Question about HP Compaq d530 PC Desktop
I have an HP Desktop D530 and am wanting to connect to the Internet but in Device Manager I have the yellow question mark on Ethernet. I know I will have to download the driver. Could someone please provide me the correct link for the right driver to burn and also the correct steps to follow after I burn the link. Thanks so much!
  • 1 more comment
  • karanm3 Oct 02, 2009
    will it safe to download to this computer of mine which is not an hp and then copy it to a usb and then follow what u said with the hp computer? thanks
    someone on here suggested that i download this driver for multiple operating systems for hp d530 to connect to the net through this link ftp://ftp.hp.com/pub/softpaq/sp42001-42500/sp42471.exe
    now the hp doesnt have internet connection so the above link is useless on that computer..will it be okay and safe to download the above drivers on this computer which is internet accessible but not an hp and copy the files to a usb driver and then use that on the hp. the main concern is the safety factor coz i dont want any problems on this computer. thanks
    i downloaded the file and when i double click on the main file b57w2k it says windows cannot downlaod the file. and it needs to go to the internet..not sure what to do its real frustrating
  • 10,515 Answers
It does not matter whether you use drivers from Hp website or from a sister concern website. I have seen many cases, where Hp don't have any drivers but still certain drivers available online help the customers.
This Question mark can still arise if you have updated drivers. If you have updated drivers then, there may be a conflict on the PCI bus so try the following. In Device Manager right click on the device and click Uninstall and then shutdown the PC. Next, remove the adapter from the PCI slot and then boot up the PC and then shut it down again and plug the adapter into a different slot and boot the PC. When the Found New Hardware appears cancel out of it and then run the driver install file that you just downloaded and reboot and then check to see if the issue is now resolved.
Now, If you do not have updated drivers, you may download from :-
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=316715&taskId=135&prodTypeId=12454&prodSeriesId=316713&lang=en&cc=us
Select your O.S and select the driver you wanted to install.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Do accept the solution, if 100% satisfied from my service!!
Posted on Oct 02, 2009
  • taran_2005
    taran_2005 Oct 02, 2009
    More addition to the above solution - It does not matter whether you download on a different computer and make a CD or store it in storage device and install it in your computer. That's absolutely fine.
    Let me know, if need any further assistance.
    Thanks.
  • taran_2005
    OK!!
    I am not sure, whether that file is corrupted or not. It's a big file. If i start experimenting, would take 1 hour only to download such file and check it.
    You can download the LAN driver from the below site :-
    http://drivers.softpedia.com/get/NETWORK...
    I am sure, the above driver is not corrupted.
    Before that, as i have read, we need to check whether you have Ethernet card installed or not?
    Follow the below .pdf file to confirm you have card and we need only drivers :-
    http://www.wsc.edu/it/helpdesk/residence...
    You need to have acrobat reader to view the file.
    Let me know, once done.
    Hope i helped you.
  • 813 Answers
Download the multi operating system drivers from:
Save the file on the desktop and double click on it to start the installation. Once complete, restart the computer and then the yellow exclamation mark would be removed from the Device Manager and you should be able to connect to Internet.
  • 1 more comment
  • Dixit Sardana
    Dixit Sardana Oct 02, 2009
    Yes, it is safe and can be easily done.
  • Dixit Sardana
    Did you install the above drivers on the HP Desktop?
  • Dixit Sardana
    Yes, it is safe to download the drivers on the computer which has Internet connection and then transfer to the HP Desktop using USB stick and install it on there.
Ethernet drivers
You will have to open up your network connections.
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled.
Click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow Question / Exclamation mark ? ! or a Red X you will need to update/reinstall the driver for the device
You only need check the following if you cant install the driver
Make sure you Ethernet/internet is enabled in bios.
Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press Enter make sure its enabled
then recheck the driveri t should be there
k the driver it should be there
make sure its enabledPci device arrows key scroll to nstalled
if you computer came with a motherboard disk the driver could be on it
or this disk provided by your ISP provider Internet Service Provider
or you might have to download one
http://download.cnet.com/wireless-atheros-ar5b91-7/3000-2112_4-202570.html
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
if these packages are not the right
http://download.cnet.com/2000-20_4.html
On the home page you should see a search tab just type in what you are looking for
tick in the box for windows software or all software box
IE: Motherboard name Wireless or Ethernet driver
you might have to try a few times to get it right
Aug 14, 2013 | HP Compaq d530 CMT PC Desktop
Nu ma pot conecta la internet !
google translated
I can not connect to internet
You will have to open up your network connections. Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled. Click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow Question / Exclamation mark ? ! or a Red X you will need to update/reinstall the driver for the device Make sure you Ethernet/internet is enabled in bios. Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press Enter make sure its enabled then recheck the driveri t should be there k the driver it should be there make sure its enabledPci device arrows key scroll to nstalled if you computer came with a motherboard disk the driver could be on it or this disk provided by your ISP provider Internet Service Provider or you might have to download one http://download.cnet.com/wireless-atheros-ar5b91-7/3000-2112_4-202570.html http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html if these packages are not the right http://download.cnet.com/2000-20_4.html On the home page you should see a search tab just type in what you are looking for tick in the box for windows software or all software box IE: Motherboard name Wireless or Ethernet driver you might have to try a few times to get it right
Hope this helps.
Jan 10, 2013 | Compaq Business d530 (PB185US) PC Desktop
I need an ethernet controller driver for my dell dimension 4600 desktop
Well that is a problem. You can go to "support.dell.com" to download the drivers, however since you can't connect to the internet you will need to use a friends computer and download it.
Aug 13, 2012 | Dell Dimension 4600 PC Desktop
Wont hook to the enternet
The Ethernet adapter may be conflicting or competing with the wireless adapter for the Internet connection. Try turning off the wireless adapter. You can either disable it in device manager, or some HP laptops have a button next to the screen that will turn it off. If you don't get an Internet connection, restart the laptop and try again.
If that doesn't help, I would suspect the Ethernet adapter driver is faulty. Check it under device manager. If it has a yellow exclamation point, question mark, or is not listed, the driver needs to be installed or reinstalled. If it simply has a red X on it, enable the adapter.
If the Ethernet adapter is fine, try a different Ethernet cable. If THAT doesn't help, it's probably software related.
A firewall may be keeping you from browsing. Some firewalls may see the Ethernet connection as an entirely different connection than the wireless one. Try disabling all firewalls.
Thanks
Jun 28, 2010 | eMachines W3118 AMD Sempron 3100+ 1.8GHz /...
I need ethernet controller driver, PCI bus for Presario 6010US
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=94026&lang=en Download driver from here but in installing of ur driver u must repair ur xp i the repairing progress it ask u driver in that u must give ur driver area
Apr 14, 2010 | Compaq Presario 6010US (470027-054) PC...
No sound after reinstaling Win XP
go to HP.com and download the sound drivers
install and restart the comp
Feb 08, 2010 | HP Compaq Business d530 Small Form Factor...
Too many ethernet devices!!!!!
get new drivers for your network card(s).
And delete all of the devices listed in Device manager
Jan 07, 2010 | HP Compaq d530 SFF PC Desktop
I have an HP Desktop D530 and am wanting to connect to the Internet but in Device Manager I have the yellow question mark on Ethernet. I know I will have to download the driver. Could someone please...
Save on your desktop and double click on this file to start the installation of drivers, once complete restart the computer and that is all. The yellow exclamation mark should be gone now and you can connect to Internet.
Oct 02, 2009 | HP Compaq d530 PC Desktop
I have an HP Desktop D530, which is normal size not the Ultraslim and am wanting to connect to the Internet but in Device Manager I have the yellow question mark on Ethernet. I know I will have to download...
Hope i helped you.
HP Compaq d530 PC Desktop Logo
314 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
