Question about Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In Line Edger
No fuel getting through to combustion chamber on Stihl strimmer FS 85.I think it is a blocked carburetor. How easy is it to fix and what are the things to look out for. Mike
  • 437 Answers
I understand your ambitious nature wanting to fix it yourself but it will be easier for a professional to do it than tearing your hair out. There are too many pieces and parts that need to be put in the right way. You will save a whole lot headache from having someone else do this for you.
Posted on Oct 03, 2009
Hard to start..will not rev. up
STIHL TRIMMER-WEED EATER REPAIR: stihl carburetor ...
? 6:55
www.youtube.com/watch?v=vK6MsQalprY
Sep 16, 2011 - Uploaded by JEREMY FOUNTAIN Here is what I did for my fussy Stihl FS 250r trimmer....this after sitting all ... STIHL FS80 FS85 FC85 HS80 CARBURETOR ASSY 41371200614 ...
Aug 07, 2015 | Stihl FS 85 Weed Eater
Starts ok and runs ok after I have pushed in the choke but cuts out as soon as I touch the throttle. Can you help?
sounds like the ethanol gas messed up your carburetor. Gotta hate this gov't mandate to use this hazardous fuel. 10% ethanol =10% gas mileage reduction.
Stihl wont warranty any of their products that use ethanol gas. They want you to buy this very expensive 'REAL GAS' about $7 a quart
May 07, 2015 | Stihl FS 85 Weed Eater
Fs 85 loses power in the heat
Change all filters--and spark plug. Use a good cleaner in fresh fuel. dump the old first. use premium fuel--it has less ethanol in it
Jul 14, 2014 | Stihl FS 85 Weed Eater
Fuel in exhaust
You will find the needle-valve inside the the Carburetor reservoir bowl. Just be sure that the bowl is free of any dirt before putting it back together.
Good Luck
Rich Lilja
Mar 19, 2014 | Stihl FS 85 Weed Eater
My Stihl FS85 runs good for about 20 seconds and then shuts completely off. I have replaced the Plug, cleaned out the fuel system and it still does the same thing. Could it be the coil?
Sounds like the main jet or the diaphrams in the carburetor are deteriorated. Remove carb and soak in a good carburetor dip style cleaner and rebuild with a new kit. Also replace the fuel line and filter and use a fresh gas mix.
Sep 17, 2012 | Stihl FS 85 Weed Eater
Instruction on how to rebuild Stihl FS85 carburetor
The FS 85 was produced in HUGE quantities over a number of years. Several different carbs were used during production and Stihl has several proprietary carbs in use. You will need a Rebuild Kit (NOT just a Diaphragm Kit) for this particular carb. On the carb body you should see a Series and a Model identification.
Example: If this is a ZAMA carburetor, the C1U-S66 might have been used on your trimmer.
Get that info off the carb body and ...
For ZAMA carb lookups click HERE.
For WALBRO carbs click HERE.
Hope this helps.
Oct 04, 2009 | Oregon Scientific Complete Carburetor for...
Stihl FS 85 stalls and wont start after about 20
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} b\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} 285 7772400 10058400 259 261 257 280 262 283 1 06WOHFQ%ZQT6,!3GM2\Y["P 5 1 0 286 False 0 0 -1 304800 243 True 128 77 255 3175 3175 70 True True True True True 282 134217728 1 3 -9999996.000000 -9999996.000000 8 Empty 16711680 52479 26367 13421772 16737792 13382502 16777215 Bluebird -87325200 -87325200 (`@````````` 267 263 5 No. It sounds a too simple, but try this: The next time you run it and it starts to die, loosen the gas cap. It should start to run again. This means that the gas cap is clogged up with dirt. It is not vented properly, causing the carburetor to not get gas.
Jim
Jun 10, 2009 | Garden
What is the correct fuel mixture for this machine
Every Stihl I have ever touched requires 40:1 fuel mixture.
Jun 02, 2009 | Garden
Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In Line Edger Logo
344 people viewed this question
Top Worx Garden Experts
Tim Whalen
john milligan
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
