Question about Microwave Ovens
The Sanyo microwave just beeps and 7 constantly appearing
Key pad then does not respond and can;t operate unless shut down for over 30 minutes.
    Sergeant:
  • 244 Answers
Something is probably over-heating. any unusual smell?
are you using 'microwave' safe containers? no metal, foil,or even foil coated hamburger wrappers! or other fast-food product wrappers that are foil coated!
IF IT DOES IT ALL THE TIME- then buy a new one!
they (even in this economy) aren't budget breakers!
good luck!
Posted on Oct 02, 2009
My white westinhouse microve is showing E2 and beeping but not workiing
disconnect by 30 seconds, and connect again. If the problem code appear your must replace the touch pad+control board.
see the diagram
Jul 31, 2012 | Microwave Ovens
Chef Banquet - turns off after 7 minutes? Why
It appears the problem is in the keypad controller board, it will only run for 7 minutes and give a loud beep, you need a professional for this, to assess the situation.
Mar 27, 2012 | Magic Chef MCD1311ST Microwave Oven
Oster ogf41101, unit display doesn't work, when
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Jun 14, 2011 | Microwave Ovens
GE Microwave power will not shut off
You will need to replace the control panel, better off to just replace the oven.
Aug 18, 2017 | GE Microwave Ovens
My microwave keeps shutting down and i have to
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, a repeat of your symptoms, as well as the answers to these questions:
When it shuts down, is there anything still on the display?
When it shuts down, does the light still come on when you open the door?
When it shuts down, do you still hear any beeps when you press a pad on the keypad?
Also let us know it if fails while in use or while idle.
Nov 28, 2009 | Magic Chef Microwave Ovens
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
The microwave suddenly beeped several times, the scroll directed to push clock button, but no button would respond and then F3 appeared on screen but no explanation. We unplugged microwave a couple of...
The code f3 is a short in the key pad for more than 60 seconds
go to GE .com and enter your model # and you can get a price to do it your self
Good luck
TEETERMAN
Aug 17, 2008 | GE Microwave Ovens
Nothin works on my key pad
Here are lock / unlock schemes for three recent Sanyo models:
- Press and hold Stop/Cancel for 3 seconds
- Press and hold Stop/Reset for 3 seconds or so
- Press Stop/Clear five times
Hopefully one of those will work.
If none of these work for you, contact Sanyo Service Customer Service.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Sanyo EM-V5405SW 1200 Watts Microwave Oven
Microwave buttons not responding - microwave running constantly with door shut
It seems the micro switch for the door close have moved from and is not aline the door clip or the micro switch is faulty
Dec 17, 2007 | Sanyo EM-S9515W Microwave Oven
Microwave Ovens Logo
70 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
