Question about Dell Latitude D600 Notebook
Dell D600 Freezing on network detection
Hello All,
I have a Dell D600 which has assisted me through the past 4 years with no hiccups. However, this has changed this week:
I had to change the motherboard frame (as the LCD screen hinges had snapped), and have done so with the utmost care. However, the laptop freezes when it detects a network...
I have removed the hard drive and tested it in another D600, which also freezes when trying to access the internet.
I have tried wireless and cabled connections with the same result.
Could someone please help?
  • 3,940 Answers
Try a repair of the network connection (Right click it, repair) that will clear several settings that might be an issue. If no change boot to safe mode with networking, see if issue occurs in safe mode. If issue doesn't occur in safe mode, then you might try a system restore to a time period when the issue was not occurring. You can flash the BIOS to a current version if a newer version is available. You can uninstall the driver in the safe mode, reboot and re-install the driver. If the issue does not occur in the safe mode, you may also try editing the startup group of MSCONFIG to see if a driver installed there is causing an issue Last but not least, run a malware scan of the system (Malwarebytes from Download.com is highly recommeneded)
Posted on Oct 03, 2009
My Dell Laptop USB ports are not working any more
Do they not work on any device? Have you tried using a device that they used to detect in the past? Maybe the device you are using is too advanced for the old D600. For example, I would imagine it would have a hard time detecting a 1TB external hard drive.
If it will not detect a device that used to work in the past I would go into the BIOS or System Setup and make sure the USB is enabled. When you turn the laptop on just watch the screen and it will tell you which key to hit to get into the Bios or System Setup. I think it is the F2 key for the D600.
Apr 30, 2012 | Dell Computers & Internet
Can not find a driver for network controller for D600
1. Click on the Link for you to download the driver for your network controller 2. Choose the Appropriate Operating system
3. Choose Network under Category
3. Select Broadcom that has Driver
4. When it finished downloading. Follow the prompts keep on hitting next and we are all good
Thanks for choosing Fixya
Jul 19, 2011 | Dell Latitude D600 Notebook
My dell laptop will not startup
Hello and thank you for allowing me to assist you.
1. Please remove your battery and remove your system from power 2. Reinstall both after several mintues 3. ONLY install your battery to see if the system will start up 4. If it does not, install the power cord to isolate the problem down to the device
If you problem is resolved, feedback is already appreciated so that I may continue assisting people for free.
Jan 11, 2011 | Dell Latitude D600 Notebook
Where can a i get the local area connection driver fro a dell d600?
this the link network driver copy past explorer and enter then download if fix your problem click yes for vote
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=LAT_PNT_PM_D600&os=WW1&osl=en&catid=&impid=
Dec 29, 2010 | Dell Latitude D600 Notebook
AUTOMATICALY DOWNLOAD VIDEO CONTROLER TO FIX MY DELL LATITIDE D 600
Dell D600 Drivers can be downloaded from Dell Official Support. Select 'Video' and download the required drivers and install them
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 22, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
My dell latitude d600 is not on.
Hello
Please be more specific on the problem you are experiencing. I will gladly assists if you give me the sufficient details.
Kind regards
'Andrea
Sep 27, 2010 | Dell (0Y4801) for Inpsiron 600M, Latitude...
Hi, does anybody have an idea why my dell d600 and my d510 wont actually connect to a wifi network, it can detect them ok, but it just will not connect to it, i have tried new connections / ssid name /...
You need to remove all your existing preferred wireless connection from your Network and sharing Center by clicking the manage wireless networks and removing each one by right-clicking each and select remove.
In xp, open view available networks and click the change advanced settings and remove all existing preferred networks then try to connect again to the wireless network you're trying to connect.
May 21, 2010 | Dell Latitude D600 Notebook
My laptop cannot detect my LAN cable
If LAN cable is working in some other system then issue might be related with LAN card. Please check the following:
1. if DHCP is not assigned then please check whether static IP has been goven or not?
2.Once disable the local area cconnection then again enablle it.
3. Please open services.msc and then check whether all the network services are on.
Thanks
Apr 12, 2010 | Dell Latitude D600 Notebook
My ethernet is not detected and seperately my wireless networks are not detected, the bios ccreen says the minni card isd not installed [need screwdriver to check this though] and my network nag screenh is...
I doubt the motherboard is dead, the computer would not boot into bios or windows if tat was the case.
It's probably a bad mini card or bad usb circuitry. Ive seen alot of that. cheap Chinese parts that are only designed to work just past the 1yr warranty. Try a wireless modem in the pci2 slot, see if you can get internet that way.
Oct 11, 2009 | Dell (0Y4801) for Inpsiron 600M, Latitude...
I lost ethernet and network controller on my laptop after reformatting it
http://supportapj.dell.com/support/downloads/driverslist.aspx?c=in&l=en&s=gen&ServiceTag=&SystemID=LAT_PNT_PM_D600&os=WW1&osl=en&catid=&impid=
please visit this link and download the drivers
Dec 17, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
134 people viewed this question
Alun Cox
