Question about HP LaserJet 1010 Printer
I can't install hp 1010 driver, message appear :"an error occurred during the instalation of the device a dynamic link library (DLL)initialization routine failed"
SOURCE: Error - Scanner could not be initiliazed
I have a MacBook Pro - a year and a half old - and recently upgraded to Leopard, which caused all sorts of problems with my HP 8160 photosmart (which worked pretty well before that).  I downloaded the necessary drivers/softward from HP for Leopard and it worked okay - but than I also started getting the "scanner cannot be initialized" messages (doing scan all wireless).  Anyway, all I did was go to applications, drag the HP softward to the trash and then went back to the HP site and downloaded the software and drivers again, and ran through the simple installation process again and now my scanner works again. Don't know why - but saw the suggestion on another site and it worked for me.  Here is the link to the HP site for software/drivers - select your operating system and it will direct you to the right page.
Posted on Sep 09, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: Error in Installation CD of HP2015dn
ISSUE: When trying to install an HP LaserJet P2015 printer, a MSVCR80.dll error message is received.
SOLUTION: To resolve the issue, complete the following steps:
  1. Before installing the printer, disable any Anti-Virus and/or Firewall software. To disable the Anti-Virus and Firewall software in Microsoft Windows XP and Microsoft Windows 2000, press the Ctrl+Alt+Delete simultaneously to enter the Windows security screen. Then select Task Manager , select the Process tab, select Anti Virus and/or the Firewall Image , and end process on the software.
  2. Disable XP firewall. To disable the firewall in Microsoft Windows XP, right-click My Network Places , select Properties , right-click Local Area Connections , and then select Properties . Select the Advanced tab and remove the checkmark from Internet Connection Firewall .
  3. If the issue persists, before trying to install the printer, we suggest you complete follow the steps:
    1. For system clean boot to perform, click Start , click Run , type msconfig in the Open box, and then click OK .
    2. On the General tab, click Selective Startup , and then clear the Process System.ini File and Process WIn.ini File , and Load Startup Items checkboxes. You cannot clear the Load system Services and Use Original Boot.ini checkboxes.
    3. On the Services tab, select the Hide All Microsoft Services checkbox, and then click Disable All .
    4. 4. Click OK , and then click Restart to restart your computer.
    5. 5. When the system restarts, click Start , and Printers and Faxes . Delete all the printer icons.
    6. 6. Click Start , click Printers and Faxes , click File , click Server Properties , and then click the Drivers tab.
    7. 7. Select all the printer drivers individually, and click Remove . Remove all the drivers one by one.
    8. Click the Ports tab and delete the listed TCP/IP ports individually by selecting the Port and clicking Delete Port .
    9. Click OK , and then restart your computer.
    10. When the system restarts, begin the installation process. You may insert the installation CD into the CD-ROM and follow the onscreen installation steps to install the printer locally.
      NOTE: Do not connect the printer to the computer until prompted to do so during installation.
Posted on Nov 03, 2008
sunny_magic1
  • 23 Answers
SOURCE: unable to install software on hp c4480
This is a very very tricky issue.
For a long period of time there was no known resolution for this.
but now you can resolve this too.
Follow the mentioned steps very carefully:
>> use the following links depending on your OS:
for Windows XP:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-62152-3&lc=en&dlc=en&cc=us&product=3560280&os=228&lang=en
For Windows Vista:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-62152-3&lc=en&dlc=en&cc=us&product=3560280&os=2093&lang=en
click on download only and download the software for PHOTOSMART C6380
>> run it and install it(keep the USB CABLE DISCONNECTED before installing)
>> during the installation you will be prompted to connect the usb cable.
DO NOT CONNECT THE USB CABLE
>> there will be a small check box that will tell you to check it if you want to connect the cable later.
>> CHECK THAT BOX and continue with the installation.
After the installation completes successfully...
insert the disc for your printer (i.e C4480)
Posted on Sep 25, 2009
Testimonial: "Thanks a million"
  • 73 Answers
SOURCE: i installed recently HP officejet
Hi There, This is a known issue with this device. Please follow the below steps to fix this issue : Try to do a complete uninstall
*first step*
-run installation media (CD / Download) software
-select uninstall and on the process, select uninstall all hp softwares associated the with the device
-after uninstall , select restart later to reboot the computer later
-go to start > control panel > add/remove programs (XP) programs (Vista)
-uninstall any existing HP softwares (note: for hp computers, skip this process)
-restart later
*2nd step*
-open contents of the installation media
-if you're using the installation CD. go to my computer, select the drive which has your cd in (eg. E:/ , D:/ ) right click on the icon and select open / explore.
-if you're using a downloaded software, click on start and click on run (XP) startsearch (vista), on that box, type in the command ( %temp% ) and press enter. it will open up temporary files folder.
