Question about Dishwashers
AEG Diswasher Model / Favorit 44080IM PNC 911925601/01 (located in UK) Wash cycle finish light flashes 5 times in sequence then starts again - please advise the meaning of this error signal ? History Machine started running immediately door was closed before any programme selected filled with water and main was motor runs and circulates water Water is not heated and detergent door has not opened Machine will continue to circuluate water until turned off If reset used then the sequence above merely restarts Spare programmer installed - no effect.
  • 2 more comments
  • adrian_covil Oct 02, 2009
    There is no blockage in the spray arms of filters the water circulates normally and machine is only a couple of months out of warranty.
    What I need is someone with specific access to AEG manuals or experience of this model.
    Thanks for the suggestion
    The machine is only a few months out of warranty , it has been suggested that filters and spray arms may be blocked this is not so and water circulates normally.
    AEG specify some of the fault light sequences in their user manualbut not all of them, what I need is someone that has specific experience of AEG and / or this model or has access to the service manual for the same.
    I am actually a qualified engineer myself so obvious things have already been checked.
    Further info:it had been suggested that filters / spray arms are blocked this is not so. I had said in my description that water circulates normally this is so and there are no blockages.The machine is fairly new and only a few months out of warranty.
    I am actually a qualified engineer myself and so obvious / simple items have already been checked.
    AEG list some of the error signals in the user manual but not all. What I need is someone which specific AEG experience or access to the service manuals to check out the indication.
    rgds
    A.Covill
    No the anti flood device is three lights in sequence if the anti flood is tripped the machine stops running.
    The underside of the machine is dry the antiflood switch is visible and not tripped.
    this is not the cause I understand that you are trying to help but would appreciate no wild guesses
  • 3,741 Answers
1 blink is machine is having major power supply problem.the power supply board needs replacement. ----------- 2 blink is CCU error.that control board problem. ----------------- 3 blink is the CT error.that is control touch pad error.that is the front panel button pad assembly gone faulty. ----------------- 4 blinks is the MCU error . that is motor controlling unit is faulty. ----------------- 5 blinks is the heating element problem.and 5 blinks also relates if motor speed is got weak.so both the things has to be checked.eith the heating element is cracked or the coils in the motor are getting weak. ---------------- you can order the required parts from ---------- www.partsselect.com ---------------- and in some cases it has been seen that this light blinks five times if any of the button is got stuck up in the front touch pad panel.so press all the buttons and check out are they proper or got stuck-ed in. ------------------- thanks.this will help.please do rate the solution.thank you for using fixya.keep updated.
Posted on Oct 02, 2009
    President:
  • 1,653 Answers
This means that the Anti Flood Device has been activated and you should shut off the wtare supply to the machine and call a Service Engineer ASAP as there is a major fault with the dishwasher.
    Genius:
  • 1,689 Answers
Adrian,
you may want to check on the link below
the lights that flash are a fault code.this should be able to be readand a diagnoses made.if aeg have been out to it get them back as thework they do comes with warranty.if needs be they should take it in anddiagnose it in a workshop which will eliminate supply issues.could befaulty pressure hose filling with water or sump float sticking.pouringBOILING water down pressure hose into the sump seems to clean them andmake them work but this may no be relevant to your dishwasher fault
http://www.howtomendit.com/answers.php?id=135959
  • 10,515 Answers
Usually 5 times flashing refers to blocked spray arms.However, it normally means there's a blockage in the spray pump or the filters.Take your filters out and take the spray arms off, try the machine again.It's basically saying it's being starved of water.
If problem still persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Do accept the solution, if 100% satisfied from my service!!
Why my AEG F55080vi stops after drain cycle (program beginning) and then it stops and I hear 2 beeps and 2 flash continuously?
Definitely, water drain time-out. Error code i20.
The pressure switch doesn't return to EMPTY (1-2) after two drain phases lasting 120 seconds.
Possible causes:
Drain circuit obstructed/blocked; drain pump
interrupted or jammed (foreign bodies); level
pressure switch blocked on FULL (1-3); hydraulic
circuit of pressure switch obstructed; wiring faulty;
circuit board faulty.
Thanks to your detailed description of failure I conclude that in drain phase (after starts drain pump) leaks water and causing a short circuit. I would thoroughly reviewed drain hydraulic circuit. If is alarm displayed and there is no water inside dishwasher then check heater and anti-interference suppressor.
Dado
Jul 12, 2014 | AEG Dishwashers
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
Aeg
Here is a link to the manuals site - I suggest you search by PNC number (you should find it on the label somewhere)
http://www.aeg.co.uk/Support/Manuals/
Apr 09, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
In which way can i reset my dw AEG favorit F 65450 vi?
Hold and press the end cycle by 5 seconds, and try again. However you can disconnect the c.breaker by 5 seconds too. and try again.
Merry Christmas.
Dec 19, 2013 | AEG 24 in. Favorit 86050Vi Built-in...
Favorit 44070 3 flashes on end of cycle light. No water loading. Does not start
you need a water valve if the overfill float is not malfunctioning
Aug 27, 2012 | Bosch Dishwashers
MANUAL
AEG has the manual for the L87490FL on their support site. I found 5 different PNC identifiers for this model. The English versions of the manuals can be found by searching for this model here: http://www.aeg.co.uk/Support/Manuals/ . The direct link for the 91453121700 version of the L87490FL is http://www.electrolux-ui.com/2011/132/938930EN.pdf . If this link doesn't work, start at the support link above.
I hope this helps.
(for other language versions of the manual, search at the AEG support sites for other countries.)
Jul 14, 2012 | AEG Washing Machines
I NEED A MANAUL FOR MY DRYER
go to AEG website
type : LTH57800 for model number.
The PNC number (which inside the door - bottemleft) might be the same, but otherwise just pick one... teh difference is some internal components revision.. most of the time not relevant for users
Sep 04, 2010 | AEG T57800 Electric Dryer
The clean light is blinking diswasher won't start
Push these buttons in this order High temp wash > Heated dry>High temp wash >Heated dry all the lights will come on and this will reset the board and run it through a short test cycle but more than likely it will come up again,It's a failure in the heating cycle either the heater itself or the turbidity sensor which sits mounted up into the tub right behind the drain pump...hope this helps
Sep 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Access to flow thru heater
On the 40660 washer this element is in line with the top sprayer arm pipe and is at the back bottom of the washer. Easly reachable by removing the back bottom plate. Has a clamp on each end and a electrical push on connector.
Apr 22, 2008 | AEG 24 in. Favorit 40650 Free-Standing...
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
Dishwashers Logo
67 people viewed this question
Top Dishwashers Experts
