Question about Toshiba Office Equipment & Supplies
Toshiba TDP-P4 Defect Ballast The lamp starts for ahalf a second, just a little flash. Tried a new lamp same thing. I suspect the ballast. Used de service manual and from Power Supply it gets the 5v wich is needed for the ballast. Also the fans and color-wheel are running properly. Is see prices on the internet for this part 526-0090-04 around 261 dollars. Somebody got experience with this ballast? Or is there a cheaper replacement? Where to get? Thanx in advance!
  • Anonymous Mar 26, 2014
    for defective lamp or if the ballast is defective
  • 2,236 Answers
The 5v from the power supply is just the signal voltage. the ballast, once ignited, sends about 350vdc to strike the lamp for a few seconds then lowers to 40vdc to maintain it. unfortunately, $261 is a standard price for it.
Posted on Nov 11, 2009
How can test my toshiba tdp-p9 projector ballas? before we order an expensive lamp.the problem is no display, the lamp is off, when the unit is power on.
OK you need sensitive ears. when the unit is switched on and the ballast power supply tries to start the lamp, it generates many 1000's of volts across the lamp to ignite the mercury vapour inside, much like a fluorescent lamp.
When this happens you should hear the snapping spark noise attempting to strike the lamp.
Sometimes it's very faint on some models and quite pronounced on others. It should last for about half a second or so.
If you cant hear it then maybe the ballast circuit or fuse or the 350V DC power feed is dead.
Another way is to have sophisticated metering across the lamp connector pins to detect the presence of the bursts of high voltage.
Hope this helps.
Apr 14, 2011 | Toshiba TDP-P9 DLP Projector
New lamp and still blinking lamp light.fan running fast and pulsing turns on and off and temp light blinks when using remote no light from lamp
MIne did the same thing, thought it was the lamp, bought a new one....still did it, figured it wasn't the ballast because the light came on for about 3-5 seconds - was told the ballast was bad, the ballast supplies high power to the lamp - if it is weak, it will not supply enough power and lamp shuts down. Bought a new ballast on Amazon for $62.00 - problem solved. I also tried a cooling fan - NOT the problem, was the ballast
Feb 16, 2011 | Samsung HL-R6167W 61" HDTV
52HM84 Toshiba DLP with apparent failed lamp (replaced ballast)
I found R3 on the original board to be open, along with reading an open on CR1, D5 and D6. All the other transistors and the transformer check out. The only thing I have to do now is find out the specs of the diodes. The replacement board also had CR1, D5 and D6 open (R3 was OK). There had been some threads on various locations where remanufactured boards had bad components (the transistors were changed but not some of the other components).
Jan 18, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Replaced bulb in projector and it still doesn't
Smetimes the other fan comes on when set to full bright. As your lamp is not lighting up, the other fan will not come on. If yo have replaced the lamp and it is still not working, then 9 times out of 10 it is will be the ballast.
Jan 05, 2010 | Toshiba TDP P4 Multimedia Projector
Toshiba Projector TDP-S20U. Horizontal Bar.
it can be also due to faulty ballast or the colour wheel due to which the horizontal bar is showing up.also if the buklb is giving less light /glow that means its weak should be the cause of this problem.as the voltage of the bulb should be checked  how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Mar 06, 2009 | Toshiba TDP-S20U Multimedia Projector
Standby light for toshiba
probably power supply or ballast (starts the lamp)
either would be $600.00 or so to repair, probably costs more than the projector is worth.
Jul 15, 2008 | Toshiba TDP-S8 Multimedia Projector
Hd50lpw175x7
Ballast Verification Process
1. Short out door switch (SP001)
2. Apply AC power and wait till DM module boots
3. Press power switch and observe spark gap on ballast
4. If spark gap arcs, suspect Lamp. If color wheel starts but ballast won’t strike
lamp, go to next step.
5. Measure BP252 on AC IN CBA for +300Vdc. If missing check door switch, cable
from AC IN CBA to switch and AC IN PCB. If correct go to next step.
6. Monitor pin 2 of BT251 for Ballast ON command from Light Engine. If present
suspect Ballast. If missing suspect Light Engine. Pin 5 of BT251 starts at 3.3V
after power switch is pressed and drops to .18V when the Light Engine sends the
start command. No change on pin 5 indicates Light Engine is suspect, change
on pin 5 with no ballast start, ballast is suspect.
Note: Lamp may arc but not start. Pin 5 of BT251 is "LAMP LIT" and goes to 1.48V
when lamp is lit. If ballast strikes lamp but lamp won’t stay lit, suspect Lamp.
Jun 09, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Power Failure, How serious a problem and cost?
Hi there
You will either be replacing the Main Power Board or the Ballast Board ( Lamp's powersupply ) The symtoms you described sounds like a faulty Ballast.
Both of the above parts are fairly cheap to replace.
Mar 25, 2008 | Toshiba TDP-T30U Multimedia Projector
No light
Most likely the lamp ballast in the power supply is blown, this was common in the P4 units. These units are more than 4 years old. They were OEM from InFocus. You can check on ProjectorCentral.com for cross reference info to the P4 (for parts info). Your unit may need repair, however it may cost more than the unit is worth (est. $150-$300) I can recommend PROJECTOR DOCTOR in San Diego CA, or ALLTECH ELECTRONICS in New Jersey for repair of this item. PJ DOC might have parts as they were a InFocus repair center as well.
Jan 22, 2008 | Toshiba TDP P4 Multimedia Projector
Toshiba TDP-S20 lamp problem
The lamp ballast which ignites the lamp has failed it sounds like. The red flashing lamp is the tell tale sign with a good lamp installed. Make sure the lamp door is closed too, there is a door switch that can also trigger the red lamp and no startup. There is a company in San Diego CA that can repair the unit called PROJECTOR DOCTOR
Nov 29, 2007 | Toshiba TDP-S20U Multimedia Projector
669 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
