My color can not be adjusted backgroung colors are green
  • dan_fiume Oct 02, 2009
    color cannot be adjusted (the only color I have is green)
    I tried unplugging and plugging TV back on problem still exists
    my model number is HD61Z575
    no video cables attached (straight cable)
    seems logical
    the TY is 5 years old
    time to buy a new one
    thanks for your support!
    Guru:
  • 1,326 Answers
How old tv? If its more then 5 years old and the color is not adjusting propery/or not at all the picture tube is going bad and will either stay green or eventually black out. A repair like this is $100-$500 depending on the type of tv and unless its an expensive one probably not worth fixing. The repair shop normally charges $35-$50 to look at it and usually goes to the cost of repair..
Posted on Oct 02, 2009
  • 19,396 Answers
The reason depends on the type of TV.
First check the video cables at the back of the unit, that is most common reason for this kind of problems.
On a plasma it can be faulty sustain board, a voltage problem, or a problem on digital video processing, on the main board.
On an LCD it is a bad LCD controller board, on the RGB channels.
On a rear projection, a different number of problems, like a blow red CRT, digital board problems, and more.
The problem depends on the TV model.
Start checking video cable, and disconnecting TV from power for ten minutes.
Also please give me the model information. I am on call out right now, I will answer within 4 hours.
Thanks
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My ws65513 has way to much green color in it.How do I adjust the color?
First thing to do is turn color all the way off and examine screen--is it black and white or another color?
If you cannot tell peek in the back with set on at the 3 lens which are red, green and blue--are all lit or not?
Jun 16, 2012 | Televison & Video
Perblem lg37lb1r has a color very often the color of green blindon
You can adjust the green temperature at the color RGB adjustment.press the menu button then choose the video adjust then scroll down to RGB setting RGB stands for RED,GREEN AND BLUE..adjust it according to your preference..
Apr 06, 2012 | LG 37LB1R 37 in. HD-Ready LCD Television
Color is over red
The color of the Television is compose three color,the Red,Green and Blue.First thing to do is try to adjust the color adjustment.Adjust and balance the color.
Aug 18, 2011 | Sony KV-XR29M50 TV
The color of my television is only blue and red whats the problem
There is a lack of one color.The television is compose of three color.The RED,GREEN,and BLUE. So your television have no green color.Try to adjust the color adjustment,if did not work the problem is in the color section of your television.Maybe the green driver transistor is deffective.Its need to troubleshoot.
Aug 18, 2011 | Televison & Video
I have a 50" LG Plasma that has lost color only with the tv
the main total assy might be the problem. it controls color, pix size and such.
Jul 09, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
White colors schemes seem off white color or brownish color and blue has green tint or baby blue color. .
Check the coolant in all three crt's as chances are it is contaminated (should be crystal clear). If brown (beer color), replace coolant in all three crt's and perform convergence adjust. Picture should be like new!!!
Good Luck!!!
Jul 20, 2008 | Akai PT5598HD 55" Rear Projection...
Color problem
CONNECT YOUR DVD PLAYER TO SOME OTHER TV .IF THE COLORS ARE OK ,THEN YOUR TV IS AT FAULT .
THE COLORS OF YOUR TV CAN EASILY BE RE ADJUSTED BY A TV SERVICE MAN.
THE CORRECT RATIO OF RED ,GREEN ,BLUE NEEDS TO BE ADJUSTED .
Jun 02, 2008 | Sanyo DVW-6000 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
