Question about Zanussi ZJ1217 Front Load Washer
Unable to use ZJ1217, start/pause flashing
I have a zanussi ZJ1217 washing machine, today it stopped mid cycle and refused to spin. Drained it , cleaned filter and reset the programs and now it won't enter any program the start/pause light simply flashes after the soap draw has water go in it.
  • krystan Oct 02, 2009
    I can open it only if I switch the machine off and then set the machine to drain (if there is water in it).
    I must then switch the machine off again and upon switching it back on the door will release.
    I cannot open the door when it is full of water or in a cycle.
    Genius:
  • Zanussi Master
  • 1,474 Answers
Are you able to open the door ?if so door interlock switch could be at fault
Posted on Oct 02, 2009
Testimonial: "this is very helpful, Allthough I am not capable of carrying out this work I do at least know what the repair guy may say. thanks."
  • Gerry Harvey
    Gerry Harvey Oct 02, 2009
    After the machine has filled the washing should start, if this is not the case then chance of motor not operating, you could check belt 1st then motor brushes , after some 4 years they will be about dead,hope this helps you ..
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
Dec 22, 2013 | Zanussi FS1455W Front Load Washer
I have a zanussi zj1217, when select any programme it sounds as it is about to start, but before any water even goes in the start/pause button starts flashing. Any idea's.
check pump /pump filter electronics can sense if the pump not working at the begining of the programme try a pump only prog.Can be heater or main motor with an earth fault. you need an insulation tester to isolate the fault.
Jul 25, 2010 | Zanussi ZJ1217 Front Load Washer
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
WASHING CYCLE STOPS AFTER A MINUTE
Can you skip through the programme to drain? Press pause button. then press start to move the lights down to the empty cycle. leave to finish.
If you have already tried this, I can explain how to put machine into engineer test mode, which will then give out a fault code to identify problem.
Apr 04, 2009 | Zanussi FJD1266W Front Load Washer
Zj1217 door not opening
you need to clean your pump there is a safety feature in the washer that will not allow it to open if there is water in the machine if you open the pump be sure to have plenty of towels
Dec 26, 2008 | Zanussi ZJ1217 Front Load Washer
Zanussi ZWF 1631W
Try to pull out the power-cable from the contact. Wait for at least 30 seconds then reconect it again.
Sometimes that can help but not always. If that dosent help you need to let a profesional repairshop fix your machine.
Good luck
Nov 21, 2008 | Zanussi ZJ1217 Front Load Washer
Washing machine
Check pump fiter and pump.
Jul 22, 2008 | Zanussi ZJ1217 Front Load Washer
Zanussi jet system 1200
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Press "end of cycle" to finish the mid stoppage..
Rate me pl.....if helped.
Jan 02, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi ZJ1217 Front Load Washer Logo
794 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
