Question about Dell - NPS-200PB-73M (NPS200PB73M) Power Supply
What is the 6 pin
I use the Dell Dimension xps t600r, i got a problem with the PSU (NPS-200PB-73M). Does it work if I replace this PSU by a normal ATX PSU
  • ngocdang_ngu Oct 03, 2009
    thanks for your answer, the total wattage is OK, but how about the 6
    pin, i mean the auxiliary power, this one is not in any normal ATX PSU
  • Dell Master
  • 32,281 Answers
You can replace the power supply in this Dell with a normal ATX power supply. Make sure the total wattage is equal to or greater than the old power supply.
Posted on Oct 02, 2009
Testimonial: "thanks for your answer, the total wattage is OK, but how about the 6 pin, i mean the auxiliary power, this one is not in any normal ATX PSU"
  • Chris Hingee
    Chris Hingee Oct 06, 2009
    Can you determine what the 6 pin connector on the motherboard is for?
No enciende el power suplay
your power box on computer has went bad were your maine power source is.
Jan 30, 2011 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Use the power supply outside the computer
Plug the power supply to desire voltage. Monetarily short the GRAY and BLACK wire in one second.
Sep 20, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
How many ways can i break this
most likely cause of death: motherboard charging circuit. there isn't a simple way to fix this one, i reccomend you get a new motherboard.
Sep 09, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
NPS-200PB-73M
SPECIFICATIONS:
Dimensions 5.9"W (150mm) x 3.4"H (86mm) x 5.5"D (140mm)
Special Features Dell Proprietary Main ATX & 6 Pin Auxiliary Connectors
AC Input 100-120V/7A 60Hz 200-240V/3.5A 50Hz
DC Output Voltage 3.3V 5V12V
Total Output Max Load 200W
Regards.
Jul 20, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
No power on
if sb +5 is ok then check one by one these component :-
check main swithing transistor for open
check diode, capesetor and 3.3 ome resitor it may be open after then check
+ 12 to +18 volt for pwm ic and ,
if votage is not missing then change pwm ic
Apr 21, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Dell - nps-200pb-73M not working
dont know the AC and the DC of my NPS-200PB-73M
Apr 25, 2008 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
TO bogdan
check the twisted paired wires that are found inside your system unit..usually it has a color red, green, blue and white wires..check your motherboard wire pins usually located at the sides of the board or near the BIOS chip. IF you can see those wires, try reseat those wires( but make sure you have an assistance of a qualified technician to avoid wrong connections and to fry your motherboard).
Goodluck!!
Feb 23, 2008 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Computers & Internet Logo
332 people viewed this question
Alun Cox
