Question about Car Audio & Video
Audiobahn 12' subs and audiobahn amp
What kind of amp do i need for 2 12 subs by audiobahn want a audiobahn amp
  • omeeze Dec 21, 2007
    2 aw121t subs bye audiobahn need a audiobahn amp as well and what kind of sub box is good for the subs going in a dodge chager 07'
  • Anonymous Mar 13, 2014
    what amp do i need for two 12" sound Xtreme subs 1400 watts each
    Problem Solver:
  • 7 Answers
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Posted on Dec 21, 2007
  • Brian Smith Dec 21, 2007
    The sub you have can handle 550W RMS with a 4 ohm coil. When wired in parellel, you will have a 2 ohm load on the amp. That is when you wire both positive and negative terminals on the subs together. (Recommended if you only want 1 amp)
    Go with either the A1500HCT or A2300HCT
    The 1500 is 1000W x1 when running a 2 ohm load.
    The 2300 is 1200W x1 when running a 2 ohm load.
    One is slightly under powered, and the other is slighty over. In my experiance, go over, and turn the amp down a hair. Cleaner bass when your not pushing the limits of your amp.
    As for your box. This comes down to what kind of music you listen to, and what kind of system you are putting together.
    A ported box that gives you about 2 cubic feet per sub is a good box if you just want some loud bass with your music. If you listen to Rock, consider a Sealed box at about 1 cubic feet per sub.
    A ported box will allow your bass to be louder, but a sealed box will allow for tighter sounding bass, but won't be as loud.
    The box can be bought at many locations including Best Buy and Circuit City.
    When tuning your system, listen carefully. when you turn it up, make sure your speakers are not clipping. (sounds like a slapping noise) If they start clipping, turn it down, or you will blow a sub.
    hope this helps.
I have a audiobahn aw1251t 12 inch sub and punch 1000-1db amp how would i wire it up
as your sub is only rated to 400w rms simply connect the sub to either a or b channel outputs you may wish to use an rca splitter before the amp to feed both left and right audio channels into a single channel on the amp. WARNING connecting both channels on the amp to the sub will overload the sub and possibly blow it up so i highly recommend not doing so.
Mar 17, 2017 | AudioBahn Car Audio & Video
Hello..im trying to find a diagram on how to wire my subs down to 1 ohm..i have 2 12 in. Audiobahn alum12n..they are currently runnimg at 3 ohms on a hifonics 2500 watt 1 channel amp that only supports 1 2...
Hi, if you wire all voice coils in parallel, you will get down to 1.5 ohms. That is the lowest you can go with these 2 subs. Just hook the amps' positive to all 4 positive speaker terminals and the amp negative to all 4 speaker negative terminals. Please let me know if you have more questions, and thanks for using FixYa.
Mar 22, 2011 | AudioBahn Car Audio & Video
I have a 12 inch audiobahn 550 rms 4 ohm coil ported box and a dual box with 12 inch subs they say 550 max wattas a piece thats it waht amp do i need to get atleast 80% of my power in bass
Get a 1200 watt 4 channel amp that's 2 ohm stable. Bridge 2 channels into the single 550W rms audiobahn. Use the other channels for each side of the dual box. Turn the LPF or Low Pass Filter on and vibrate down the road.
Sep 25, 2010 | Car Audio & Video
AW1508X are they really any good?
The subs are good overall depending what kind of amp you are using. I personally use a ported box for all audiobahn subs.
Apr 30, 2010 | AudioBahn AW1508X Car Subwoofer
Is the audiobahn enternal a good sub i got a 12''
i think they are if you look into them the imortal is a bad as sub. but the enternal was design to even hit note the imortal cant.... you gotta make sure you have enough power to give them justice i like the a2300hcx by audiobahn look in to that amp they are nice..
Feb 03, 2010 | AudioBahn ADS12E 12" Sealed Enclosure Car...
Subs will not work right.
the subs coils are melted and shorting out so the amp shuts off
Apr 22, 2009 | AudioBahn AW1206T Car Subwoofer
I need wiring diagram for audiobahn AWES12P 4ohm speaker
you can go to audiobahns website. just fill in the specs like how many subs you have and what kind of amp/amps and it will give you all available wiring options.
Jan 26, 2009 | AudioBahn AW800 Car Subwoofer
Wiring subs
audiobahn.com can help you with the free diagrams under tect support
May 03, 2008 | AudioBahn A4075HCQ Car Audio Amplifier
Is it enough
Audiobahn subs are not too powerful and they can not handle too much continuous RMS, be careful they will heat up and tear off the voice coils off ur subs. run about 100 - 150 RMS at 75 HZ to each sub and keep the gains at about 3/4 this way you will avoid blowing out your subs. It also depends on the amp? What kind of amp is it?
Let me know if you wish. Otherwise
Oct 21, 2007 | MA Audio HK4000D Car Audio Amplifier
Car Audio & Video Logo
460 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
