Question about Garden
Change engine oil
How do I change the engine oil myself
  • 881 Answers
The mower has a engine so the drain plug must be at the lowest point and the lowest point is just above the blades So turn the engine off turn mower upside down and you will find a drain plug square head 4sides and it is tapered /un do it and let all oil out by standing it back on its wheels/when drained refit bung only as tight as it was getting out and turn back on wheels and refill with 20W 40 OIL
Posted on Oct 02, 2009
Where is the oil change reset button. What oil is best preferred?
To reset the oil change warning light:
1. Turn on the ignition (not the engine).
2. Hold down the brake and accelerator for twenty seconds until the warning light goes off.
Mar 03, 2015 | Cars & Trucks
I want to do 30000 mile oil change myself. what do i need to look for or change besides the oil change?
There is an oil drain plug on the bottom of the engine. Drain the oil, as well as replacing the oil filter which is usually on the side. Real easy process. The hardest part is keeping from getting any oil on the floor or the engine.
Dec 25, 2010 | 2003 Harley Davidson FLSTF Fat boy
Does the machine need an oil change, if so how often and can i do it myself?
i would change the oil every 100 hours or six months in the engine.
and would change the oil in the pump every 12 months.
to change the engine oil,look for a 12mm or 13mm bolt at the base of the motor.
it should be at the front of the engine.undo bolt & drain oil into a container.
tighten bolt up & fill engine with new oil.
Dec 09, 2010 | Northstar Pressure Washer 3000 PSI
How to change the oil on a 2005 Kia Sedona
The oil filter is towards the front of the car, underneath on the passenger side, at the corner of the engine cradle. Loosen the drain plug and drain the oil. Make sure the old oil filter gasket came off with the oil filter. Reinstall the new oil filter. Reinstall the drain plug and fill with 5 quarts of 10w/30 motor oil.
Apr 25, 2010 | 2005 Kia Sedona
"Change Engine Oil" still showing after oil change.
You can do it yourself. Turn you key on and press the fuel pedal 6 times then shut your key off and back on.
Apr 22, 2010 | 2004 GMC Yukon
1995 BUICK PARK AVENUE SUPERCHARGE ULTIMA
On the GM car the engine will have to be removed to change your oil pump, however it is easiest to pull engine and transmission as an assembly. My question is why do you think you have a failed oil pump??? If oil pump fails it usually screws up engine too....
Aug 27, 2009 | 1995 Buick Park Avenue
Engine oil change - Quantity
Its 3 1/2 Quarts, but you might as well put a full 4 quarts in if it goes through that much. make sure you change the filter aswell! dirty oil will not cause your engine to go through it any faster. Is the oil leaking or is the engine burning it?
Jun 16, 2009 | 2002 Hyundai Accent
2008 yukon first oil change
THE OIL PAN IS GOING TO BE THE LARGEST PAN AT THE BOTTOM OF THE ENGINE. THERE WILL BE ONLY ONE PLUG ON IT. TO RESET THE OIL CHANGE REMINDER FOLLOW THESE STEPS. TURN THE KEY TO THE ON POSITION, BUT DO NOT START THE VEHICLE. WHILE THE KEY IS ON PUSH THE ACCELERATOR PEDAL ALL THE WAY TO THE FLOOR THREE TIMES. THIS WILL RESET THE OIL REMINDER.
Jan 24, 2009 | 2008 GMC Yukon
Garden Logo
790 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
