Question about Cell Phones
Cannot enter name against any speed dial number on lg gw300 mobile phone
NEED HELP IN SET UP SPEED DIAL NUMBER
To enter or edit a speed dial number on the Uniden D1788, go to PHONE BOOK (the book icon), when SELECT appears use the up/down arrows to select the previously entered phone book name, press MENU/SELECT (EDIT appears), press MENU/SELECT (EDIT NAME appears), press MENU/SELECT (EDIT NUMBER appears), press MENU/SELECT (SPEED DIAL - XXXXX) appears. Now, to assign a speed dail number, use the up/down arrows to select the desired speed dial number (Expl: SPD2) and then press MENU/SELECT to save it. The selections are SPD0 to SPD9 and also NO SELECTION to remove an existing speed dial number. You can also assign a speed dial number that's already used to a different phone book name. It will remove it from the old name and reassign it to the new name. Use the above procedure to assign a speed dial number to a new phone book entry when SPEED DIAL appears.
Nov 05, 2012 | Uniden DECT 6.0 Cordless Phone System...
I bought an LG GW300 from the pawn shop and I'm trying to reset the phone but it won't allow me as I need to enter the code which I do not know and also Dollar Dealers didn't give me one. So...
Now, on your LG GW300, Dial 1809#*500# and choose Factory reset. No code required and phone won't ask: "Are you sure?". All settings will be reset to default values, including the user code (0000 is the default code after)
Regards
Oct 03, 2011 | LG GW300 Cell Phone
I'm having problems with a Samsung KPDCS-12B LCD phone I've recently been given, I need to add myself to group 501 to take calls for my department (Plumbing) but my phone (Extension 250) is...
Hi you need to do this in 2 parts - firstly to add yourself to group 501 follow the step-by-step instructions which are on the video I have posted. Then follow this to add a mobile number to the directory;
Press the TSFR key
Enter 200
Enter code 1234
=/- key to enable
Speaker key
dial 705
I.e. once in 705
Type in speed number, the cursor will tab over to speed dial slot.
Enter 9 followed by the phone number.
Press 12th button down,
Enter name,
Press 12th button. (You will be back at the speed dial.)
Press tab, then enter the next speed dial slot you wish to program.
NB-
( 705 - Speed dial 12th Button down to toggle between)
( 706 - Speed Name the 2 MMC
Jun 08, 2011 | Samsung DCS 12 Corded Phone
Ive got a puk number for my sons LG GW300 but dont know ho to enter it can you help
Hello Bag.
When you switch on the LG GW300 phone it will ask for code. Please enter the PUK code you will have and will unlock the phone.
Jun 01, 2011 | LG GW300 Cell Phone
Want to know my pin2 for my lg gw300
PIN numbers are not based on phone model but the SIM cards.
Call your mobile operator for the PIN numbers. They will provide the PIN numbers after confirming your identity.
Mar 31, 2011 | LG GW300 Cell Phone
How do i unlock my lg gw300 for tesco network after i have the IMEI number so that i can put a vodafone sim card in my phone?
Hi , welcome to fixya.com . I think you will have to shell out some money to unlock your cell phone. Here is the link http://www.gsmliberty.net/shop/lg-gw300-unlock-codes-p-3087.html .How it's Done ? Removing the network restriction has never been easier! All you need to do is supply us your GW300 Serial number (IMEI) and within the indicated time frame, They will email your unique unlock code. Simply dial in the network unlock code supplied using the instructions provided just like you would dial any phone number. Finally enjoy your unlocked LG GW300 to use it with any active compatible GSM SIM card. Hope this helps you. Have a nice day. Bye.
Mar 13, 2011 | LG GW300 Cell Phone
Dont know my puk code for LG GW300
Please don't enter any puk entry your self. Please ask your network provider. He will provide you the details. Its is not for your mobile but it is of your SIM.
PLEASE NOTE THAT ENTERING WRONG PIN/PIN2 THREE TIMES WILL BLOCK YOUR PIN/PIN2 RESPECTIVELY.
IT WILL THEN ASK FOR PUK/PUK2. AND IF YOU WILL ENTER PUK2 WRONG TEN TIMES. YOUR SIM WILL BE BLOCKED.
So you should contact your customer care and get the necessary details about puk numbers.
Sep 24, 2010 | LG GW300 Cell Phone
Speed dial not working
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else.
YOU WILL NEED A PEN AND PAPER.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Speed dial list
***Storing a Number for Speed Dialing*** 1 Press Phone Book on the control panel. 2 Press Phone Book or the scroll button (􀂥 or 􀂊) to display ?Store&Edit? on the bottom line of the display. Press Enter. 3 Press Enter when ?Speed Dials? appears on the display. The display prompts you to enter a location number, showing the first available number. 4 Enter a one or two-digit speed dial number between 0 and 79, using the number keypad or scroll button (􀂥 or 􀂊), and press Enter. If a number is already stored in the location you chose, the display shows the number to allow you to change it. To start over with another speed-dial number, press Upper Level. 5 Enter the number you want to store using the number keypad and press Enter. To insert a pause between numbers, press Redial/Pause. A ?-? appears on the display. 6 To assign a name to the number, enter the name you want. For details about entering characters, see page 1.14. If you do not want to assign a name, skip this step. 7 Press Enter when the name appears correctly or without entering a name. 8 To store more fax numbers, repeat steps 4 through 7. To return to Standby mode, press Stop/Clear. ***Sending a Fax using a Speed Number**** 1 Feed the document(s) face up into the ADF. For details about loading a document, see page 2.2. 2 Adjust the document resolution to suit your fax needs. See page 2.3. If you need to change the darkness, see page 1.20. 3 Enter the speed dial number. ? For a one-digit speed dial number, press and hold the appropriate digit button. ? For a two-digit speed dial number, press the first digit button and hold the last digit button. The corresponding entry?s name briefly displays. 4 The document scans into the memory. The fax number stored in the speed dial location is automatically dialed. The document is sent when the remote fax machine answers
Aug 17, 2007 | Samsung SF-560 Plain Paper Laser Fax
Cell Phones Logo
136 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
