else that has an Inspiron 1525, and they would try to charge your battery. If it doesn't charge up, you would know it's the battery. If it does charge up you can move on down the charging system, to try to find the problem.
2.AC adapter, (Charger) If you have a multimeter, set it to the 50 volt DC scale.
Laptop and desktop computers use DC current. (Direct Current) Your house, for example, uses AC current, (Alternating Current)
AC is converted to DC by the AC adapter, (Charger)
An example of DC current are flashlight batteries, and your laptop battery.
DC current has a Positive pole, and a Negative pole.
The center pin of the plug of your AC adapter is the Positive pole. Any of the four outside pins on the plug, are Negative.
The Red, (Positive), probe of the multimeter goes to the center pin. The Black, (Negative), probe goes to any of the outside four pins on that plug.
Example of a DC Power Jack, for the Dell Inspiron 1500 Series of laptops, 1525 and 1526, (This is the jack inside your laptop, where you plug the AC adapter into),
http://www.megaemarket.com/dc-power-jack-for-dell-inspiron-150150015011505.html
3.It may be that DC Power Jack itself is bad, or one of the solder connections is cracked. It's hard to see it clearly on the link I provided, (So I Right-clicked on it, Save Image As, and put it right in my My Pictures folder. Then I magnified it), but in the photo you will see some metal pins sticking out of the rectangular body.
The metal pins are sticking up. In reality those pins go down, when the jack is mounted on the motherboard. They go through the motherboard, via holes, and are soldered on the other side.
It is these solder joints that may crack, is what I'm referring to.
Solution to 1?
Obviously buy a new battery.
Solution to 2?
If your multimeter findings show lower voltage than needed, it's time to buy a new AC adapter. They have generic ones that can be used on a variety of laptops. The voltage will be stated on the top of the AC adapter.
Example: 19.2V-1.0A
That's 19.2 Volts at 1 AMP.
It may just be the plug end on the AC adapter itself. The plug end that goes into the DC Power Jack, on your Inspiron laptop.
Solution to 3?
Unless you are a skilled Electronics Technician, and have Excellent de-soldering/soldering skills, I advise taking it to a computer repair shop. It may not just be cracked solder joints. The DC Power Jack may need to be replaced. Maybe the motherboard is one of a bad design, and where the DC Power Jack attaches to it, has cracked.
Jul 25, 2009 | Dell Inspiron 1525 Notebook
Ac adapter will not charge my computer
If the laptop will run from the adaptor, then the adaptor is probably fine. That being the case, if the charge light flashes when the adaptor is plugged in, the battery is faulty. No charge light on an otherwise working system is probably the battery charging circuit in the laptop.
May 17, 2009 | Dell Inspiron 1525 Laptop
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1525 Laptop Logo
132 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
