On the Library section of the DT16300 I have approx 8.5 hours of saved programmes yet the display says there is only 18% of disc space left! out of 60 hours recording time?.
After Re-loading the Freeview Channels on 30th Sept, the disc space was nearly full on The Thomson DT16300. Go to Set up in the Menu, choose 'Personal Favourites' this will bring up all the stored Channels, For some reason a lot of the Channels are marked 'ON' each one takes up disc space. De-select every one, the channels stay in the recorder but release disc space. I now have 86% free. Trevor Rushton
Posted on Oct 05, 2009
I recently purchased the Toshiba DR570KU DVD recorder. I live and purchased this machine on a small Caribbean Island,and with respect to local people they have no technical knowledge of what they are...
Hi -
I'll try to explain without confusing you any further, but if anything doesn't make sense, please let me know. The instructions on page 79 are contradictory, which doesn't help very much. The upper part of the page suggests you can create extra space on a DVD+RW disc by deleting titles, while the lower part, in the grey box, states you cannot. The bottom part is actually correct.
I'll split this into two sections - blank/unused and used discs then explore a few scenarios.
Blank/unused discs
A DVD+RW is typically 4.7GB and will record approx. 2 hours of video in SP mode or 4 hours inLP mode. If you record more than one programme, they will appear consecutively in the disc editing menu, and shown as numbered blocks in the Title List. The last block shown will always be 'EMPTY', but the actual size of this block can be all or none of the total capacity of the disc.
If you insert a blank DVD+RW disc into the machine and view the title list, you will see this:
Although you can't 'record' to a block labelled EMPTY, this doesn't mean you cannot record to this disc. The blank space on the disc precedes the block labelled as 'EMPTY'.
If you then record one programme of 1 hour duration in SP mode. the title list will look like this:
Once again, although you can't 'record' to the block labelled EMPTY, this doesn't mean this disc is full or that you cannot record anything else on it. The next programme recorder will appear between title 1 and the 'empty' block - as long as there is sufficient space on the disc remaining to record the programme.
If you then record a second programme of 1 hour duration in SP mode. the title list will look like this:
This disc is now full as 2 hours of video has been recorded in SP mode. However, if you'd only recorded 1 hour in total for these 2 programmes, you would still be able to record another hour of video in SP to this disc. The additional programmes would appear between the last numbered title and the 'empty' block - until the disc is full.
The empty block is always present and you cannot 'get rid of it', but it doesn't mean the disc is full or cannot be recorded on.
Hopefully, this goes some way to explaining it, but I still need need to explain what happens with used / full discs when you want to delete programmes and re-record.
There is a maximum length for messages posted on FixYa and I may be getting close to this, so rather than break off in mid-flow, I will continue the explanation for used discs in another message below this one. I will do this right now, but it will probably take me 20 minutes or so to write part 2, so keep checking back. It will be less confusing if you hold any questions until I've written part 2, but I will be happy to answer any after that.
Regards,
BElectric
May 02, 2011 | Toshiba DR570 DVD Recorder
My lg recorder will not delete progs !?
my l g hard drive recorder/dvd,suddenly would not delete programmes that i wanted to edit ,also the timeshift would not work,but i could still record ok,and i had a few hours space left on the hard drive .so i copied to disc my favourite stored programmes ,about 3 discs,and put them to one side .
i tried then to format the complete hard drive ,but it didnt do anything !so i put it on record for 7hours on sp,then i stopped recording, and tried deleting the programme straight away ,and it did !it also cleaned the hard drive empty ! the timeshift is ok and all else is ok ,so i fixed it witha bit of my logic !hope this helps someone one day !
Sep 22, 2009 | LG RH266 Recorder
Thomson DT16300 Freezing problems
Can anyone help me solve a problem with my Thomson DT16300? The orange light stays on. The fan comes on and off at the back. There is no picture and I can not programme it. I have tried rebooting but can't get it working apart from the orange light coming on and the fan starting up.
Feb 06, 2009 | Thomson DPL909VD System
Recording fails to delete
Record another programme so that you have something above the dodgy one in your library. Then go back into your library and press down, blue then green really fast. This worked on mine.
Jan 02, 2009 | Philips DIRECTV H20 DTV Receiver
I am recording fron VHS to DVD. When I am finished and push the stop button, How can I tell how much space is on the DVD to record something else and how do I finish the dik so it can't be recordered over
JVC DVD Recorder – Finalizing and disc space
First, you will need to know if the program was recorded in XP mode, SP mode, LP mode, or EP mode. To find out how much room there is left, put the dvd in the tray and press the Disc Menu/List button on the JVC remote. This will display the title and how long it is - write that number down. It will also say either "XP,SP, LP, or EP" - write down that mode. In XP mode, a DVD will hold 1 hr and 20 mins worth of prgramming - MAXIMUM. SP mode = 2 hours. LP mode = 4 hours. EP = 6 hours. So, if your program is one hour, and you recorded in LP mode, you have 4 - 1 = 3 hours of space left for recording on that disc.
If you finalize a disc, you will no longer be able to add more programs to that disc, unless the disc is a + or - RW disc. Also note that finalization requires some disc space, so if you recorded a program that is exactly 1hr and 20 mins long, and you recorded it in XP mode, then the disc will probably not finalize correctly.
That being said, the finalization directions are on p. 23 of your manaul: Title --> Finalize --> => --> find finalize --> Enter --> OK --> Enter
Now it will play on other players.
Here is a link to the user manual:
http://resources.jvc.com/Resources/00/00/93/LPT1133-001A.pdf
-Tha Mp3 Doctor
Dec 31, 2008 | JVC DR-MV7 DVD Recorder/VCR
Problem with Thomson DTR DT16300-25 I have bought a DTR and I have programs stuck in the Program Library which I don't want and can't get rid of. If I try it hangs the DTR and I have to remove power to...
We've had the same problem with our Thomson DTR, but it was relatively simple to fix. Go to the menu by pressing MENU, then press 4 followed by 6. This will show the Help menu. Then, key in 1397 to enter 'engineer' mode, which contains several useful diagnostic functions. Scroll to item 7 (disable library video window) and toggle it to Yes by pressing the right directional button on the remote. After this, press Library, then delete the unwanted programmes.
It's very annoying, but hopefully the bug will be fixed when the next software update comes out.
Hope this has helped.
Oct 02, 2008 | Thomson Televison & Video
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Pioneer DVR 640 H
You may have CDs stored in the Jukebox taking up space- if so delete them.
You may have images stored in the photoviewer - again, delete...
Have you done any disc backups, and forgot to delete the backup file? Goto bottom of copy menu for disc backup, then in the disc backup menu, choose delete backup file.
Jan 04, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
ACER 1360
Unless I am mistaken, the D drive or partition is the partition that contains the restore feature for yor laptop. This may or may not be hidden system files. As far as the available free space on your C drive, you WILL need to either delete files and/or backup and delete files. Image files, music files, cookies temp files take up a lot of disk space. Try this and I think you will find more free space. BPCS
Dec 23, 2007 | Acer Aspire 1360 Notebook
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
