Question about Sony VAIO VGN-S150 Notebook
Usb problem when i plug a thumb drive into the usb it tells me that the usb is not recognized. i have tried installing xp sp2 and vista but both has the same problem. please help! But a simple things like a mouse works fine... seems as if it's a usb 1.1 and not 2.0. But when i hbought this laptop it says 2.0. Sony VGN-S150
  • 662 Answers
It really doesn't make much difference if you are using the Thumb drive on a USB 1.0 or 2.0, It could be possible that there is some issue with the Driver itself. Try to connect the drive to another USB port. Check if it happens with the Drive on other computer also. If it works fine on other computer Try to format it and then check on this system.
Hope this resolves your issue, Please let me know
Posted on Oct 02, 2009
    Scholar:
  • 66 Answers
I found some pretty cool documents here. You're right it says 2.0. but still, a lot of good info. http://esupport.sony.com/US/perl/model-documents just put in your model and hit search. On the top left is a link for drivers & software.
click on show all files. Make sure your drivers are up to date but especially the ones for the memory stick and the mouse.And use you windows updates faithfully! So many new bad bugs out there, you need them up to date.You should already have sp3. Not a good idea to cut corners in that area. Not having them could make all kinds of things go wrong. Last but not least you might try powering on with your device attached. If I helped pleased rate me..Thanks and good luck.
5 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: Reinstalled xp after Vista . USB port not working
i've found drivers for an ed 500 at
http://ca.lgservice.com/index_b2c.jsp
you can try the drivers... but do NOT use the bios driver
Posted on Dec 19, 2008
anasmaq
  • 100 Answers
SOURCE: usb device not recognized problem
uninstall driver then turn off the PC then unplug the power cord from power socket, short its legs then leave it unconnected for 5min, then reconnect it to power socket and turn on PC and install driver it should work :)
Posted on Dec 29, 2008
  • 5 Answers
SOURCE: USB device not recognized
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
Posted on Jun 18, 2009
Says my system does not meet requirements . Cannot download . Running Windows Vista with Service Pack 1
You need to install Vista Service Pack 2 Minimum System Requirements:
  • Microsoft® Windows 7 Home Premium (32- or 64-bit), Microsoft® Windows Vista™ Home Basic SP2, Windows® XP SP3 (32-bit) or SP2 (64-bit), 1 GHz processor and 512 MB RAM
  • 1024x768 DirectX 9.0c compatible graphics card with at least 16-bit color setting, sound card, DVD-ROM drive
  • 2 GB free hard drive space for installation
  • Windows Media Player 10 or higher
  • CD Writer for audio CD and DVD Writer for DVD
  • Internet Explorer 7 and 8
  • QuickTime player version 7.6 for some functionality
  • One available USB 2.0 port
Mar 01, 2011 | Roxio Easy VHS to DVD for PC
MSI RS482M4 Mobo not recognizes USB port on XP SP2-3 boot.
Try to find application that load the CPU at 100% by seeing TASKMANAGER.
To start TASKMANAGER press CTRL+ALT+DEL on the keyboard, select PROCESSES TAB, click on CPU to order by CPU load and find process that come near to 100%.
Oct 18, 2009 | Computers & Internet
USB flash drive un recognized -transcend JF v30/8GB. i have tried a couple of computers (VISTA/XP-sp2) same problem yet previosuly was working. can i recover the drive + data?
Have you tried to manually install the device? Do you see any changes on the screen when you insert the USB device? Do you see any lights on the Flash Device when it is inserted into the computer?
Ryan Frame
Creative Energy Associates Technical Center
Sep 03, 2009 | Transcend (589307) Media
I need the driver for wd2500me-00,usb external hard disk
The folks over at WD said:
There are no downloadable USB, Firewire, or eSATA drivers available. WD external drives install using the resident USB and Firewire drivers that come in Windows 2000 SP4, XP SP2, Vista, and Mac 10.4 and 10.5. If the drivers are not installing when you connect the WD drive, or you are having driver issues, you will need to contact Microsoft or Apple for their recommendations.
I will search further if you like, just let me know.
Try the old, disconnect (the drive form the computer), reboot, reconnect, reboot once again and see if it picks up the way it was meant to.
Hope this has been of help please leave rating
thank you.
May 08, 2009 | Computers & Internet
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
The usb drivers are part of your chipset drivers, so lets try and get this sorted. The reason that they work in Vista, is probably because Vista has added support for your chipset and XP SP2 doesn't.
Try installing XP from scratch. First you need to completely wipe your hard drive. Use the XP boot disc, you need to delete the hard drive partition as well. This way, you will start with a RAW drive.
Set up a new partition, and let the XP disc format the drive with NTFS. Do NOT use quick format. Then let XP copy the files and install.
When XP has installed, get your internet set up, and download XP Service Pack 3 from Microsoft:
http://www.microsoft.com/downloads/details.aspx?FamilyID=5b33b5a8-5e76-401f-be08-1e1555d4f3d4&DisplayLang=en
You will notice that Microsoft have written not to use if updating just one machine. Ignore this. The reason is because this is the FULL Service Pack, hence it being over 300MB.
Once you have SP3 installed, your system will restart. Open Windows Update, make sure you have this set to update all Microsoft products, then download all updates. Restart your system and check if your usb's are working.
If they are still not working, go to the laptop website and download the chipset drivers from there, but make sure you are downloading the drivers for XP. If not, then go to the Chipset manufacturer's website and download from there.
Let me know how you get on
Tim
Dec 19, 2008 | Computers & Internet
Windows Vista Don't recognize my usb hard discs
last guest your a f u c k i n g a s s h o l e..i have the same problem with vista nad no one has an answer...
Aug 10, 2008 | Computers & Internet
PNY Optima Pro Attache 4 G
Make sure you are using the right port. There are slow and faster ports on a laptop.. So try plugging it into another and see if it helps
Jul 18, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Driver Issues on Windows Vista Basic
As an adhoc solution you may try to download drivers for XP SP2, tell the driver installation applet to search for drivers from the folder you downloaded them to when it tells you this driver was not made for Vista tell it to install them anyway. It may not work but as this manufacturer is no longer in the modem biz vista is not supported by them at this time.
Jan 15, 2008 | Microsoft Windows Vista Ultimate Edition
USB will not recognize devices
just try to first install your device driver in xp-home sp2 and then try if not pllz ask me.
Dec 25, 2007 | Dell Dimension 4500 PC Desktop
Sony VAIO VGN-S150 Notebook Logo
95 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
