Question about Brother MFC-5440CN All-In-One InkJet Printer
Ink absorber pad is full - Brother MFC-5440CN All-In-One InkJet Printer
    President:
  • 1,653 Answers
You need to replace the waste ink absorber and then reset the counter. These can be obtained from some suppliers of ink and spares etc, otherwise you will need to contact Brother in your country or take the unit to a service engineer.
Generally when these errors occur the waste ink absorber needs replacing, if not your images will start to degrade in quality and you will start to see ink splays / splodges appearing as well as random spots and ink patches. In the mean time press RESUME /CANCEL to continue printing.
Posted on Oct 02, 2009
SOURCE: how to reset waste ink absorber full ip3300 warning?
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
Posted on Mar 23, 2008
Nicolomd
  • 84 Answers
SOURCE: ink absorber is full
Use this tool
http://www.startcopy.ru/repair/files/ip1100.zip
!!! Don't forget to vote!!!!
Posted on Feb 07, 2008
SOURCE: How to open Canon iP3000 and remove absorber pads?
my computer see the printer as ip3100 & ican`t load my driver
Posted on Mar 12, 2008
CAM THE MAN
  • 20 Answers
SOURCE: waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Posted on May 27, 2008
  • 421 Answers
SOURCE: canon ip4300 ink absorber is full
You need to reset the waste ink counter. The printer doesn't know that you have replaced or cleaned the pads you need to tell it.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Hope that helps, if it does please rate my solution.
Thanks
Posted on Nov 14, 2008
My ink absorber is full on mx310
When the cartridges are parked, there is a pad that absorbs ink when the nozzles self-clean. After a while it gets full. Put the printer in the change ink mode to move the cartridges away from their parked position. If there is a plastic cover over the absorber, remove it. Then take a straight pin and pull the absorber pad out. Wash out the excessive ink and let it dry before reinstalling.
Dec 13, 2016 | Office Equipment & Supplies
Canon IP90 ink pad is full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Feb 11, 2013 | Canon PIXMA iP90 Mobile Printer
E8 Waste ink absorber full, or platen waste ink absorber full WHAT MUST DO?
I am told that this will reset your counter and eliminate the full absorber warning that you are getting.
Cleaning the pads is messy, sending the printer to Canon is expensive,
I used a simular reset code for my MP470 and haven't had any problems.
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Jan 14, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Ink absorber full
There are two possible reasons for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads
. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error.
Reset the Printer using an MP Tool
Mp Tools are utilities designed to clear errors that will appear in an MP160 printer. Download this MP Tools here.
while the printer is on Run this software
1. Click Reset Main (main) to reset the waste ink counter and
2.
Click Reset Platen button (E27).
If errors still persist.
Press and Hold down Reset button and wait until the printer restart.
Release the Reset button and wait until it fully initialize.
Happy printing.
Please comeback and rate this answer.
Thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber if full, contact service provider? is there any other remedy?
There are two remedies for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Reset the Printer using an iP Tool
iP Tools are utilities designed to clear errors that will appear in an iP1800 printer. Download this iP Tool here.
1. Click Reset Main to reset the waste ink counter and
2.
Happy printing.
Aug 18, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Ink absorber is full cannot print
Mp Tools are utilities designed to clear errors that will appear in an MP150 printer. Download this MP Tools here.
2.
Happy printing.
Aug 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber (sponge part)
2.
Happy printing.
What does it mean when your printer is saying ink absorber is full
ink absorber pads in bottom of printer have become full of waste ink. would need ink absorber pads and know how to reset counters
Apr 14, 2010 | Canon PIXMA iP1600 Printer
Pixma ip1880 ink absorber is full pls tell how to fix
Turn off the printer and take some soft absorbent tissues and fold it into a pad.
Lift the cover to expose the ink cartridges and place this pad over the ink absorber on the LHS of the printer so the pad soaks up the wet ink.
Repeat until the absorber is nearly dry.
Nov 24, 2009 | Canon PIXMA MX310 All-In-One Printer
If ink absorber is already full what should i do next?
it is not possible for you it is the problem mantainence wast tank full it mean when we print then chack cartridge is automacily clean then some ink fall under pad this pad is full ink then machine say ink absorber tank is full
you go to aservice centre only support printer canon. Thy clean wast tank and reset your printer
Jul 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
2,046 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
