Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
My tv has lines in it
My hitachi 42EDT41 has 2 vertical lines one in the middle and on to the left
what can i do to fix this at home
  • 1,153 Answers you can get more info and reading here on threads also.
Posted on Dec 22, 2007
What is the cause of my 14inch videocon crt tv appears only a single vertical line in the middle
The image on a CRT TV is produced by a beam of electrons which is controlled by a magnetic field to move the beam top to bottom and left to right. A single line suggests that the vertical deflection is working but not the horizontal deflection (left to right). There are a number of components associated with this and requires a competent TV repair engineer to fix. Better to to buy a new TV!
Jul 13, 2016 | Televison & Video
I have an older model Hitachi 32" ultravision CRT tv. the video just collapsed into a thin horizontal line (about 1/4"). Video is fine. Any help would be greatly appreciated. Thanks.
TURN IT OFF AND DO NOT TRY TO USE---if a thin line left to right in middle of screen it is vertical problem---the set should shut down but even seconds count here--this can burn a mark on all three picture tubes instantly and it is permanent.
Problem if small line left to right in vertical circuit.
Let me know what you know and I will try to help--I know these sets very well.
Sep 22, 2010 | Hitachi 61SWX10B 61" Rear Projection...
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Sep 16, 2009 | Hitachi 36UX01S 36" TV
Screen only shows horizontal line
if line is left to right in middle of screen the problem is in the Vertical deflection circuit---could be either a soldering problem with the vertical output ic or a bad part in that circuit. If this has been helpful please give me a vote.
Aug 08, 2009 | Hitachi 32CX39B 32" TV
Hitachi 42HDS69 Blue Vertical Lines
I think that you have dry solder joints on either the vertical scan board, the focus board, the line output stage, or the chroma panel. Hope this helps.
Sep 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Aug 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi Model CMPAS14V vertical line
anyone experiencing this problem should get in touch with Dave at . he sold me a fix for this problem, for much less than the $400-$500 we were told it would cost to fix it. Dave not only solved the problem but provided the best customer service and support I have ever received. ABSOLUTLY the best money I ever spent, saved my T.V. Get in touch with the confidence of knowing he will help you as he did me. Thanks again Dave!!!
Apr 13, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Horizontal Line
A LINE left / right thru the middle ( horiz line) indicates a problem in the vertical circuit.First step is to solder the pins of vertical o/p
IC.........Next, troubleshoot vertical circuit to look for problem...T.
Please rate solution................................
Nov 15, 2007 | Hitachi 36CX39B 36" TV
Black line in center of screen
These black lines on the plasma screens are very fixable.  There is a dry solder joint on a circuit board at the bottom of the plasma that needs resoldered.  There are 6 or 7 "ribbons" along the bottom of the screen that correspond to vertical sections of the display, so you just follow the black vertical line down to figure out which one is faulty.  I just performed this fix successfully on my first attempt on a Gateway plasma, but it will work on most plasma's, specifically Hitachi, gateway, LG, Hyundai, & Akai. I think they may all have LG boards, my gateway did.
I can't really describe very well what to do, but I assure you it is fixable.  If anyone is near nashville, I might be able to help you out.  My email is
Jan 18, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
No Picture On Screen and red line in middle.
The set has a vertical problem if the line you mention is from side to side ,if the line is from top to bottom the problem is in the horizontal circuit and both can be repairable,a vertical fairlure is a common problem,the vertical IC goes bad and it takes a safety resistor with him to prevent any more damage,the horizontal is rare but it happens too,if you are familiar with tv service you can change the IC but you will need a service manual to identify the part,you can get a manual overnight if you downloaded it at,if you are not too familiar you should seek the help of a servicer for safety reasons.Let Us know how it goes or if you need more information.
Nov 01, 2006 | Hitachi 36UX01S 36" TV
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
242 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