-locate the file that starts with 7z (eg. 7z001cs1) and open it and now you are in the contents of the installer
-on the contents of the installer, locate UTIL folder and open it then locate CCC and open it as well
(note: check your operating system if it is running on a 32-bit or 64-bit . you can check it going to start>control panel>system)
-on CCC folder , locate uninstall L1 (for 32-bit) uninstall L1 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later
-on CCC folder , locate uninstall L2 (for 32-bit) uninstall L2 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later
on CCC folder , locate uninstall L3 (for 32-bit) uninstall L3 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later (repeat uninstall L3 steps for 3 times)
**********important**********
(do not run uninstall L4)
contiunued in the next post ..............................
Posted on Nov 14, 2010
muntejaya
  • 10421 Answers
SOURCE: when install hp deskjet d1668
Please install new driver and get it downloaded here : www.siliconguide.com > Drivers > Printer > HP
www.opendrivers.com/.../hp-free-driver-download.html
www.brothersoft.com/downloads/hp-printer-driver.html
Jay nbal
Posted on Feb 13, 2011
Hw to remove run DLL error in microsoft window 8.1
run.dll is a DATA LINK LIBRARY FILE if it is sikped in installing windows {or} other any software ,malware,adware virus problem you can fix it by using DLL suite { the dll suite download and install it will have a lot of serials keys in serial.ws.com } you will enjoy the features of windows
Apr 06, 2015 | Microsoft Computers & Internet
The ordinal 120 could not be located in the dynamic link library iertutil.dll
iertutil.dll is a dynamic link library used by Internet Explorer. Ordinal 120 refers to something inside the dynamic link library. These errors typically occur when the file is corrupt or there is a version mismatch (eg. IE 9 using iertutil.dll from IE 8). A reinstall of IE should fix this problem
Ericthecmh
Oct 05, 2011 | Microsoft Windows XP Professional for PC
I make window on my pc but it take me a error stop:c0000221unknown hard errorsystemrootsystem32 tdll . dll
This problem may occur if the file that is described in the error message is corrupted. The following files are checked for integrity when Microsoft Windows XP starts:
  • All driver files (except those that are loaded by the system loader to start. the computer)
  • All dynamic-link libraries (DLLs), including User, Graphics Device Interface (GDI), Shell, Kernel, Ntdll, Crtdll, and others.
This problem may occur if you install an inappropriate driver for your hardware. For example, you receive one of the error messages that are described in the "Summary" section if you install a MIPS driver on an X86-based computer.
This problem may occur if an Iomega Zip drive is on the same integrated device electronics (IDE) cable as the hard disk drive.
The third-party products that this article discusses are manufactured by companies that are independent of Microsoft. Microsoft makes no warranty, implied or otherwise, regarding the performance or reliability of these products.
Apr 20, 2010 | Microsoft Windows XP Professional for PC
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
Path\File_name
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
c:\winnt\system32\ntdll.dll
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
<path>\<file_name>
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
GOOD LUCK :-)
Feb 03, 2010 | Intel Computers & Internet
TWAIN Driver
Reload the camera software onto your computer after you delete the old version. The dll is a dynamic link library and must be in the proper directory to work. The program is in your startup files. That's why you get the message everytime you start your computer.
Dec 13, 2017 | Cameras
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Cesar.pratto@gmail.com
Hi , yes it's a known problem and Microsoft/DLink both has confirmed that.
Please download the updated drivers by clicking on the link. below. AS er your information your router's model no. is the 6th entry on the page.DWL-G630_revE. Download and re-install the drivers.
It will fix the problem
http://support.dlink.com/faq/view.asp?prod_id=3002&orig=1
For more information
http://support.microsoft.com/kb/950720
Jun 05, 2008 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Compaq pc recovery problem
hal.dll is a dynamic-link-library.
Not necessarilly a part of your operating system.
could be a printer or other peripheral device driver.
try re-installing all of your other hardware device drivers.
Mike @ compurepair.
Apr 04, 2008 | HP Compaq Presario V6000T Notebook
Pixe view TV Tuner CArd
you can grab the xp drivers here
http://www.prolink.com.tw/
and for watching tv, you may be able to use this
chris tv lite freeware
http://www.softpedia.com/progDownload/ChrisTV_Lite-Download-2301.html
Nov 15, 2007 | Televison & Video
Application won't start up (VIsta)
if you managed to get the driver installed, you should get an option to use either windows wireless management or the software that came with the adapter, you may be able to dissable the cards software and use windows own
Sep 09, 2007 | D-Link AirPlus G DWL-G510 802.11g/b...
HP LaserJet 1010 Printer Logo
240 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
