Question about Casio EXILIM 10.1-Megapixel Digital Camera - Red
I need to transfer image from memory onto the card
    Brigadier General:
  • 11,967 Answers
In the menu, there should be an entry for "copy" which would allow you to copy the internal memory to the memory card.
Posted on Oct 02, 2009
SOURCE: Transferring images on camera memery onto memory card.
I had the same problem, and I found after much playing and mostly accidental findings that I could do this by following these steps
1. Put an SD card in the camera. Will not work otherwise
2. Go into playback mode, where you view the pictures, button looks like an blue arrow pointing to the right
3. Press the round 4 way controller downwards, and a menu (that I have never seen before!) appears
4. Choose the 4th icon along on the top line and that will give you options to transfer from memory card to camera and the other way around.
Posted on May 13, 2008
jayzone2k1
  • 57 Answers
SOURCE: my samsung s1030
An 8gb memory card to too large for your camera. It can't handle the large space on an 8gb memory card. If I'm not mistaken the s1030 can only go up to a 2gb memory card.
Posted on Jun 10, 2008
  • 3 Answers
SOURCE: How do I transfer pictures onto the memory card?
Go to the camera's "setup menu" and scroll down to the last option, "move images to card" That should put the images onto the memory card.
Posted on Jul 01, 2008
  • 102366 Answers
SOURCE: I need to transfer photos from my built in memory
Select "COPY" from the PLAY menu. Select the direction (in this case, IN-to-card). Select YES.
Posted on Apr 14, 2010
  • 102366 Answers
SOURCE: i have a Panasonic Lumix
From the Playback menu, select "Copy." If necessary, format the card first.
Posted on Jan 21, 2011
Tip
If your camera will not read or transfer internal images on to memory card
When your camera will not transfer images onto memory card this is often because the image storage has been set to 'Auto'. You need to set it back to internal memory temporarily to allow you to copy the images over to the card. Once you have done this you can set the camera back to 'Auto' and this will reset the system and you will now have access to all of the images on the card.
This particular procedure works with all cameras but the steps outlined here are for Kodak in particular.
Please follow these steps;
1) Insert the card
2) Turn the camera to Auto
3) Press review - "reading memory card"
4) Press menu and scroll down to image storage and press ok
5) Select Internal Memory and press OK
6) Scroll down to Copy - Copy Pictures to memory card
7) Scroll down to ALL and press OK - you should see "Copying" displayed
8) When the screen goes back to the main menu - Scroll to Image storage again and select Auto - OK - "Reading memory card"
You should now be able to see the pictures from your internal memory saved onto your memory card and your camera is once again ready to use.
Hope this helps. Please do register your vote using the Yes/No buttons below to reflect the helpfulness of this Tip.
on Dec 22, 2009 | Cameras
Pentax Optio M30- How do I transfer pictures from the internal memory onto an SD card??
this model not support it, To do that, you need to connect to pc and transfer it. As long you inserted the SD card, IT will use memory from SD card and not display image, video from built in memory.
if you want to delete file in built in memory, you need to remove memory card.
check this :
PENTAX OPTIO M30
May 09, 2011 | Pentax Optio M30 Digital Camera
Hi, i have some photos on my internal memory and need to put them on an sd card because the connection with usb is faulty. As soon as i put an sd card in camera i cant see internal memory images. Is...
There should be an internal transfer from memory to SD card on most camera but not all look under the main menu for the memory card where it tells you to format card and create folders it there should be a COPY option.
Dec 06, 2010 | Pentax Optio A10 Digital Camera
How do u transfer pics from facebook to memory stick
right click on the image from face book, save to your computer - isnert USB drive onto your computer USB
then locate the image in your computer and drag it or save to your USB drive
Oct 15, 2010 | SanDisk 4GB Memory Stick Micro M2 Memory...
I have pictures stored on my camera and need to transfer them to my memory card. I cannot hook the camera up to the pc because I do not have a cord to transfer the images to pc. How do I transfer them onto...
Do not format!!!This will erase the card. Go into the menu and look for an entry for "copy" that will give you the option to copy the internal memory to a memory card.
Mar 27, 2010 | HP Photosmart M415 Digital Camera
Uploading pictures back onto my camera
Hey hapurves,
Uploading your images should not remove the images from your memory card. If your images are no longer on your memory card the card has most likely been formatted. You could try connecting the memory card to your laptop with a card reader and under My Computer right click on the icon for your memory card and select open. Now you could try copying the images you want back on the memory card and pasting them into a folder on the memory card. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 09, 2008 | Nikon Coolpix L11 Digital Camera
Apr 06, 2008 | HP Photosmart M415 Digital Camera
Jan 13, 2008 | Pentax Optio S6 Digital Camera
How do i put a tape recording onto the pc?
Unless the video is stored on the memory card you cant transfer it directly, you need a video capture device, it is an attachment to your Computer that manages the transfer of taped video copies to digital...
Dec 09, 2007 | JVC GR-D60 Mini DV Digital Camcorder
Casio EXILIM 10.1-Megapixel Digital Camera - Red Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
