Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Amillo pro 2010 screens gone black tried new inverter still no good cleaned ram no good the xp pro disc is off this laptop but got invalid message when reinstalled the screen went blank two days later cant even get it to boot or get on bios
  • 71 Answers
Try useing external monitor?
Dumb Question.
Try switch monitor button? Fn + F5 (together) usually
Hard way,
Remove hard drive, maybe even CD Reader, Floppy.
Power on system
Posted on Apr 10, 2010
I want to remove win7 from my compaq cq57 laptop (intel core) and replace it with xp pro
In your case try the RAM part 1st.
Blue Screen Of Death
  • You may need to roll back system with System Restore (press F8 during boot and choose safe mode).
  • Uninstall last program(s) that was installed, again in safe mode.
  • Re-install Windows. Clean install works best.
  • Test one DIMM at time. One slot at a time. To eliminate possible bad RAM.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 01, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Acer travelmate 220
Do you hear any beep code? If so, first check the RAM (you may try to clean the golden colored area of the ram but carefully and restore it in the laptop. If you steel hear some beep code you may have to try with other good RAM with the same value ).
If not and black screen with some message, please post those details with your problem.
Jun 25, 2012 | Acer Computers & Internet
My MX6214 Laptop will not start windows XP, a series of white vertical lines comes on in the bottom of the screen and after they all turn solid windows screen comes on but never starts, I tried a new hadr...
THERE SHOULD BE PROBLEM WITH THE RAM. PLS CHANGE THE RAM AND TRY. OR IF YOU HAVE 2 RAMS INSTALLED TRY REMOVING 1 AND TRY. THE RAMS ARE GENERALLY PRESENT IN THE CENTRE IN THE BOTTOM SIDE OF THE LAPTOP. PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Gateway MX6214 Notebook
My e-machines etower 633is won't boot up. The beginning black screen comes up then the E-machines screen and that's as far as it will go. It gets stuck there. Can you give me some idea what is causing...
I cant really seem to understand but if the computer beeps then you should take the RAM out and clean it and re-insert it. and try again. Sometimes the processor can give that kind of problem if it is faulty.But if after cleaning the RAM it still doesnt work please take it to the tech department.
I hope this solution is helpful.
Sep 26, 2010 | E-Machines etower 633is PC Desktop
Check by rebooting it to BIOS--Press Del or F1 during boot....
Choose F8 option during startup intial stage-Windows
Choose Safe Mode----If it works---then No Problem with Hardware,,but with Operating System--Repair or Reinstall Operating System using Valid XP Serial Key
Oct 01, 2009 | Computers & Internet
I have a hp2000 with a black display screen
your problem is a faulty ccfl BackLight Inverter, the display uses the backlight to illuminate the lcd screen, the inverter is used to illuminate the cold cathode light in the back of ther lcd theirs countless places to laern about it on google
Aug 20, 2009 | Dell Latitude D600 Notebook
DVD burning on Seimens Li Amillo Laptop
When you are finished burning a disk you have to make sure you finalize the disk.
Nov 28, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Restore factory settings on a fujitsu siemens amillo pro
You should be able to fix this simply by inserting the original Cd that came with the computer and following the onscreen instructions.
Or the startup disks (if created) when you first used your laptop.
Alternatively If you do not have the one that came with your computer then you should be able to purchase one from ebay quite easily, and then insert it and follow the onscreen instructions.
I hope this helps you, Chris
Nov 03, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Upgrading memory
I have found a link for you from where you can download the mannual for the notebook you are using. This mannual explains that how you can replace the memory of the notebook.
Open link
http://www.fujitsu-siemens.com/support/manuals.html
Under "Select Product" - Select Notebook - Amillo Pro - Amillo Pro V2xxx - Amillo Prov 2000
Download and open
Basic informations on mainboard Technical Mannual
You will find the details in that.
I hope that this resolves your issue.
Sammy
Nov 28, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
331 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
