Question about ASUS P5P800S Motherboard
Asus motherboard p5p800s wiring vcc -d +d ground
  • 336 Answers
SOURCE: Need SPDIF pinouts identified.
When looking at the board, bottom towards you assuming that the 3 pins are parallel to the pci/e slots, the left pin should be the +5V vcc the middle pin is the spdif out and the right pin is the ground. Also the 3 pins are probably not exactly the same distance from each other (equally spaced) the 2 pins that are closest together are the spdif and the ground, spdif is always the middle pin. This info is based on 2 different asus motherboard install guides. I hope this helps you.
Posted on Aug 12, 2009
  • 50 Answers
SOURCE: usb connection wires from front panel to motherboard
The header plug is 9 pins, 5 on one side and 4 on other. Orient the header so that the missing pin is lower right and the connection left to right on top row and lower row are as follows. If you have a shield wire, do not connect this as it causes instability if the ninth pin is earthed. If you have no markings on the wires, you can test from the socket. Orient with the pins up looking from front socket and left to right is 1,2,3,4 same as header.
Pin Wire Color Function
1 Red V BUS (+5V)
2 White D-
3 Green D+
4 Black Ground
Posted on Sep 29, 2009
Testimonial: "was very helpful clear instructions both usb ports working 100% highly recommended"
  • 624 Answers
SOURCE: short circuit in vcc and ground
Some questions first: Is this the same board mentioned in your other post? If so how did you decide that you have a short on your motherboard?
Posted on Jan 30, 2007
ardmax
  • 155 Answers
SOURCE: asus k8v se data-2 data+2 ground and vcc wires
You can download the manual from this location http://dlsvr01.asus.com/pub/ASUS/mb/sock754/k8v_basic/e1529_k8v.pdf
Go to page 1-21 and see the extra USB connectors. If you are talking about your wires coming out from your case and used for a USB port like the one in the front, you should connect them to any of the 4 available USB channel following the polarity. For example connect your Vcc to USB+5V, groung to GND, data-2 to USB_P8- and data+2 to USB_P8+
Let me know if you need more help
Posted on Oct 23, 2007
  • 64 Answers
SOURCE: P5e Asus motherboard
best for the ground cable to connect to ur power input cable's ground. doesn't have to be direct it must just in some way get grounded. eg a wire that connects to ur house's wall is grounded
Posted on Jan 20, 2008
Ram used for asus P5P800S
Single channel DDR400 memory, maximum 2 GB
May 10, 2010 | ASUS P5P800S (90MBL0Q0G0UAYZ) Motherboard
2 x 184-pin DIMM sockets support max. 2GB
PC3200/PC2700/PC2100 non-ECC DDR SDRAM memory.
Or if you prefer it a bit plainer a maximum of 2 x 1GB DDR400/DDR333/DDR266 SDRAM memory.
you will find the full specs as well as the drivers on the asus global website.
Mar 18, 2010 | ASUS P5P800S (90MBL0Q0G0UAYZ) Motherboard
I need help with connecting my case wires to the motherboard
those wires are for the USB not audio,the meaning of the
writing no the wires are:
vcc=5 volts, -D=data negative, +D= data positive,GND=ground.
look in the manual for usb connection, if the mainboard has the header connection for them connect the wires to it if not just leave them out, secure them out of the way.
Mar 13, 2010 | EliteGroup ECS A780GM-A Motherboard - AMD...
Asus mother board sound driver
Go to the Asus website, www.asus.com. Click on the support link. Lookup your specific board model # and select the operating system you are running. A list of all available files will appear. Scroll down until you find the sound driver. Click on it and download and install. Follow the onscreen instructions and you should be all set. Hope this helps.
Sep 19, 2009 | ASUS P5P800S Motherboard
Aug 11, 2009 | ASUS Intel 5000P Chipset...
Microphone
In the back of the computer where all the computer wires are , there is a pink circular jack , you can plug your microphone into that......
Sep 30, 2008 | ASUS P5P800S Motherboard
Asus p5p800s
It could be that you have a damaged power supply which took out your motherboard. When turning it on, what beeps did it make?
Sep 17, 2008 | ASUS P5P800S Motherboard
Asus k8v se data-2 data+2 ground and vcc wires
Oct 23, 2007 | ASUS K8V-SE Motherboard (MBASK8VSE)
ASUS P5P800S Motherboard Logo
1,799 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
