my lg rear projection t.v has ghosting mainly with blue. Happened after i moved t.v. From what i have researched it sounds like convergence chip or board?? have tried auto convergence without success - is it worth replacing the chip? any idea on cost? as I really like my t.v & don't want to get a new one
ICs are STKs big black ICs will have part number on them Call Mats Electronics 1-800-628-1118 ICs $12.00 Also call Zenith Moduel Exchange 1-800-632-6637 See if they have rebuilt board & cost.
You can try using a convergence coil. You can rent, borrow, or buy one from an electronic parts store. This convergence coil becomes magnatized by plugging it in to the room a/c outlet and you take it to the front of the tv screen with the set on and start a rotating motion and start moving away from the screen backwards about five feet and then cut the convergence coil off from the switch that is on the coil. You may have to do this two to three times. You can also call a tv technician to do this for you which will take him 5 minutes.
the picture on my zeneth pvy6067dt tv will not get bright enough even when brightness is at 100%....
(More)
THE PICTURE ON MY ZENETH PVY6067DT TV WILL NOT GET BRIGHT ENOUGH EVEN WHEN BRIGHTNESS IS AT 100%. PICTURE IS BLURED IF CONTRAST IS VERY HIGH. I CANT GET PICTURE TO BE CONSISTANTLY CLEAR. TV IS USEABLE BUT CAN BE A REAL PROBLEM WHEN WATCHING A MOVIE WITH A DARK PICTURE, OR WATCHING SPORTS WITH SCORES AT TOP AND BOTTOM OF SCREEN. CAN ANYONE HELP ME OUT?
The TV shuts off by itself and then comes on 30 seconds later, it keeps doing it over and over. It...
(More)
The TV shuts off by itself and then comes on 30 seconds later, it keeps doing it over and over. It did stay on for a few hours last night but then kept shutting on and off again.
