Question about Intermec EasyCoder F4 Printer
Printer print one-third of the label and then stuck. After pressing button on printer goes empty label (sometimes one or two, sometimes more) and just after that goes good label. Often printer stuck on a half of sticker.
    President:
  • 2,976 Answers
You need to calibrate your printer to the label stock and clean the photo eye that the label passes over right before it goes into the printhead. Make sure the eye picks up the light. They MUST be in perfect alignment, normally about 1/2" from the side of the label. You should also make sure you have the correct label size AND orientation selected in the program you are running. Running a 6" X 4" label with the program set for a 4" X 6" label will stop the works.
Posted on Oct 02, 2009
When I print one label, the printer prints one label and send out two labels out. One is the printed one, the other one is empty. What's wrong with it?
  • Open the printer and remove the labels roll.Re-load it making sure its well fixed.
  • Turn the printer off.
  • Press and hold the green feed button and turn on the printer.Release button after the first flashing of led light.The printer will run a print test.
  • Turn it off and on again.
  • Now print.Problem solved?If not,
  • Open the printer[while still on]and disconnect power.
  • Close it and reconnect power.Turn it off and on again.
  • Now print.
Hope this helps.Thanks!
Oct 10, 2011 | Zebra LP 2844 Thermal Printer
The printer is new. When you press the feed button,it does dot feed 1 label. What do I need to do to correct that?
First download a driver ans install it.
Second program your label size.
Third Select the correct settings (Detection, protocol etc..)
Print a label.
Now when you press feed you'll get a label
Aug 15, 2011 | SATO CL608e Thermal Label Printer
The machine prints about 12 labels and then prints about 25 empty ones, prints 12 and the pattern repeats. Restarted the computer three times and restarted the printer five times, nothing helped.
Hold in the Feed button for 4-5 seconds, which causes the printer to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
Feb 18, 2011 | Datamax DMX-I-4208 Label Printer
I have a Zebra s600 that is set to 30 darkness and the head is screwed down fairly tight. I can print this way but if the printing lightens up, I don't have any more adjustment. The barcode reader picks up...
0.print config label (printer off, press Cancel button and tur on printer, wait 5 secunds and relese button)
1.press the last button until the ligth set on Darkness (Darkness on),
2 press the 3rd button 10 times( darkness down from 30 to 20 (3rd button=less 2nd button=more),
3.press 2 times the last button untill the 3 leds flash(save)
4.turn printer off.
5.Press pouse button, turn printer on, still pressing for 8 secunds, and then release te button.
6.The printer go to print the test label, let run 3 or 5 labels, then pause.
If not happy, repeat steps 1 and 2 (less times 2 or 3 times at the time and save)
print configuration label again ans se if you happy.
If the printer still going to darkness 30, chek if you forgot to save or check the driver settings and change.
Last option Resect to Factory Defult (this drop darkness to +10)
Oct 29, 2010 | Zebra Stripe S600 Thermal Label Printer
Not printing all labels
Do a calibration, this should fix the issue. Also make sure that the label stopper (silver peg on label holder) is pressed firmly against the labels. This will stop the labels from sliding around during a print, throwing off the calibration. Also check to make sure the sensors are free of any dust.
Jun 17, 2010 | Zebra 105Se Thermal Printer
Our Zebra 105se printer has started missing labels. For ex., it will be printing a batch of 40 and every third or fourth label it shoots out an empty. sometimes it puts out two empty labels but in the end...
Clean your platen roller. It's the white rubber roller (that turns and pulls your labels through your printer) located under your printhead. When this gets slick it causes your labels to slip while printing.
You should use rubbing alcohol to clean it. Your computer guys may also have some cleaning wipes in a foil packet that you can use.
Jul 13, 2009 | Zebra 105Se Thermal Printer
TLP2848Z blinking red, will not print
1: Is it a TLP2844 or a TLP2844Z.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
Calibration:
If its a TLP2844. Load media. Connect power.
Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
Calibration:
If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute)
Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
Dec 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
"490: MP tray is empty" message when trying to print labels from Word 2003
The MP tray referred to is the Multi Purpose tray and is located at the front of the printer. To access it, you need to find the 2 indentations at the side of the front feed assembly and pull them towards you. this then gives access to the MP tray. Don't forget to press the blue button after loading the paper. Your user guide/manual will give clear instructions and pictures. It may also be called manual feed tray. Once loaded with the correct paper press the online button and printing will start.
Oct 18, 2008 | OKI C5500n Printer
Just installed my 2844
Bask11,
sounds like the printer needs to regap itself. Turn the printer off, hold the feed button down and while holding the feed button, turn the printer back on. As soon as it flashes, let go. It will regap itself. When it stops moving, press the feed button once and there should be a priinted line that says 'out of dump'. The printer should be ready to go then.
Mar 11, 2008 | Zebra LP 2844 Thermal Printer
Printer not lining up and display doesn't work
You can adjust the display contrast by pressing and holding the MENU key for 10 to 20 seconds to modify the LCD contrast level.
Jan 17, 2008 | Datamax M-4208 Thermal Label Printer
Intermec EasyCoder F4 Printer Logo
198 people viewed this question
Top Intermec Office Equipment & Supplies Experts
pkwc
Paul Bade
donjackson
Level 1 Expert
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
