Question about Brother MFC 3220C All-In-One InkJet Printer
How do i clear memory on the brother mfc 665cw
Where is the sevice button on the brother mfc665cw
Posted on Jul 21, 2010
  • 215 Answers
Hold down the service Button and replug the machine, old down servie button for some time.
"Maintenance" Mode will appear in the display.
Maintenance codes are:
01 reset
91 reset without memory
99 End
This is basically for Brother MFC 4820 C
please try with your printer also
Hope this helps you
Thank you
Posted on Oct 02, 2009
    Sergeant:
  • 244 Answers
First try clicking on 'start', then '.control panel'. select the 'printer/fax/scanner' icon, click on your brother printer icon (right click), go up to 'files', see if their are any printing jobs waiting in the queue and delete them ( if they're not important!). shut down your computer, unplug the usb from your printer, unplug the printer- let it set for 10 or so minutes. plug it back in, boot your computer, re-plug the usb to your printer, and it should be cleared!
good luck!
4 Suggested Answers
Mix-it-up
  • 832 Answers
SOURCE: Cleared printer jam, message Unable to print 30
...and 50? Is it toggling between those two error codes?
Anyway, see here what to do:
http://www.fixya.com/support/t211210-brother_mfc845cw
Posted on Mar 11, 2008
eagle338
  • 4889 Answers
SOURCE: MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
Posted on Jun 11, 2009
komguy
  • 2306 Answers
SOURCE: How do I clear
51 error says that the purge assembly is stuck and not cycling properly. If you can power up and get the printhead to the center and unplug again, look with a flashlight in the far right corner where the printhead parks for any paper scraps or things that don't belong and remove them it might work again. Otherwise a shop repair to possibly replace the cleaning assembly.
MFC-665CW won't turn off?
Brother MFC-665CW Quick Start Manual - ManualsLib
www.manualslib.com > ... > All in One Printer > MFC-665CW
View and Download Brother MFC-665CW quick start manual online. Brother MFC-665CW: Quick Start. MFC-665CW All in One Printer pdf manual download
Aug 30, 2015 | Brother MFC-665CW All-In-One InkJet...
How to get an mfc 665cw to print in black and white only?
I Suggest You To Watch
Brother MFC 665CW FAQ Troubleshooting Others To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Jan 30, 2011 | Brother Office Equipment & Supplies
We were sold a MFC 665CW and Noel Leaming Co.
Here is the link for the Manual (is English):
http://www.brother-usa.com/SiteSearch.aspx?sk=mfc%20665cw
Select the "Users Manual" to begin with. IF you also need the drivers, Select the "View All Downloads for MFC-665CW" and THEN Choose the MFC-665CW in the Drop-Down-Box-Listing. Choose from there for your Driver Support Download.
Jun 12, 2009 | Brother MFC-665CW All-In-One InkJet...
Jun 11, 2009 | Brother MultiFunction Center MFC-440CN...
I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Brother Multi-Function Center MFC-665CW...
How to clear memory from fax? MFC-665CW
Hi Jodi,
I have a Brother MFC 8860 DN Laser.
Just contacted Brother and they told me the following:
1. Switch off machine from Mains
2. Press and hold the Red "Stop/Exit" button
3. Switch on machine from mains.
It worked fine with me and the memory is back to 000 now.
Hope this helps.
Sep 18, 2008 | Office Equipment & Supplies
Mar 11, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 3220C All-In-One InkJet Printer Logo
1,526 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
